The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Jan 4, 2020 at 9:45 PM
    #1981
    TWTaco
    TWTaco Well-Known Member
    Dave
    TWIN TURBOS :drool::drool::drool::drool: Cant wait !
  2. Jan 5, 2020 at 12:22 AM
    #1982
    PolarBearX
    PolarBearX Well-Known Member
    Willamette Valley
    2016 White Tacoma Limited
    Just received my Nitro gears and ARB locker. Now for some fun!
    Ol'gray mare likes this.
  3. Jan 5, 2020 at 11:24 AM
    #1983
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Old diffs out, waiting on fed ex to put 5.29’s in from ecgs.
    Ps fed ex sucks.
    RyanDCLB, Glenn_R and Pablo8 like this.
  4. Jan 5, 2020 at 11:54 AM
    #1984
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Any lessons learned on front clamshell removal? About how long did it take?
    Glenn
  5. Jan 5, 2020 at 12:12 PM
    #1985
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Twin turbos?
  6. Jan 5, 2020 at 12:18 PM
    #1986
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    H3llRid3r[QUOTED] likes this.
  7. Jan 5, 2020 at 12:24 PM
    #1987
    H3llRid3r
    SLcUT
    Pablo8[QUOTED] likes this.
  8. Jan 5, 2020 at 12:30 PM
    #1988
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    with a helper I found it easy to leave the cv’s attached to the spindles and just remove sway bar links lower ball joint bolts and seperate the tie rod ends. Was able to get it out of the way enough and rest them on a jack stand on one of the lower ball joint bolts screwed back in and plenty of room to remove the cv’s since I couldn’t get the little nut cover off without damaging it and my wheels don’t run a center cap so they’re pretty visible.
    What ended up popping the cv’s free was a large flat head and hammer while my dad applied pressure with a pry bar. We had a little bit of a fight. Slide hammer wouldn’t do it nor the hammer method without the pry bar.
    Instead of removing the plug bracket we left it in place and just removed all wiring. We also removed the little bracket that’s held on by a 12mm Allen accessed from underneath and this gave us more room. Some instructions left this in place.
    all in all it wasn’t too bad at all, took us about an hour and a half. We’ll see how hard going back together is.
    I used these vids for some info and found them useful.
    Part 1
    https://youtu.be/6MWjetIjFR8
    part 2
    https://youtu.be/Qrn1lui91-I
    On aside note the play in The driver side cv shaft is just plain stupid. Toyota should be ashamed of such a crappy design in my opinion. Hoping my front locker will take care of that issue on my new front diff.
  9. Jan 5, 2020 at 12:55 PM
    #1989
    jpel_atl
    jpel_atl Member
    anyone know of a good installer in the atlanta area?
  10. Jan 5, 2020 at 2:12 PM
    #1990
    loastad
    loastad Well-Known Member
    Denver
    2016 AC OR Tancoma
    5.29s, CBI T3 f and r bumpers, ADS suspension, AT Habitat, various small mods
    I hate to be the bearer of bad news, but Fed Ex is not going to put those 5.29s in for you. :D
  11. Jan 5, 2020 at 2:14 PM
    #1991
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    hahahaha that’s some funny stuff right there.
    loastad[QUOTED] likes this.
  12. Jan 5, 2020 at 5:28 PM
    #1992
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    hi. Trying to place my order for the 5.29 complete assembled pre-built core and don't want to go through 100 pages in this thread to find out the answer. Someone kindly reply.
    Here are the list of options in the link : https://eastcoastgearsupply.com/i-23993418-2016-tacoma-auto-non-elocker-third.html
    Questions.
    1. Do I need to add the solid spacer option? I don't know it's merits. What do you recommend?.
    2. Do I need to add gear oil? We have diff oil.
    3. Where do I specify that I am not a 4x4. I don't want the front diff. I'm only replacing my rear diff as my truck is not a 4x4.
    4. Should i select 'No core' option + shipping label if I want to buy ECGs diff and return my stock gear/diff core?
    I'm a mall truck. I have no plans to off-road. Never have. I have 33s on all four corners. Mine's a TRD sport automatic with no front diff. Re-gearing for better driving experience. Thanks!
  13. Jan 5, 2020 at 5:33 PM
    #1993
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    1. No
    2. No
    3. Not sure, looks like you order the front and rear seperate.
    4. I think you have to select core otherwise you buy the 3rd outright but I’m not sure. Normally when you buy a part you pay the core charge and when you return the old one they reimburse the core charge but not sure how ECGS does this.
  14. Jan 5, 2020 at 5:44 PM
    #1994
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    1. no clue
    2. your choice
    3. this is for the rear only so it doesnt matter if you 4x2 or 4x4, diffs are the same.
    4. Add core charge and label. Quote from the description on page you linked: "If you are waiting until you receive new diff, to send your unit in, please select add core charge from the core charge drop down Tab. After 4 weeks the core will be considered purchased by you."
    bacon_st[QUOTED] likes this.
  15. Jan 5, 2020 at 6:01 PM
    #1995
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I'd call and speak with Steven to place the order....
  16. Jan 5, 2020 at 6:07 PM
    #1996
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Who here is running 35s with 5.29s? I’m thinking about jumping up in the spring!
  17. Jan 5, 2020 at 6:07 PM
    #1997
    JoeCOVA
    Joe
    Colorado Springs
    The OP :)
    whatstcp and ERod27 like this.
  18. Jan 5, 2020 at 6:09 PM
    #1998
    bacon_st
    San Diego
    16' Taco TRD sport
    Thank you. I will do that then tomorrow.
    Built2Ride and RyanDCLB[QUOTED] like this.
  19. Jan 5, 2020 at 7:28 PM
    #1999
    Chadr7858
    Chad
    Colorado
    You never jumped up from 33s right?
  20. Jan 5, 2020 at 7:31 PM
    #2000
    SuperBad
    Dallas, TX
    Truck stuff
    from what i've read here he went from stock 31's right to 35's, Never had 33's. I havent read the whole thread though.
    JoeCOVA[OP] likes this.
