The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Mar 4, 2020 at 5:18 AM
    #2301
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The Tacoma is a 4wd vehicle not an awd vehicle. Most 4wd vehicles have selectable transfer cases WITHOUT CENTER DIFFERENTIALS. Driveline bind can occur when operating on dry pavement for extended periods. This can cause bucking, break parts, and cause the transfer case to pop out of 4wd high at speed with the driveshafts under different loads-long curve on an interstate.
    Awd vehicle’s typically have Center differentials in there transfer case and they can split the loads between the front and rear driveshafts enabling driving on dry pavement where there is 100% potential traction front and rear. The center diff will provide the “separation” of the two driveshafts.
    It gets more complicated with older 4x4s like some land rovers and land cruisers that have transfer cases with selectable center differential in there transfer cases. This enables smooth awd on pavement then when the center diff is locked true 4wd.
  2. Mar 5, 2020 at 9:42 AM
    #2302
    zcweisman
    zcweisman Well-Known Member
    Zach
    San Diego
    2016 TRD Off-Road 4x4 MGM, 1993 FZJ80 Land Cruiser
    TRD CAI Magnaflow Catback Exhaust - Chopped OVTune 2.0 Beta 25600 91 Nitro 5.29 Gears TRD Pro Grill Raptor Lights Mod Hondo Vent Mount Hondo Radio Knobs Cobra 75 CB Radio Firestik 3' Antenna Gobi Ranger Rack Leitner Designs ACS Classic SwitchPro 9100 Baja Designs S8 30" Baja Designs Squadron Sport Amber Driving/Combo x2 Baja Designs Squadron Sport Amber Wide Cornering x2 (fogs) Baja Designs Squadron Sport Spot Ditch Lights x2 Baja Designs S2 in backup light positions (scene) x2 Baja Designs S1 (scene) x2 KC Hilites Chase Bar SCS F5 Matte Bronze 17x8.5 Nitto Ridge Grapplers 285/70r17 LR E Tepui Autana 3 FOX 2.5 RR Front and Rear 700lb, 14" Eibach Springs Dakar leaf springs + 2 AAL C4 Hybrid Bumper C4 Sliders C4 HC Rear Bumper w/Swingout RCI Full Steel Skid Plates Recovery: VIAIR 400P Compressor Smittybilt 9K Gen3 Winch Maxtrax 48" Hilift Shovel Assorted straps
    I'm curious about everyone's shop experiences getting regeared. I went with the Nitro kit, truck is currently in the shop getting gears put in. I talked to the guys on the phone a few weeks ago and asked about REM polishing/cryo, and the break-in period with changing the oil and all that.
    Basically, they said you don't really need to worry about any of that. His logic was, truck comes from the factory without having anything crazy done to the gears, and you don't change your diff fluid till the 30k mile mark anyways so it seems a bit silly to waste all that expensive oil and just change it after 500 miles.
    Thoughts?
  3. Mar 5, 2020 at 9:46 AM
    #2303
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    This is a question I've been asking. I don't know anyone who "breaks in" gears when they roll a vehicle off the lot, or having to pull off to the side of the road to let the gears cool down when you go for a test drive.
  4. Mar 5, 2020 at 10:35 AM
    #2304
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    :drevil:
    :popcorn:
    Valid point. Didn’t think about this.
    H3llRid3r[QUOTED] likes this.
  5. Mar 5, 2020 at 11:19 AM
    #2305
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    When I had mine done at ECGS, I asked why they needed break in as the factory gears didn’t. I’m paraphrasing, But he said the factory gears were of higher quality and cost.
    I can say for sure that my fluid after 500 miles was much darker than Tacoma’s on stock gears changed at 30k, not to mention having metal in it.
    “Waste” the oil.
  6. Mar 5, 2020 at 2:15 PM
    #2306
    zcweisman
    Zach
    San Diego
    Thanks for your input. I was definitely curious about a potential difference in production quality of the gears.
    uploadadventure likes this.
