The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Feb 1, 2019 at 7:41 AM
    #3501
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Balls of fury dude :headbang:
    I’ll bebhitting the trails. But not exactly sending it hahaha
  2. Feb 1, 2019 at 7:47 AM
    #3502
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    We don’t haul ass down the trails anymore.
  3. Feb 1, 2019 at 7:48 AM
    #3503
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Makes sense. Either way I'm excited to finally be able to go.
    TacoTRD78 and Trident904[QUOTED] like this.
  4. Feb 1, 2019 at 7:56 AM
    #3504
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Rgr that. Reckon I'd still go farther than you with the T4R on worn down 32s and open diffs? :D Honestly, depending on how well the traction control works, you probably could go places I couldn't.
    Yeah, but some people think the 30 mph speed limit is way too fast. I'd probably seem that way to me too unless I get the new suspension on the T4R before the meet...which shouldn't be hard actually.
  5. Feb 1, 2019 at 2:09 PM
    #3505
    dnpbakon
    Kevin
    Alright fellas what do you guys use for comms on the trails? Cb? Gmrs? FRS Walkies? And if so any licenses needed?
  6. Feb 1, 2019 at 2:37 PM
    #3506
    Taco No Baka
    Lee
    Tampa, FL
    Usually CBs, but I may not have comms if I bring the T4R.
  7. Feb 1, 2019 at 2:42 PM
    #3507
    dnpbakon
    Kevin
    Does cb need a license?
  8. Feb 1, 2019 at 2:48 PM
    #3508
    Taco No Baka
    Lee
    Tampa, FL
    Negative. Just a radio, a mic, and an antenna. :thumbsup:
    dnpbakon[QUOTED] likes this.
  9. Feb 1, 2019 at 2:57 PM
    #3509
    dnpbakon
    Kevin
    Right on. I may order one this week. My buddy is recommending a gmsr radio but I don’t feel like paying for a license
  10. Feb 1, 2019 at 10:33 PM
    #3510
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    CB does fine for all the meets I've been to for the last 4 and a half years through 4 different states. I thought about upgrading to have both but havent found the need yet.
    dnpbakon and Taco No Baka like this.
  11. Feb 2, 2019 at 4:32 AM
    #3511
    dnpbakon
    Kevin
    Any recommendation on a cheap setup? Ever had one before so not sure what to look for
  12. Feb 2, 2019 at 7:55 AM
    #3512
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Midland 75-822 can be run handeld or with cig lighter and portable whip antenna if you want a quick solution. I use the Cobra 75 WX ST, with the main box under my center console.
  13. Feb 2, 2019 at 7:57 AM
    #3513
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I have extra space available in spot 3. My buddy canceled. So I'll probably just bring the small tent, unless whoever wants or needs to share a larger tent. Then I could bring my Cabin tent.
  14. Feb 2, 2019 at 10:28 AM
    #3514
    mosquitoTaco
    Anthony
    SouthTennessee
    This was actually my first CB. I wanted a quick set up and just ran a coax through my back window and mounted an antenna in my bed. I left the CV in the glove box and the coax just laying under my bed mat when not in use that set up actually did really well. After a while I went to a more permanent solution a couple years ago and got the uniden pro520xl since is was compact enough to mount in my center consale while leaving storage space. No complaints on this unit for the price
    TacoTRD78 and dnpbakon[QUOTED] like this.
  15. Feb 2, 2019 at 11:45 AM
    #3515
    02tacotoy
    02tacotoy Active Member
    Hey guys- New to the group but been to citrus many times in my 02 TRD w TTORA. Now I have a stock 3rd gen and want to bring it out. I'll also have my friend in a 4R joining at my site.
    @Taco No Baka I Booked Site 16- 2 trucks
  16. Feb 2, 2019 at 7:05 PM
    #3516
    Taco No Baka
    Lee
    Tampa, FL
    Welcome to TacomaWorld! :wave:
    Are you sure you booked the right weekend? Last time I checked it said the site wasn't available, probably due to construction. It's possible that could have changed, but just double check for me that you booked on February 8th-10th. Thanks.
  17. Feb 3, 2019 at 8:04 AM
    #3517
    02tacotoy
    Yup - I doubled checked- Thanks
  18. Feb 4, 2019 at 10:21 AM
    #3518
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    Totally forgot about camping with friends this weekend. I'll be down in the Hog Island Campground.
    Had it marked on my calendar for camping. Thought it was just me trying to make time to go camping in general.
    Doubt I'll be able to stop by as the wife will be with me. Shame i stumbled on this thread so late.
    mosquitoTaco likes this.
  19. Feb 4, 2019 at 7:06 PM
    #3519
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    It's my wife's birthday this weekend or I would be there. Next year hopefully...in the meantime I'll live vicariously through everyone's photos.
  20. Feb 4, 2019 at 8:31 PM
    #3520
    Taco No Baka
    Lee
    Tampa, FL
    This week is going to be nuts for me. Have to get a set of wheel spacers tomorrow, hopefully earlier than later. Still have to install the diff drop and get Natty aligned. Then I have appointments I have to be at Wednesday and Thursday. The OGT is going to have to get me to Wednesday's appointment, but I'm really hoping Natty gets me to Thursday's or I'm screwed. I'll have to pull a Dom, show up in a 3rd Gen T4R on Saturday and sleep in the vehicle. On the plus side, at least that should be more comfortable than it was when I tried it with the OGT.
