The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Nov 20, 2015 at 2:21 PM
    #261
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Sport rear lol not that much better. Going 35s and mud tires I may get alittle more rambunctious since no kid this trip
    White Horse likes this.
  2. Nov 20, 2015 at 2:21 PM
    #262
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    For reelz. Frank has no fear. I respect that about him. :thumbsup:
    White Horse and Rattletrap66 like this.
  3. Nov 20, 2015 at 2:23 PM
    #263
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    My tru trac works just fine.
  4. Nov 20, 2015 at 2:23 PM
    #264
    Taco No Baka
    Lee
    Tampa, FL
    LSD is pretty much the same as an open diff when it comes to articulation where a tire may get pulled off the ground. ;)
  5. Nov 20, 2015 at 2:25 PM
    #265
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    unless you do the ebrake mod, seems to help quite a bit
  6. Nov 20, 2015 at 2:35 PM
    #266
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Hey now I haven't broken my rear .......
    Yet
  7. Nov 20, 2015 at 2:41 PM
    #267
    Taco No Baka
    Lee
    Tampa, FL
    You're probably going to regret saying that. :eek:
    Speaking of, what did you end up doing to your front end? Never heard what the issue turned out to be.
    Rattletrap66 likes this.
  8. Nov 20, 2015 at 2:57 PM
    #268
    michaelrussell
    Michael
    belleview,FL
    Yeah probably lol and my steering rack was shot I replaced it and everything seems fine now but I have yet to get my front end realignment done since I've been working my ever living ass off so I'm stuck driving the Chevy
  9. Nov 20, 2015 at 3:40 PM
    #269
    Taco No Baka
    Lee
    Tampa, FL
    I'm sorry. That must be awful. :p
    Honestly, I can relate though. I have my new wheel bearing and seals which could technically get the OGT roadworthy again, but I'm holding off on getting my LCA bushings so I only have to take everything apart one time (and I don't have to leave the OGT on jack stands for a prolonged period of time). Consequently, I'm heading over to meet up with Spruce tomorrow morning and I'll be showing up in the Honda. :oops: :p
  10. Nov 20, 2015 at 3:52 PM
    #270
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    That's ok, I won't think any less of you. Sometimes we have to do things we don't want to. Haha :D
    Taco No Baka[QUOTED] likes this.
  11. Nov 20, 2015 at 5:44 PM
    #271
    Taco No Baka
    Lee
    Tampa, FL
    Thanks. At least I'm not rolling up in a Chevy though. Haven't fallen that far yet. :D
  12. Nov 20, 2015 at 5:54 PM
    #272
    Taco No Baka
    Lee
    Tampa, FL
    BTW, speaking of alignments...did you ever get that frozen eccentric fixed? I've been doing a lot of research on those given I'm about to pull mine apart (hopefully none of them are frozen). There seems to be a cautionary tale in there for 2nd Gen guys. If you'll haven't done so already, you 2nd Gen guys should pull yours apart and grease the crap out of them (or at least liberally coat them with anti-seize) so they don't lock up on you. Evidently Toyota put them in dry which is the reason they seize up so frequently. It might save you from having to by new eccentrics--which aren't cheap--should your LCA bushings ever go bad or if you can't get your front end aligned properly.
  13. Nov 20, 2015 at 6:10 PM
    #273
    michaelrussell
    Michael
    belleview,FL
    Yep I took care of that a couple of months ago I had to use an air hammer to get them apart and hit the new ones with a crap ton of antiseize
  14. Nov 20, 2015 at 6:19 PM
    #274
    Taco No Baka
    Lee
    Tampa, FL
    :thumbsup:
    Did you do all of them or just the seized one(s)?
  15. Nov 20, 2015 at 6:27 PM
    #275
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    @Taco No Baka im fairly certain I have at least 2 of the eccentric bolts/cams/whatever they're called from my stock suspension. If you happen to need them, they are yours.
    Taco No Baka likes this.
  16. Nov 20, 2015 at 6:37 PM
    #276
    Taco No Baka
    Lee
    Tampa, FL
    Awesome! Thanks, Todd. I'll definitely let you know if I run into any snags. I'm hoping not. Had it aligned 2 years ago and they seemed fine then. Plus, I've already soaked them down with acetone/ATF a couple weeks ago. I'll do it again the night before start taking them apart. Hopefully it'll soak in there and free everything up before I even touch it.
    allenfab[QUOTED] likes this.
  17. Nov 20, 2015 at 6:46 PM
    #277
    michaelrussell
    Michael
    belleview,FL
    I replaced them all because they were all seized
  18. Nov 20, 2015 at 6:52 PM
    #278
    Taco No Baka
    Lee
    Tampa, FL
    Ouch! :eek: Geez, seems like you've had as much trouble with your front end as I have and you aren't even 4WD. o_O
    Timbo's Customs likes this.
  19. Nov 21, 2015 at 4:17 AM
    #279
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    One of my alignment guides bent over the other day hahaha. I'm hoping with the spindles that my alignment will be like stock
  20. Nov 22, 2015 at 8:11 AM
    #280
    Timbo's Customs
    Timothy
    Lakeland FL
    You guys care if I have a buddy come with his jeep wrangler?
