The 2021 Toyota Hilux is impressive, makes the Tacoma look like a Camry. :(
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4wdExplorer, Nov 6, 2020.
  1. Nov 7, 2020 at 5:21 AM
    #141
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    not impressed..I would still stay in my Tacoma if they brought that ugly ass thing here in the states .
    hiPSI and RedWings44 like this.
  2. Nov 7, 2020 at 5:23 AM
    #142
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not necessarily. But the difference is you could use steel wool to remove surface rust!
    hiPSI and Stocklocker[QUOTED] like this.
  3. Nov 7, 2020 at 5:26 AM
    #143
    RedWings44
    Michigan
    Depends on the 10 miles. 10 miles on a mountain bike? Definitely. 10 miles on a road bike/gravel bike? Maybe, depending on how hilly the terrain is.
  4. Nov 7, 2020 at 5:27 AM
    #144
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Honda will probably offer a hybrid Ridgeline and they will sell.
  5. Nov 7, 2020 at 5:28 AM
    #145
    RedWings44
    Michigan
    Basically, manufacturers don't want to invest money into developing their engines to meet EPA standards here, particularly when it comes to diesel. Diesel isn't as popular in the US, so the cost of development may not be worth it.
    shakerhood likes this.
  6. Nov 7, 2020 at 7:21 AM
    #146
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol depending on design, a hybrid can actually have less parts, not "more things to break."
  7. Nov 7, 2020 at 7:39 AM
    #147
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    By the time they went thru all that along with certifications it would push the cost of a Tacoma to 50K.
    RedWings44[QUOTED] likes this.
  8. Nov 7, 2020 at 7:41 AM
    #148
    RedWings44
    Michigan
    Yep. The Colorado charges a premium for it, but they also developed it from Thailand and basically cornered the market for it at first, so the cost for development was worth it for them. I'd drive a diesel if they can be proven to be reliable. But that whole DEF system has me skeptical.
  9. Nov 7, 2020 at 7:47 AM
    #149
    shakerhood
    Southern Ohio
    I wouldn't trust it either, can't imagine they sell too well.
  10. Nov 7, 2020 at 7:56 AM
    #150
    RedWings44
    Michigan
    They sell pretty good. The only consistent issue I've heard is the DEF system. But even that is pretty good as long as you don't let the truck sit for extended periods of time without running it. Basically the DEF fluid crystalizes and clogs up the injector, which then sends you into limp mode until you get it fixed. All of which is mandated by the EPA.
    shakerhood[QUOTED] likes this.
  11. Nov 7, 2020 at 8:53 AM
    #151
    shakerhood
    Southern Ohio
    l read that GM was doing away with the Diesel Colorado for the next Generation, would assume they probably just don't sell enough to justify it. Don't think you would ever see a diesel Tacoma, the price would be too high and the sales would be minimal.
  12. Nov 7, 2020 at 8:58 AM
    #152
    RedWings44
    Michigan
    My understanding is they are doing away with the 2.8L and bringing the 3.0L from the Silverado. But that's all rumor.
    You can do a diesel conversion, but those are expensive. People that do them love them, but also don't have to deal with the DEF system. I'd love to see more diesels here. I'm sure Toyota will change their minds at some point. After all, Jeep now has a diesel as well.
  13. Nov 7, 2020 at 9:17 AM
    #153
    shakerhood
    Southern Ohio
    Maybe you are right but dont think it makes sense in a Tacoma, guessing you would see a hybrid Tacoma instead of a diesel.
  14. Nov 7, 2020 at 9:19 AM
    #154
    RedWings44
    Michigan
    I fully expect that before a diesel.
  15. Nov 7, 2020 at 9:34 AM
    #155
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The should do a diesel-hybrid.
    Then you could roll coal and save the planet. It’s a win/win
  16. Nov 7, 2020 at 9:37 AM
    #156
    RedWings44
    Michigan
    Lol, that would be intense.
    I will say, though, I changed my mind about hybrids after actually trying one. Yes, the 1.8L engine was weak, but I got 47 MPG consistently (3 fill-ups) so I was able to look past that pretty easily.
  17. Nov 7, 2020 at 9:39 AM
    #157
    Stocklocker
    17TRDORDCSBAT
    In all honesty, a diesel hybrid would give you incredible range of it a had a decent size tank.
  18. Nov 7, 2020 at 12:56 PM
    #158
    awesomeandy013
    awesomeandy013 Well-Known Member
    Andrew
    Pittsburgh, PA
    '17 MGM DCLB TRD OR, '16 TRD Pro 4RNR QS (wife)
    265/75R16 Wildpeak AT3W, Softopper, Kicker speakers, shift knob, Ventvisors, Tint, Husky Weatherbeaters, Hondo Garage radio knobs. The to do list: Bilstein 6112/5160, 3 leaf add-a-leafs, lights, alu skid, PRP seat covers...
    Obviously everything can be damaged if determined enough. Everything. Look at the location of the damage. It looks like somebody had their rental Tacoma, was building a fence of something with the tailgate down and lumber laying flat, moved the truck, when being reversed a piece of lumber hit a wall or something and the tip of the board punched through the wheel well. The wheel well is thinner than the floor of the bed, its not really meant for load bearing or taking hits on the vertical surface. That would have completely ripped through a steel wheel well without a doubt. First think I look at on used trucks is to see if the wheel wells are dented/damaged. Just for comparison, I've stood on the wheel wells when loading a Silverado at work and it dented when I stepped up on it (about 210lbs). I could jump up and down on the top o our wheel wells. I'm still not convinced that steel is better. :notsure:
  19. Nov 7, 2020 at 1:02 PM
    #159
    RedWings44
    Michigan
    Yeah, there was no doubt in my mind that it had to be some sort of impact. And I agree, at minimum that would have probably dented a steel wheel well. But, as I said, this is the first damage I've ever seen to one of these beds.
  20. Nov 7, 2020 at 2:34 PM
    #160
    DrMark
    DrMark Diet Mtn Dew & Guns
    Alabama
    2011 Tacoma PreRunner DoubleCab
    I'm glad that standard wasn't applied to me and my citizenship.
    CrazyAirborne likes this.
