The 4.56 w E-locker inquiry thread.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Sep 21, 2020.
  1. Sep 21, 2020 at 7:25 AM
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    I like the way my truck drives now on 31’s and factory gears. I don’t want it to be geared lower, but am thinking of going up a size in tires to 275/70/17 (32”) when my tires wear out. I am not sure I want to go right to 4.88.
    Is there any options for 4.56 out there for the larger (8.75”?) TRD Offroad e-locker diff?
    I recall reading somewhere that there is a gear set for the Landcruiser that is the same, but not sure. Just wondering. Any info appreciated.
    Skydvrr likes this.
  2. Sep 21, 2020 at 8:28 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Toyota offers 4.56 on 8.75" in the Hilux. You can buy the gears, or the whole chunk.
  3. Sep 21, 2020 at 10:32 AM
    Stocklocker
    17TRDORDCSBAT
    Are they available in North America?
  4. Sep 21, 2020 at 10:49 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I would think 4.30s would be bring you closer to factory and save you some RPMs on the highways. https://www.extremeterrain.com/nitr...ing-pinion-430-gear-ratio-gptaco2016-430.html
    https://www.extremeterrain.com/nitr...ing-pinion-456-gear-ratio-gptaco2016-456.html
    edit: my bad, they aren’t the right size. Not for elocker. Sucks.
  5. Sep 21, 2020 at 10:54 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Just get the 4.30 from a 3rd gen manual transmission
    2000prerunner23 and Dirk Diggler like this.
  6. Sep 21, 2020 at 10:56 AM
    Jowett
    Brian
    North Adams, MA
    Relatively easy to order from overseas. I've dealt with all of the following companies Partsouq.com Carmarka.com Amayama.com en.impex-jp.com . Shop around, some have the parts, some don't, prices can vary widely... Partsouq ships the quickest, but they tend to be on the higher side.
    Rear chunk w/ diff lock 41110-0K660
    Rear gears 41201-09C10
    Front gears 41201-09C90
  7. Sep 21, 2020 at 11:03 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    You doing the labor yourself ? I'd do the plug and play calc and see if a 4.30 can get you where you wanna be from a junk yard somewhere in the US that can ship it. Or pick a pull or whatever near
    Stocklocker[OP] likes this.
  8. Sep 21, 2020 at 11:09 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd go with the 4.88 (maybe even 5.29) right of the bat. A gear swap is expensive and not something you'd want to do twice. It's probably a couple 100 RPM difference at highway speeds. You see complaints all the time about not enough gear but rarely too much.
    Old saying from my N/A Cobra days was don't fear the gear.
    4.88 at 75 with 32s = about 2230 RPMs. That's lower than a stock manual with 32 at about 2400. Unless I did the math wrong?
    https://www.justdifferentials.com/Articles.asp?ID=251
  9. Sep 21, 2020 at 12:33 PM
    Stocklocker
    17TRDORDCSBAT
    Thank you for the suggestions and reply’s everyone. I appreciate it.
  10. Sep 21, 2020 at 12:43 PM
    4x4spiegel
    4x4spiegel Well-Known Member
  11. Sep 21, 2020 at 12:51 PM
    Jowett
    Brian
    North Adams, MA
    Also, if you choose 4.56, some of the 5th gen 4-Runner w/ 4 cylinder came w/ 4.56. Might be able to use the front diff.
  12. Sep 21, 2020 at 1:27 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    4.88s with 32’s or 33’s is overgeared if you are going to be driving it on the highway. I was at around 2700 rpms at 70 mph if I believe. If you keep it around 60 you’ll be fine. I think 4.56 would be perfect for 33s.
    But... you have a third gen so it’s much different. I haven’t heard anyone complain when regearing to 4.88 or 5.13 with a third gen
    Stocklocker[OP] and dfanonymous like this.
  13. Sep 21, 2020 at 1:39 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Also remember, difference between 4.56 and 4.88 at 70mph will probably be close to 150rpm. bet you wouldn't even tell the difference between the two. Not worth all the hassle of trying to find 4.56 when 4.88s are so readily available.
  14. Sep 21, 2020 at 5:04 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Geez these 2nd geners commenting on 3rd gens.. 33" tire on 4.88@70 mph is 2000 rpms... The difference between 4.56 and 4.88 at highway speed is 130rpm
    Brucey and whatstcp like this.
  15. Sep 21, 2020 at 8:38 PM
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    Well... someone tagged me to comment so I did. That’s why I made a comment that it’s much different with 3rd gens obviously
  16. Sep 21, 2020 at 9:54 PM
    JoeCOVA
    Joe
    Colorado Springs
    Should lead with that.
  17. Sep 21, 2020 at 10:10 PM
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    Or just read the whole post
  18. Sep 22, 2020 at 6:18 AM
    JoeCOVA
    Joe
    Colorado Springs
    Meh I did, basically it was “here’s my opinion blah blah, oh by the way it’s completely irrelevant because I have a 2nd Gen,” when it could have read “I have a 2nd Gen so I can’t add much to this topic.”
    LOL
  19. Sep 22, 2020 at 6:35 AM
    Gruber1922
    Tacoma, WA
    2015 Tacoma Sport
    I’m truly sorry I wasted 3.5 whole seconds of your day. Oh please accept my apology...
    To be fair, I didn’t even see it was third gen until after, and then I edited my post. But I decided to keep that info in case a second gen owner viewed the thread.
    Also, who gives a shit. Maybe just ignore my comment then, and provide your insight.
    You must be fun at parties.
    blah blah
  20. Sep 22, 2020 at 7:43 AM
    JoeCOVA
    Joe
    Colorado Springs
    LOL
