The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Jan 15, 2016 at 8:53 AM
    #641
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Maybe I'm just used to richloam, we always had cell service or were very close to it. I'll just need to get Lee to help me tune my antenna before we leave
    Rattletrap66[QUOTED] likes this.
  2. Jan 15, 2016 at 8:53 AM
    #642
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    same lol
    I might just get that NW Cobra if it really only is like $15 more lol
  3. Jan 15, 2016 at 8:56 AM
    #643
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    My thinking is, if it's a solid radio like like the 25LTD, then the large illuminated display would probably sate my need to see it better at night and the additional diagnostic features would probably be useful as well.
  4. Jan 15, 2016 at 8:58 AM
    #644
    Taco No Baka
    Lee
    Tampa, FL
    The regular 25LTD was $89.95 while the 25 NW LTD is $106.95 (okay so it's a $17 difference).
  5. Jan 15, 2016 at 9:14 AM
    #645
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    @Alfuh you can save a little bit of money if you go with the firefly antenna, IIRC I got mine for around $25. It was under 30 anyway. Haha
    My cheap Realistic works just fine, no bell & whistles but i dont use it every day. Frank & I were just talking about how well mine does just yesterday. Maybe it's your antenna setup, just a thought.
    Rattletrap66 likes this.
  6. Jan 15, 2016 at 9:23 AM
    #646
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    definitely more along the lines of the antenna and coax and not the radio itself
  7. Jan 15, 2016 at 9:29 AM
    #647
    Taco No Baka
    Lee
    Tampa, FL
    QFT. You're antenna setup is definitely the most critical component of being able to get out there. The radio is more about durability. Even the best are only going to xmit 4 watts (unless you've had it peaked and tuned, and then you can get ~5 watts out of them. Both of my 25s have been peaked and tuned ;), but I don't know where to have it done anymore). Everything else is just how much of a beating they can take off-road and the whether the aesthetics of a given unit appeal to you.
  8. Jan 15, 2016 at 9:32 AM
    #648
    Alfuh
    2006 Prerunner
    I have a few mods
    lol, I could just ditch the 25 then and keep the radio shack one. I was just wanting to replace it with something "better" I guess
  9. Jan 15, 2016 at 9:33 AM
    #649
    1stgen
    18 SR5
    Got my cobra from Walmart.
  10. Jan 15, 2016 at 9:33 AM
    #650
    Taco No Baka
    Lee
    Tampa, FL
    I don't think you'd make a wrong choice if you went ahead with the 25. You'll need one for the Hilux anyway. :thumbsup:
  11. Jan 15, 2016 at 9:35 AM
    #651
    Alfuh
    2006 Prerunner
    I have a few mods
    that is very true haha
    Taco No Baka[QUOTED] likes this.
  12. Jan 15, 2016 at 10:13 AM
    #652
    Alfuh
    2006 Prerunner
    I have a few mods
    Well just made the purchase for the new CB stuff. Time to get rid of the crappy setup I have now! @Rattletrap66 I'll finally be able to talk to you hahaha
    Taco No Baka and Rattletrap66 like this.
  13. Jan 15, 2016 at 12:06 PM
    #653
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
    Damn, I got my CB at a garage sale for 5 bucks. I think it works just fine, but I do need to tune it to make sure.
  14. Jan 15, 2016 at 12:10 PM
    #654
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    what cb radio were you using before?
  15. Jan 15, 2016 at 12:13 PM
    #655
    Alfuh
    2006 Prerunner
    I have a few mods
    radio shack 40 channel mini cb....I mean...it works...but I just want something thats nicer and better. I only got that because I wanted one and was tight on cash at the time for getting ready for the citrus meet the 1st time. and of course I had no prior knowledge of CBs and setups. So now Ive got a Cobra 25 and a 5 foot FireStik II with a spring thingy
  16. Jan 15, 2016 at 12:15 PM
    #656
    nammer
    Nam
    Bradenton, Florida
    just bring your old cb to citrus, i'll put it to good use for you :)
    White Horse likes this.
  17. Jan 15, 2016 at 12:19 PM
    #657
    Alfuh
    2006 Prerunner
    I have a few mods
    lol, hey now, my little pickup needs a CB lol. Ill have to get another coax cable and antenna for it though. There might be something wrong with the radio shack coax cable and the antenna I got off a buddy for free.
  18. Jan 15, 2016 at 12:27 PM
    #658
    nammer
    Nam
    Bradenton, Florida
    fine....................:pout:
  19. Jan 15, 2016 at 1:16 PM
    #659
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
  20. Jan 15, 2016 at 1:24 PM
    #660
    trdagule
    trdagule Well-Known Member
    David
    naples FL
    07 tacoma 4x4 speedway blue
    I'm coming with 10-11 more vehicles that you can add to the list 2 of then are on TW but they haven't sing up
    It will be
    3 Tacoma
    1 4Runner
    4 Fj80
    1 maybe 2 Fj70
    1 Hj62
    Taco No Baka, Rattletrap66 and 1stgen like this.
