The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jun 25, 2022 at 7:40 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Anyone else with a 3500 lb RC 2nd Gen who has done 2.0’s or 2.5’s?
    I had an extra set of fox rear 2.5 w remote reservoir and DSC so I got some basic fox 2.0 fronts and had them both installed.
    It’s still a bit more of a harsh ride than I expected even after adjusting preload down. The previous suspension, at 128k and 17 years, was fine. I probably should have left it as is.
    I’m wondering if 500 lb springs would make sense for such a light vehicle. I’m not sure I fully understand how it’s all playing together but I think the primary stuff ride comes from the fronts. Also wondering if I would benefit from shock tuning? Just not sure what the options are really.
    The full 2.5 remote reservoir dsc setup on my 2016 is a dream, I think mostly because it’s a heavier vehicle.
  2. Jun 25, 2022 at 8:17 AM
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    I don’t have a Pre-runner or 4x4 but on our 5 lug Reg cab and Access cab there’s a BIG difference between the OEM front springs. I did install Icons when we had our 2015 DCSB Pre-runner V6 just for the nice ride and better handling. I could tell the 650 lbs springs were on the stiff side.
    What front spring rate / springs do you have?
  3. Jun 25, 2022 at 10:42 AM
    daveeasa
    David
    PNW
    I asked Fox and I believe they said the springs are 600 and suggested 550’s might not be a noticeable difference. But 500’s sounds drastic unless anyone else has experience with that.
  4. Jun 25, 2022 at 10:58 AM
    Hayrider
    Hey You…
    Convection Oven AZ
    Dave,
    These are some of the best made springs available. I believe you need 2.5” x 14” springs if so here’s a link.
    https://www.a1racing.com/hyperco-1814b0500-coil-over-spring-2-5in-id-14in-tall.aspx
    Edit;
    Dave, just for an example on spring rate. This gentleman has a Access cab Pre-runner with an Iron block LS engine swap. He’s running 550 lbs front springs so I’m fairly sure 500 lbs springs will not be too soft…
    https://www.tacomaworld.com/threads/munkeywrenchs-2nd-gen-ls-swap.661391/page-2
    daveeasa[QUOTED] likes this.
  5. Jul 13, 2022 at 9:41 AM
    HGPineapple
    HGPineapple Active Member
    Hawaii
    2013 Superwhite RC
  6. Jul 20, 2022 at 11:06 AM
    sogafarm
    sogafarm Well-Known Member
    GA
    2012 tacoma reg cab spruce mica
    31" Falkon wild peak AT's, fat bobs lift, mud accents
    Happy Birthday to my 2012 Tacoma! Bought new in July, 2012. Ten years of 85,000 trouble free miles.
  7. Jul 26, 2022 at 9:44 PM
    KanakaRebel
    KanakaRebel Well-Known Member
    Kauai, HI
    2009 Tacoma 4x4 Single Cab
    Anyone had to replace rear parking brake cables on their 2nd gen Tacoma with bench seat? If so, did you have to pull up the carpet to get to the portion that connects into the cab? I’ve watched videos online, but they’re of double cabs with bucket seats, so they remove the cup holder and the linkage is below that……..which I don’t have.
    Dirtybird45 likes this.
  8. Jul 28, 2022 at 7:24 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    You don't have to remove the carpet, it has an opening right behind the cables to access them. You might need to remove the seat to get enough room to work though.
    KanakaRebel[QUOTED] likes this.
  9. Jul 29, 2022 at 10:27 PM
    KanakaRebel
    Kauai, HI
    Damn, was hoping to be able to do it without removing the seats. Does it seem like something that can be done in 8 hours? Gonna attempt this at work, boss could care less what I do during work so it’s the perfect time to fix it without interruptions.
  10. Jul 30, 2022 at 9:30 AM
    ryfox0276
    Montana
    2013 RC 4x4
    You may be able to get away without removing it. Push it all the way forward and see. I took my bench out a while ago so I can't help you further there. And as far as how much time, I've never worked on my parking brake cables so I can't help you there. As far as removing the seat, shouldn't take you more than 20 minutes. Less if you have a buddy. If your seat has airbags remember to unplug your battery first to be safe.
  11. Sep 1, 2022 at 1:17 PM
    that_06regularcab
    that_06regularcab 3rd gear wide open in a Toyota
    Southern Oregon
  12. Sep 1, 2022 at 2:33 PM
    Hayrider
    Hey You…
    Convection Oven AZ
    2.7L Pre-runner?
    I didn’t think anyone here would be into a Donk Tacoma. God I hope you have gears or you like getting 6 mpg…
  13. Sep 1, 2022 at 3:06 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    disliked
    Soonr1, IEsurfer and easleycrawler like this.
  14. Sep 1, 2022 at 6:43 PM
    that_06regularcab
    Southern Oregon
    529s and front/rear lockers. 20mpg
    Hayrider[QUOTED] likes this.
  15. Sep 1, 2022 at 9:04 PM
    Hayrider
    Hey You…
    Convection Oven AZ
    That good…but what about these? As sometimes you got to STOP‼️
  16. Sep 1, 2022 at 10:48 PM
    that_06regularcab
    Southern Oregon
    Oh I don’t have a problem stopping but I’ll upgrade brakes at some point yes
  17. Sep 6, 2022 at 8:27 AM
    daveeasa
    David
    PNW
    Has anyone slapped a pro skid plate on their truck? The oil filter door won't be usable, right? But otherwise it would bolt up just fine?
  18. Sep 6, 2022 at 10:14 PM
    that_06regularcab
    Southern Oregon
    What’s a pro skid plate? Just a gnarly one with a lot of coverage/protection or sumthin?
  19. Sep 8, 2022 at 8:42 PM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    My single cab project isn't going to happen............had one picked out but it just didn't work out.
    I was so sure I was getting the truck that I bought a bunch of stuff to customize it. Looking to sell a ton of stuff. ALL NEW. In the Des Moines Iowa area.
    Including:
    Black tailgate emblem overlays (small TOYOTA and TACOMA)
    OEM Toyota parts:
    Cruise control
    Intermittent wipers
    Antenna mast
    White door edge guards (3rd gen but think they'll fit 2nd gen)
    Touch up paint - white
    All this stuff is brand new and still in the packaging. HUGE DISCOUNT OVER RETAIL PRICES!!!!!! PM if interested in anything or all of it!!!!
    Grumpy and Black Bean Taco like this.
  20. Sep 10, 2022 at 4:28 PM
    PITT_Taco
    PITT_Taco Well-Known Member
    Mitch
    Charleston, SC
    2012 RC 4x4 5spd
    2016 TRD Sport Wheels, Truxedo Tonneau Cover
    I always thought I'd keep my 2012 taco forever but I'm finally putting her up for sale. Couldn't ask for a better truck
    MSN88longbed, whatstcp and IEsurfer like this.
