The 2-stroke thread
Discussion in 'Motorcycles' started by RenoTacoma, Dec 6, 2011.
  1. Jul 12, 2015 at 11:20 AM
    #1001
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    I'm not sure I see your problem...
  2. Jul 15, 2015 at 10:40 AM
    #1002
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I have a 2014 200 XC-W that I just recently added some Powermadd bark busters. After adding the hand guards my speedo and display won't activate with movement of the front wheel nor am I getting a speed reading or mileage. The display works, just no input from the wheel sensor or similar I assume. I've pulled the headlight and checked are rechecked all the connections. In fact, when I reconnect the wheel sensor the display triggers on.
    Any suggestions on where to start? Possibly a common problem w/ a fix I'm not aware of? :fingerscrossed:
  3. Jul 16, 2015 at 1:56 PM
    #1003
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I have lost 5th gear 3 times in my YZ, pretty much the only weak point that bike has. Now I am way more careful to make sure I fully engage 5th gear otherwise 1 mis-shift will cost me $350 in parts and that getting everything nearly at cost.
    I replaced the springs in the spur hub and replaced the spring with a stronger one for the internal shifting mechanism and its been good for 9 months of racing so far which is pretty good for me!
    Check continuity in the speedo exciter wires, might have in internal break that's not obvious, pretty much has to be that..
  4. Jul 16, 2015 at 4:47 PM
    #1004
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    so how many gears are you replacing? after i tore mine all apart i ended up getting all new shift forks, shift drum, oil pump, 4 gears, cam chain, shift shaft, lever, and all the gasket bs and it was well over 700 with just parts :(
    are you talking about #8 as far as the spring??
    http://www.motosport.com/dirtbike/oem-parts/yamaha/2012/yz250/shift-cam-fork
  5. Jul 17, 2015 at 1:04 PM
    #1005
    Speed Freek
    Mine is a 2 stroke. All shift forks 3rd 4th and 5th drum was fine.
    I can't open that link from my phone but it's the main single spring off the shift linkage and I get parts at cost from sponsorship.
  6. Jul 17, 2015 at 1:49 PM
    #1006
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Meh, its only a little hole :anonymous:
  7. Jul 17, 2015 at 5:21 PM
    #1007
    XCDave
    XCDave Well-Known Member
    David
    2015 TRD 4X4 long bed dbl cab
    None at this time.
    Hey guys, new to this race. I've found that having one of each is best. KTM 250xc and an 08 yz450 for the fast open sandy races in Florida. We do a lot of hare scrambles. The 250 is light and nimble hauls ass through anything. The 450 just keeps pulling no matter where. Lazy mans bike in the woods for sure. Awesome that there's a few bike threads in here.
  8. Jul 17, 2015 at 5:26 PM
    #1008
    XCDave
    David
    None at this time.
    The smoker. Still going strong at 52.
    Speed Freek likes this.
  9. Jul 17, 2015 at 5:27 PM
    #1009
    XCDave
    David
    None at this time.
  10. Aug 3, 2015 at 11:36 AM
    #1010
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Just about finished up :D
    XCDave likes this.
  11. Aug 4, 2015 at 7:27 AM
    #1011
    anarion55
    Tony
    S. Florida
    2013 PreRunner SR5
    Getting there... will it be done before the cold sets in?
  12. Aug 4, 2015 at 8:17 AM
    #1012
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Yeah I should be able to get the rear tire on before November I hope :laugh:
  13. Aug 4, 2015 at 9:23 AM
    #1013
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    mainly asking speed freak this but if any of you have experience in desert/dry rocky terrain, which tire are you liking the best? I just finished up a set of mx52s and they chuncked pretty bad after just two rides.. I was told by a buddy to check out the maxxis desert IT but no where in town stocks them.
  14. Aug 4, 2015 at 1:41 PM
    #1014
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I always had good luck with the Michelin star cross as well as the maxxis desert. Both very stiff.
  15. Aug 4, 2015 at 5:20 PM
    #1015
    Spagget13
    Spagget13 Well-Known Member
    Drew
    Lake Havasu City
    01 TRD off road ext cab
    Mcm Fabrication4x4 long travel kit, ADS coilovers, ADS bumps Deaver h70/e30 Leafs, 2.5x16 king double bypasses, straight pipe after cat, Glassworks Fiberglass front and rear.
    Maxxis Desert IT hands down. Only tire I'll ever buy.
  16. Aug 4, 2015 at 9:57 PM
    #1016
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    cool cool. im leaning towards the maxxis anyways. Thanks guys.
  17. Aug 6, 2015 at 9:44 AM
    #1017
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    If you ever make the mistake of moving to the east coast you won't be happy with the stiff tires. Dunlops and Pirelli are popular here.
  18. Aug 8, 2015 at 8:05 PM
    #1018
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Ripped around on the 500 today at the beach. Im actually debating about just keeping it for glamis and pismo... now that im getting even more confident on it, i can see why theyre the king of sand bikes. :bikewhoops::bikewheelie2:
  19. Aug 11, 2015 at 4:47 PM
    #1019
    XCDave
    David
    None at this time.
    With a paddle tire it's got to be a hoot.
  20. Aug 14, 2015 at 7:23 AM
    #1020
    anarion55
    Tony
    S. Florida
    2013 PreRunner SR5
    More power is the best medicine for sand...
