The 4.0 Dipstick is a piece of shit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Nov 1, 2009.
  1. Nov 1, 2009 at 1:04 PM
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Has anyone else noticed this? Impossible to get a clean reading on these sonsabitches!
    Checked the stick today as part of routine maitenance and it appeared on one side to be about .5" past the full mark...the other side was streaked all to hell. 4 attempted rechecks yielded the same result.
    Let about half a quart out to be safe....last oil change, put in 5.5 quarts....truck never had any problems, but I like to be on the safe side.
    These dipsticks suck.
  2. Nov 1, 2009 at 1:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most dipsticks DO suck. The little hash marks on them are horrible. I roughed mine up good with some sand paper, and it seems to work a little better.
  3. Nov 1, 2009 at 1:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    (thick irish accent) "Start thinkin with your dip stick jimmy!!!"
  4. Nov 1, 2009 at 1:13 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    I may have to try that...
    I agree, with the bend required to get the dipstick back into the oil it's damn near impossible to get a good read. If I don't get a clean pull on the first try I just check it again later because I know I've already smeared oil all along the inside of the guide.
  5. Nov 1, 2009 at 1:32 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Yup, it does suck! I only check mine in the morning and go by the first pull. It's very readable at that point, but even if you stick it back in for another reading it's streaked so much it's pretty tough.
  6. Nov 1, 2009 at 1:40 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I did the same thing as chris4x4 with my dremel and it helped a lot.
  7. Nov 1, 2009 at 1:41 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    Just let your oil get real dirty and it's easier to read! I wonder if bead blasting the end would help? Most new cars are a PITA.
  8. Nov 1, 2009 at 1:46 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    That's what she said.
  9. Nov 1, 2009 at 1:47 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    :laugh: oh yeah giggity giggity :D
  10. Nov 1, 2009 at 1:48 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Thank god, i thought i was the only one that hated that dipstick.
  11. Nov 1, 2009 at 1:55 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    5.5 quarts with filter should do it. I also etched mine with sandpaper and made like an "x" pattern at 45 degree angles to each other...seemed to help. I use the reading on the side of the stick that isn't smeared. 5.5 quarts usually shows up right at the top fill line.
  12. Nov 1, 2009 at 2:56 PM
    jandrews
    Just to be sure, changed her out with a fresh load of EXACTLY 5.5Qts of Purple Jesus.
    Drove her for about 30 minutes, drained the oil and filter hot, and then did the change. Did NOT preload the filter. Seems to have come up almost exactly on the full line.
    Anyone else notice royal purple becomes clear after you've run it in your engine for only a few minutes? Must be heat-degrading purple dye they use or something.
  13. Nov 1, 2009 at 5:25 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    The 2.7 dipstick isn't any better.
  14. Nov 1, 2009 at 6:51 PM
    sdnicker2000
    sdnicker2000 Well-Known Member
    Nebraska
    Mostly Stock 08 TRD Sport
    Rear spring TSB, Fumoto Valve, No A/C on defrost mod., tailgate theft mod.
    At least we have a dipstick (but it does suck). Some newer cars such as BMW's I hear don't even have one. CRAZY!!!
  15. Nov 1, 2009 at 6:55 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Will this count as a mod, dip-stick mod?
  16. Nov 1, 2009 at 7:19 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Good idea but I would think that you would have drilled small holes in 1/4 qt increments and attached a viscosity funnel on the end! ;)
  17. Nov 1, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I actually thought of that (sans visco funnel), but my buddy broke both my smallest drill bits. :(
  18. Nov 1, 2009 at 7:38 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I know the manual says 5.5 qts. and I tried that with my first change, but it was 1/2 qt high. I have been putting 5 qts in ever since, always on the money. Dipstick is a PITA btw
  19. Nov 1, 2009 at 7:38 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Yes
  20. Nov 1, 2009 at 9:00 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I'm pretty consistent at exactly 5 quarts a change.
    Anyone tried knurling the end of the dipshit. (I typed dipshit on accident but I decided to leave it for a laugh).
