The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Feb 11, 2019 at 6:46 AM
    #3601
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Only got a few photos. Wish I had my dashcam remounted in time.
    Scooter WCT and TacoTRD78 like this.
  2. Feb 11, 2019 at 8:17 AM
    #3602
    Mistaman
    Mistaman New Member
    Alex
    1998 ext. cab 2.4l 5 lugger
    3” fabtech spindle lift, 2” rear shackles, 3” body lift
    Had a blast this weekend with all of you guys. It was really nice meeting up with a group, let alone one tat would hang around and help me fix a snapped lower ball joint haha much appreciated guys :cheers:
    Definitely a memorable first trip.
    I guess if someone had to do it it might as well be me :woot:
    Anyway, here's a few photos of the break and fix. Ill get one of the part up later.unnamed.jpg IMG_2278.jpg IMG_2280.jpg IMG_2276.jpg
    And finally back at camp in one piece
  3. Feb 11, 2019 at 11:06 AM
    #3603
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    VSC to me is Vehicle Stability Control and I didn't think cars came w/ that way back then. So I'm clueless on this one. I started here at Toyota back in 2010 and Vehicle Stability Control was just becoming standard (Star Safety System) on all Toyotas.
  4. Feb 11, 2019 at 3:08 PM
    #3604
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Can’t wait to see some more photos of the event. I know someone has a few of me crawling!
    Rattletrap66 likes this.
  5. Feb 11, 2019 at 4:02 PM
    #3605
    taco_feevuh
    taco_feevuh SUUUUUUUUUUUUP?!
    Merritt Island, FL
    2018 cement Tacoma TRD OR 4x4 DCSB
    Rci sliders, Trd pro grill, Fox 2.5 fronts, Fox 2.0 rears w/resi, SCS Ray 10’s, Cooper stt pros
    Been lurking on TW for a minute. When is the next time ya’ll are doing this again? I’d like to check it out after I acquire a little more gear
  6. Feb 11, 2019 at 4:02 PM
    #3606
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    My phone ended up putting all the videos together as one. Here's the main Washout on TR14. @Taco No Baka your at ~30secs in.
    @allenfab Here you climbing the wall on the north part of 2?
  7. Feb 11, 2019 at 4:08 PM
    #3607
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  8. Feb 11, 2019 at 6:20 PM
    #3608
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Ayup, every time my Evap system burps (usually on a full tank of gas going over a rough spot in the road) and kicks a code the VSC and Trac Off lights come on with the check engine light. Think it was just the '01s and '02s that had it though since they were the only ones with the center diff. I imagine it was pretty common on 4th gens.
    Now if i could only get the OGT to flex like that rear AND front...:cool:
    GuyHuey and TacoTRD78[QUOTED] like this.
  9. Feb 11, 2019 at 6:45 PM
    #3609
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    Looks good! Was Citrus more fun in a less capable vehicle or did you miss the OGT?
    Taco No Baka[QUOTED] likes this.
  10. Feb 11, 2019 at 7:09 PM
    #3610
    Taco No Baka
    Lee
    Tampa, FL
    I'm going to have to say it was more fun for the most part, but I was a lot more twitchy about the pin striping and paint damage the antenna was causing. Plus, I avoided the mud holes so Natty didn't seem significantly less capable although the first washout on trail 14, the Crack, was more challenging in a fun way. I had to use AWD and finesse it to climb up out on the line I took, so yeah that was more fun.
    TacoTRD78 and GuyHuey[QUOTED] like this.
  11. Feb 12, 2019 at 3:13 PM
    #3611
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    anyone get any pictures or photos of my truck? I once again was going to take MORE photos...and I didnt even get any of my truck lmao
    dnpbakon likes this.
  12. Feb 12, 2019 at 3:33 PM
    #3612
    dnpbakon
    Kevin
    I had one or two brother I’ll check now! I know someone got some of my truck crawling a bit but don’t remember who
  13. Feb 12, 2019 at 3:34 PM
    #3613
    Stormtrooper_08
    Stormtrooper_08 If two wrongs dont make a right, try three
    Orlando, FL
    White '08 TRD Sport Prerunner SR5
    4" Maxtrac spindle lift, adjustable bilsteins up front set at 1.75", 2" blocks and pro comp aals in the rear. 33" Cooper STT Pros.
    Where’s the photos of my truck? Lol
  14. Feb 12, 2019 at 3:35 PM
    #3614
    Alfuh
    2006 Prerunner
    I have a few mods
    lmao, man I hardly took any haha, I was supposed to hook up my gopro too....but I had NO idea where the hell my batteries went lol
  15. Feb 12, 2019 at 3:53 PM
    #3615
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :spy: in for pics of my truck :rofl:
    Alfuh and TacoTRD78 like this.
  16. Feb 12, 2019 at 4:36 PM
    #3616
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm just going to laugh if I got stuck for a solid 10 mins and no one took a photo.......which means did I get stuck? :spy:
  17. Feb 19, 2019 at 7:49 AM
    #3617
    DarkMark340
    DarkMark340 @TRDLess_Taco
    Mark
    Jacksonville
    2011 Black 4x4 Tacoma DCSB Base
    SUSPENSION: 3” Factory/Toytec Lift Blackout14 Custom Leaf Pack 5+1 HD Bilstein 5100 B100 Shocks Wheelers Off-Road U bolt Flip kit w/ Timbren Bump stops BAMF HD Rear Shackle Hangers ARMOR: SOS Off-road Concepts Sliders SOS Off-road Concepts High Clearance Rear Bumper Pelfreybilt Front Bumper Full Hoop GEAR: Smittybilt X20 10K Synthetic Line Winch Leer 100XQ Prinsu CABRAC & TOPRAC Simple Outdoors Skyloft Hardshell RTT Pope Overland Expedition 72” Awning 18x9 VTX Off-road Bronze Terra CaliRaised LED Lights FUTURE PURCHASES: SOS Off-road Concepts Full Skid Plates Relentless Fabrication Tailgate Reinforcement ARB Twin Compressor w/ Locker
    Hey guys, unfortunately I missed this past trip. Pretty new to FL and planning to hit citrus in early March are there trail maps available or have any recommended trails for guys fairly new to the scene. Pics looked like everything was pretty moderate as long as you picked good lines.
    TacoTRD78 likes this.
  18. Feb 19, 2019 at 7:54 AM
    #3618
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    google maps works. save the area before you go in case signal is an issue. Trails are easy to navigate since everything runs either north/south or east/west pretty much. Trail 19 is the most rugged but there are bypasses for everything so if you want to check it out (I'd run it from Trail 8 north up to 2). Trail 14 east of 13 is a good one as well
  19. Dec 5, 2019 at 8:27 AM
    #3619
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
  20. Dec 5, 2019 at 8:33 AM
    #3620
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Fingers crossed I can make this one. I’ve missed the past 2 or 3 big meets. Hopefully work schedule will cooperate this time.
    Timbo's Customs likes this.
