The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Feb 7, 2013 at 9:00 PM
    #1661
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Just as the right and left wheels need to turn at different rates, the front and rear axles also need to turn at different rates, so the transfer case has to allow for that by running a diff on the driveshafts.
    You could quite literally "redneck engineer" an AWD using a third diff and come creative brackets and bevel gear assemblies, and of course adjusting your transmission's ratios to allow for the added diff.
    Remember, AWD is full-time, and no 4L range, so this assembly would replace the transfer case.
  2. Feb 8, 2013 at 6:20 AM
    #1662
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Did you adjust your mileage for the tires? 265/75/16 are 3.7% bigger so you need to multiply your miles driven by 1.037 to get actual miles driven. Additionally yours is probably more like 4+% because the treadwrights are a lot taller than regular 265's
  3. Feb 8, 2013 at 6:31 AM
    #1663
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Anybody wanna guess whether an 08 SR5 RC Prerunner has the pwr mirror harnesses in the doors already even tho it does not have pwr windows or locks? I'm guessing it won't so I'll have to run wiring from doors to switch but I will find out tommorrow when I pull door panels to install nice fresh 2012 pwr mirrors just scored from member here. And would the mirror harness plugs for 2012 mirrors be same plug for earlier yr model pwr mirrors? I'm sensing a wiring job vs. plugnplay done in 15 minutes thing.
  4. Feb 8, 2013 at 7:18 AM
    #1664
    EEKANOUSE
    EEKANOUSE Well-Known Member
    will
    PA
    2010 standard cab 4x4
    3" lift, Goodyear 265/75 duratrac, wet okole seat covers, are cap, safari springs rear.
    Jeep cherokes have a full time t case you could use they have a full time4wd position and part time 4wd position think this t case was used in hummers too. Allows for awd on wet or dry surfaces without damage to drivetrain and the ability to switch it for "real 4wd" my 2008 had it think its called selectrac.
  5. Feb 8, 2013 at 8:02 AM
    #1665
    EEKANOUSE
    will
    PA
    Sorry it was a 98 jeep Cherokee and the t-case is a NP-242 selec-trac.
  6. Feb 8, 2013 at 8:15 AM
    #1666
    EEKANOUSE
    will
    PA
    The np-242 allows for full and part time 4wd as well ad 4-lo and even has a real lever no sissy switch haha probablly easy to source a junkyard one considering xj cherokees were a dime a dozen in the 90's.
  7. Feb 8, 2013 at 2:55 PM
    #1667
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Ratio gearing, I pictured the redneck engineering part with your first post thus my question. But yeah I know about awd and how it works.
  8. Feb 8, 2013 at 7:01 PM
    #1668
    EEKANOUSE
    will
    PA
    Why even mess with all that when they make transfer cases that already do it for ya? Awd is for soccer moms not trucks. Just sayin
  9. Feb 8, 2013 at 8:52 PM
    #1669
    Rich91710
    Rich
    Los Angeles
    08 Base
    They don't always correlate, but being brilliant is a damned good way to get a big bank account.
    My buddy was brilliant when his dad was a Diesel mechanic.
    Today he owns two houses on the harbor and 3 boats.
    Still drives a 2000 325i though :D
  10. Feb 8, 2013 at 8:55 PM
    #1670
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, but Kase is slammin' his 4x4 and running street tires.
  11. Feb 8, 2013 at 8:57 PM
    #1671
    Rich91710
    Rich
    Los Angeles
    08 Base
    Seriously?
    I'm surprised regular cabs have widow cranks. They aren't going to be prewired for anything but the speakers.
  12. Feb 8, 2013 at 10:56 PM
    #1672
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    Really? Tell that to the 80 series Land Cruiser. sure, there are plenty that Have done their share of mall cruising but they are still probably the most stout/capable full time 4wd vehicle to roll off of a showroom floor.
  13. Feb 9, 2013 at 11:15 AM
    #1673
    EEKANOUSE
    will
    PA
    I agree but they prob have an awd system that differentiates the front and rear through a transfer case not all that other crap that was my point transfer cases are capable of doing it
  14. Feb 9, 2013 at 11:17 AM
    #1674
    EEKANOUSE
    will
    PA
    And that land cruiser is prob locked into 4lo through its awd transfer case for anything serious
  15. Feb 9, 2013 at 12:05 PM
    #1675
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    Hah I thought about making some sigs for people since I was changing mine every few days. Then I got Call of Duty Black ops II and started playing zombies for 6 hours a day. Sigh. But good twerk.
  16. Feb 9, 2013 at 12:29 PM
    #1676
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    As you probably know, the 80 series does have to be in 4lo to lock the front/center/ rear but I have found out that they are more than capable in 4hi and unlocked. I have wheeled mine ( pictured above ) in 4hi, 4lo, locked and unlocked and I was surprised what she could do in 4hi after my initial outings were locked up. She is like a Bull dog when she is locked and i am still running OEM birfs.
    PLANTED, is the word that comes to mind. I would certainly take the 80 " wheeling " over the Tacoma any day. The only reason I bought the 4wd Tacoma is that I would rather have and not need it than need it and not have it.
  17. Feb 9, 2013 at 3:40 PM
    #1677
    Rich91710
    Rich
    Los Angeles
    08 Base
    About 10 minutes and you can do it with nothing more than a screwdriver and plastic butter knife.
    There are 3 part numbers for the stalk, the only difference seems to be the legend/symbols to indicate delay, and which direction the knob is turned to increase/decrease the delay.
    I'm using 84653-04141
    It has actual words on the stalk, and the slowest speed is all the way up on the knob... it's natural, as the knob is turned "down" (top toward you) the wipers speed up. When you hit bottom, it's time to pull the whole thing down, so speeding up the wipers is a continual progression of "down".
    The '12-'13 stalks have symbols instead of words, and I think the part number specified for the '09 and later reverse the direction of operation of the knob.
    Also, the low speed will change.
    Right now, your 2 speeds are "Fast" and "Too Fucking Fast"
    With the new stalk, "Fast" is now "Nice"
  18. Feb 9, 2013 at 6:20 PM
    #1678
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
  19. Feb 9, 2013 at 6:47 PM
    #1679
    btipsword
    btipsword Well-Known Member
    Ben
    Illinois
    12' Reg. Cab 4x4
    Billys at 1.75,1" Block in rear for now,16x8 Pro Comp 7089,265/75/16 Duratracs,Aftermarket Tow Hitch, Tint 30% front 2 15% rear
    Got my tacoma in a little mud today, went out shootin' guns with the family and it was a little wet!
    Thinking about updating suspension, maybe a little bit more lift. Currently running billys at 1.75 up front and a 1" block in the rear with 265/75/16. Any ideas? Not wanting to go any bigger on tires. (don't wanna lose power). anyway heres the pic
    photobucket-44059-1360459668297_zps81464_f128f3ee2d7f6c913adfc64301c579d7bcbfd4f2.jpg
  20. Feb 10, 2013 at 7:56 AM
    #1680
    Leonel
    Leonel Well-Known Member
    San Francisco,CA.
    2017 Super White DCSB TRDOR/6MT
    TC,Ext Kings,U402's,4:88's.Elocker rear,ARB front,etc..
    I used part#84652-02610 in my 2012 and it works perfect !!
