The 2 low mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by JVTACOMA, Jan 16, 2009.
  1. Jan 16, 2009 at 12:10 PM
    JVTACOMA
    JVTACOMA [OP] Well-Known Member
    York, Pa
    I was sitting here thinking about all the crap I've done to truck such as mod and cheap tricks and was checking out the stickies about mods to see what else I could do. However, in the link below are two mods that I've done and didn't see on the forum at all. Hope this is not a repost..
    The 2 low mod...one of my frav...
    Full time power outlet mod...
    http://www.yotatech.com/f127/full-time-power-outlets-01-tacoma-75184/
  2. Jan 16, 2009 at 2:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  3. Jan 19, 2009 at 10:10 AM
    JVTACOMA
    York, Pa
    man you were not kidding about digging for it!!!
  4. Jan 19, 2009 at 2:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :D.....................a few shovels worth,huh??:D
  5. Mar 9, 2009 at 5:14 PM
    davistn
    davistn Member
    i have a question about the 2 low one. so when you engage the button and put it in 4 low then its in 2 low? and when you unengage the button then its in 4low?
  6. Mar 9, 2009 at 5:15 PM
    davistn
    davistn Member
    ok nvm, i just read it again...
    when you have it in 4 low w/o the button engaged its in 2 low.
    haha. gotcha.
    nice mod.
  7. Mar 9, 2009 at 6:03 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Thanks Will, I had totally forgot about the power outlet mod. Took 5 minutes, and that was with shrink tube. Now I can run a spot light or charge the phone/camera with the keys in my pocket. Kevin
  8. Mar 9, 2009 at 6:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this is one mod i still gotta do....been too lazy.:D
  9. Mar 9, 2009 at 7:13 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    thats a pretty sweet mod..i gotta get around to doing that(full time power outlet)
  10. Mar 9, 2009 at 7:23 PM
    Monkeysuncle
    Kevin
    Florida
    Yea I was worried about a check engine light or something along those lines but nothing like that, it works and works well. I even made sure the relay that was replaced was protected by a fuse, and it was. So now charge all the small things without being interrupted by turning off the key. Kevin
  11. Mar 10, 2009 at 3:08 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    BUMP:
    This should be a sticky!
  12. Mar 10, 2009 at 5:13 PM
    davistn
    davistn Member
    is this 2 low healthy for your truck? i mean the 2 low is wayyyy lower than the 4 low...
  13. Mar 11, 2009 at 5:54 AM
    PrezidentRedz
    Redz
    Owings, MD
    All it is: 2wd Low Range. That way then you dont need 4wd Low, its just an option. for people that wheel...:D
  14. Nov 2, 2013 at 11:58 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Uh no it's not.... It's the same transfer case reduction.
  15. Nov 2, 2013 at 3:25 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Reply is better late than never....lol jk
