The 2-stroke thread
Discussion in 'Motorcycles' started by RenoTacoma, Dec 6, 2011.
  1. Feb 17, 2015 at 8:49 AM
    #841
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    lol, tons of people think it's a Suzuki.
  2. Feb 17, 2015 at 9:14 AM
    #842
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Zuki or not, is that smoker efi?
  3. Feb 17, 2015 at 9:36 AM
    #843
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    The Yami's are still carb'd :(
    Smokers are like the red headed step child when it comes to R&D
  4. Feb 17, 2015 at 10:38 AM
    #844
    JBecker
    Virginia
    It's carbureted.
  5. Feb 17, 2015 at 10:45 AM
    #845
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I kinda prefer carb for a 2 stroke, unless the efi system was smart enough to compensate for different oils, oil ratios, etc.
  6. Feb 17, 2015 at 10:49 AM
    #846
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Sadly yes, or is it that they are just that simple.... wouldn mind having the throttle control of EFI though.....
    What does oil ratio have to do with the computer compensating for fuel air mix? Just wondering what your thoughts are.
  7. Feb 17, 2015 at 10:53 AM
    #847
    JBecker
    Virginia
    You would have to program the system for the oil ratio you are going to run. Just like you have to jet the bike now for different oil ratios.
    If you run more oil, you will have to up the amount of fuel flowing through the carb or throttle body or you will have a lean condition.
    Nothing different from how it currently is. You just would use a laptop instead of pulling the carb apart.
  8. Feb 17, 2015 at 10:56 AM
    #848
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I was thinking like the old huskys that didn premix the oil but ran a seperate feed instead for mix oil. A setup like that would then allow the bike to adapt to conditions.
  9. Feb 17, 2015 at 10:58 AM
    #849
    JBecker
    Virginia
    You could but it's not needed. There are already aftermarket EFI retrofit kits available for 2 strokes. They work fine with premixed fuel.
    Adding oil injection systems bring it's own set of problems. You need a separate oil tank, and an oil pump. They tend to be less consistent, and more prone to failure.
  10. Feb 17, 2015 at 5:24 PM
    #850
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah I guess that was my question, how sensitive is the oil ratio with jetting? obviously running more oil causes there to be less fuel in the mix causing a lean condition when compared to the same jetting with less oil but I'm just not sure how lean...
    Oil injection systems scare me, my rd350 has one that I'm stupid paranoid about, always checking the hose fittings etc :laugh:
  11. Feb 17, 2015 at 6:55 PM
    #851
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    The oil displaces the fuel as you said. How fat you can go is a matter of testing, go up and couple main sizes and hammer it!
    Most guys I know with RDs and RZs just premix the fuel and ditched the Oil injection system. But they are all track guys sooo..not so convenient for a daily needing to stop for gas.
  12. Feb 17, 2015 at 7:31 PM
    #852
    JBecker
    Virginia
    Just as a point of reference between my KTM and Yamaha 250's. My KTM was setup for 50:1 and the Yamaha 32:1. The KTM was running a 172 main jet and 45 pilot. Yamaha a 180 and 50. Same needle on the middle position and both run the air screw 1 turn out. Both also have the same reed system, same pipe and silencer.
    I'm also running VP C8 fuel. If I were running pump gas I would have needed to up the jet size a bit more.
  13. Feb 23, 2015 at 1:29 PM
    #853
    Speed Freek
    Hell yeah 1st place in Nationals, currently in 1st place in the Series!!! I want that #1 plate baaaad.
    And I'm doin this shit on a clapped out 2005 YZ250 with a big bore kit, whoopin the 450s and fancy euro 300's...:)
    Senior (40 yrs. & up) “B” - Cumulative Race Times by Place
    Place Rider# AMA# NHHA# Rider Name Club Sponsors Brand Lap 1 Lap 2
    1 N736 962019 N736 Jason Watson BADGERS Leatt, TBT, Cycle Gear, TUbliss, Dirt Digits
    YAM
    2:00:21 (2) 3:31:53 (1)
    2 N759 819409 Frank Zugovitz
    BET
    2:00:50 (3) 3:34:16 (2)
    3 N188 892751 N188 Scott Aldridge Fly racing, Motoshop, KTM Country
    KTM
    1:58:38 (1) 3:39:18 (3)
    4 N833 1108282 N833 Bruce Tookey
    KTM
    2:07:42 (4) 3:53:30 (4)
    5 O999 810277 Matthew Mcgowen UNITED
    KTM
    2:13:21 (5) 4:13:30 (5)
    6 N859 280532 N859 Carl Westphal JAVELINA RACING, MOTOREX, ONEAL
    KTM
    2:16:11 (6) 4:14:58 (6)
    7 N838 2198214 N838 Tetsunori Sukenobu
    HON
    2:17:58 (7) 4:15:49 (7)
    8 N867 963258 N867 THOMAS HUNDTOFT
    KTM
    2:19:03 (8) 4:22:54 (8)
    9 N843 2202589 N843 Hideyuki Fukuoka
    HON
    2:27:12 (12) 4:24:59 (9)
    10 O13X 911575 Gary Lipczynski JACKRABBITS
    YAM
    2:24:20 (11) 4:28:56 (10)
    11 O34 899007 Bob Boals BADGERSMC
    KTM
    2:24:14 (10) 4:31:48 (11)
    12 N320 920852 N320 Steve Grieb C&D Cycle Center
    BET
    2:23:36 (9) 4:32:11 (12)
    13 O16 3011964 N112 Jason Becker BADGERS 3Bros ktm , Petra Geosciences
    KTM
    2:33:20 (14) 4:36:40 (13)
    14 N113 1107997 N113 Daniel Hamilton
    HON
    2:29:25 (13) 4:46:40 (14)
    15 N821 907626 N821 Garrett Wichmann
    KTM
    5:24:57 (15)
    DNF O17X 1078914 David Scales
    HON
    3:36:00 (15)
    DNF O20 810351 David Tullar SO CAL
    YAM
    4:09:21 (16)
    DNF O104X 910576 O104X Paul Le Tourneur
    KAW
    DNF N839 2753971 N839 Curt Van Valkenburg
    KTM
    DNF N857 1092806 N857 Tony Jewell
    KTM
  14. Feb 23, 2015 at 2:54 PM
    #854
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Congrats!!! That's awesome.
    Also thanks for the jetting info guys, it makes sense.
    I finally got around to doing the fork seals on the new yz, it was my first time messing with upside down forks, not too bad with the right tools. Pvc seal driver ftw!
  15. Feb 24, 2015 at 8:16 AM
    #855
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
  16. Feb 24, 2015 at 1:16 PM
    #856
    Speed Freek
    Thanks guys! Mixin gas and haulin ass!! Or tryin to anyway....
  17. Feb 24, 2015 at 1:20 PM
    #857
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Congrats man!
  18. Feb 24, 2015 at 2:09 PM
    #858
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    :burnrubber:
  19. Feb 25, 2015 at 12:48 PM
    #859
    Speed Freek
    Thanks guys, so far I am 1st place in the National Series after 2 rounds, 6 more to go!
  20. Feb 27, 2015 at 10:49 AM
    #860
    Cr250jumper
    The moon
    50 shades of tan©
    Looks like Chad Reed will be riding a KX250 in the opening ceremonies in Atlanta tomorrow, this week is 90's throwback week for supercross
