The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Dec 18, 2017 at 5:57 PM
    #2781
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    :argue:
    LMarshall73 likes this.
  2. Dec 18, 2017 at 7:24 PM
    #2782
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, I pulled the trigger today on a new NAPA CV axle. I hope to gawd that it holds up a lot better than the other ones. :fingerscrossed:
    JaBoudy and TacoTRD78 like this.
  3. Dec 19, 2017 at 12:49 AM
    #2783
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Why not go chrome moly and never have to worry about it again lol
  4. Dec 19, 2017 at 9:18 AM
    #2784
    Taco No Baka
    Lee
    Tampa, FL
    If they had full chromo versions I would probably think about it, but the only ones I know about that have chromo parts are those Lotus axles Toytech sells for $500/ea and from what I understand only the birfield cages and inner races are chromo while the rest of it is just normal steel and they're not lifetime warrantied. The factory axle I popped didn't break at the brif. It exploded the stub axle and took out the lockout with it. So all else being equal, I'd rather snap the brif and only have to replace the CV than snap the stub axle and end up having to replace the axle and the hub.
    Of course, if they did have full chromo CV axles for my truck, then I'd probably end up destroying the ring and pinion or tearing the carrier in half which would be way more expensive to replace. I just want something that will hold up better than the previous axles I was using, but still fails at the brif before it pops the stub axle.
    Edit: I don't know if it means anything, but the NAPA axle looks a lot more like the factory axle than the other brand. That makes me cautiously hopeful that it will hold up better. However, time will tell. :fingerscrossed:
    Timbo's Customs and LMarshall73 like this.
  5. Dec 19, 2017 at 9:46 AM
    #2785
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Whenever the weakest link is the cheapest and easiest part to replace, you know the engineers designed it right.
    Taco No Baka[QUOTED] likes this.
  6. Dec 19, 2017 at 10:05 AM
    #2786
    Taco No Baka
    Lee
    Tampa, FL
    If I was going to design one, I think I'd make the birfield cup/stub axle, birfield cage and inner race, and the inner cup/axle out of chromo. The half shaft would remain steel with maybe a failure point machined into it so it breaks clean and a PVC sleeve over it so when it does fail it would still hold the broken ends in alignment so you could get to somewhere to replace it without beating the crap out of your suspension with the broken ends flopping around. I'm not an engineer, but it seems like that would be an ideal setup so all you'd have to replace is the halfshaft if it failed while protecting the more expensive parts.
    LMarshall73[QUOTED] likes this.
  7. Dec 19, 2017 at 12:53 PM
    #2787
    drewyota
    drewyota Member
    3” Lift ARB OME Front Bilstein 5100 Coilovers Rear ARB OME Full Leafs Fox Shocks FJ Cruiser Tcase 4.56 Gears Hypertech Powerstop Drilled Rotors 17” KMC Enduro 315/70/17 Nito Terra Graplers
    Have a wedding to me at on the 27th. If anyone is going out for a ride on Sunday would like to join. 4wd possibly two 4wds
  8. Dec 20, 2017 at 1:05 PM
    #2788
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    well....im hoping this goes well with this setup lol. also got a winch damper, one of the last few things i needed for recovery gear
    5 Lug Fury and LMarshall73 like this.
  9. Dec 20, 2017 at 1:16 PM
    #2789
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I've been eyeballing the little Baofeng units pretty hard. Today I started scouting out locations for upcoming HAM license exams. I found a few relatively close in January. Already downloaded a study guide app to start taking practice tests. I've had the HAM Radio for Dummies book since 2012 or so. Maybe I should finish reading it.
    Blackout Z7 and Alfuh like this.
  10. Dec 20, 2017 at 1:18 PM
    #2790
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    It seems like a alot of people recently are going to get there HAM liscense. I think im going to start looking into it also.
    Blackout Z7, 5 Lug Fury and Alfuh like this.
  11. Dec 20, 2017 at 1:18 PM
    #2791
    Alfuh
    2006 Prerunner
    I have a few mods
    nice, yeah I need to get one as well, just havent really done anything lol. Its funny though....on the BTECH box it has Baofengs website hahaha
  12. Dec 20, 2017 at 1:18 PM
    #2792
    Alfuh
    2006 Prerunner
    I have a few mods
    HAM is so much better than CB
  13. Dec 20, 2017 at 1:21 PM
    #2793
    TacoTRD78
    Stuart,fl
    Where do I start I don't know a single thing about it.
  14. Dec 20, 2017 at 1:23 PM
    #2794
    Alfuh
    2006 Prerunner
    I have a few mods
    find a HAM radio license study guide and look over that. Once you feel confident with that, find a local area that administers the test, they only do in person tests. once you do that and pass it, you get your license and can use a HAM radio
  15. Dec 20, 2017 at 1:29 PM
    #2795
    TacoTRD78
    Stuart,fl
    Thanks Chris
    Alfuh[QUOTED] likes this.
  16. Dec 20, 2017 at 1:33 PM
    #2796
    Alfuh
    2006 Prerunner
    I have a few mods
    no problem! I dont remember if the license costs anything, I think it does, but no more than $20....I think.....
  17. Dec 20, 2017 at 1:34 PM
    #2797
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I've watched a few of this guys videos. He isn't a HAM snob and is promoting getting more people involved and licensed.
    Also, THIS LINK has information about licensing, classes, and exams.
  18. Dec 20, 2017 at 1:37 PM
    #2798
    TacoTRD78
    Stuart,fl
    thanks guys
  19. Dec 20, 2017 at 1:44 PM
    #2799
    TacoTRD78
    Stuart,fl
    Alfuh and LMarshall73 like this.
  20. Dec 20, 2017 at 1:51 PM
    #2800
    Alfuh
    2006 Prerunner
    I have a few mods
    yeah I need to get mine before Citrus
    TacoTRD78[QUOTED] likes this.