  7. Mar 5, 2020 at 2:16 PM
    #2307
    Turd Hawg
    Sure. I have no idea if it’s true or not, just what the man said.
  8. Mar 5, 2020 at 6:35 PM
    #2308
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    The dark oil is the phosphorous coating on the new gears coming off.
    I tend to agree that break in is important but mostly for finding problems, not for “polishing” properly set up gears.
    I may be wrong here, but my understanding is also that Nitro’s warranty policy does not cover REM polished gears.
  9. Mar 5, 2020 at 6:37 PM
    #2309
    therealprotaco
    Gilbert, AZ
    Finally had the truck back in for diagnosis today. The position sensor was causing the fault. No one is really sure why as it looks perfect but they ordered one and it will be in tomorrow. Hopefully this is the last of the issues and I can just get back to enjoying the truck!
  10. Mar 6, 2020 at 3:36 AM
    #2310
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Could've been damaged
  11. Mar 7, 2020 at 7:27 AM
    #2311
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Anyone know about any sales coming up on 5.29 gear sets? Looking to do REM polish and cryo as well.
    whatstcp likes this.
  12. Mar 7, 2020 at 8:27 AM
    #2312
    zcweisman
    Zach
    San Diego
    Hey all, emergency post here.
    Just got my truck back from the shop yesterday. They told me to do 3 drives of about 15-20 miles each separated by 2-3 hours of cooldown time. Got home from my 3rd drive and my front diff was smoking and there was oil all over the top side of my skid plates.
    Probably about to pull the skid plates, check oil levels and the drain and fill plugs for tightness and just inspect the diff for where the leak is coming from. Anyone out there got any advice as to whether my new gears are completely screwed?
  13. Mar 7, 2020 at 8:38 AM
    #2313
    zcweisman
    Zach
    San Diego
    When I got home from my first drive home from the shop, there was a drop of oil on the ground underneath the front diff. I looked closer under the skid plate and there was definitely a light streak of oil, so I kinda brushed it off and chocked it up to oil overfill. There was also kind of a high frequency vibration in the front diff when slowing to a stop, around 1000-1100 RPM.
    Anyways, it wasn't till this morning I noticed that theres oil all over the bottom of the engine and tranny skid plate, so it's very possible in the 3 drives I took between yesterday at around 4pm and 10:30pm that all the oil could have leaked out. Hence the smoke after the last drive.
  14. Mar 7, 2020 at 8:39 AM
    #2314
    therealprotaco
    Gilbert, AZ
    I agree with all of this but I would also call the shop immediately, or better yet email/text them just to let them know of the issue. If it’s a solid shop they will be happy to offer you a tow back to the shop to look it over.
    whatstcp[QUOTED] and zcweisman like this.
  15. Mar 7, 2020 at 8:43 AM
    #2315
    zcweisman
    Zach
    San Diego
    Yea absolutely. Unfortunately there are no axle shops open in SD till Monday, so it's on me until then.
  16. Mar 7, 2020 at 8:55 AM
    #2316
    zcweisman
    Zach
    San Diego
    Thanks everyone, appreciate the advice. But in general not too concerned about damage to the gears? I did only drive 15 miles with a potentially empty front diff.
  17. Mar 7, 2020 at 8:58 AM
    #2317
    therealprotaco
    Gilbert, AZ
    No, unfortunately I would be very concerned about damage to the gears if the diff was smoking. I wouldn’t touch anything until it can be returned, by tow, to the shop that did the install.
    elmontemike and PB FAB like this.
  18. Mar 7, 2020 at 9:00 AM
    #2318
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    Depends on where it’s leaking. If it’s coming from a CV seal then it won’t be a huge deal. They aren’t turning under load anyway in 2wd. I’ve driven about 500 miles on the front diff after losing a seal. Seal blew somewhere outside Wilson, WY and I had no idea until we stopped in Ft Collins and I figured if I made it this far I could make it home.
    The diff is designed to have some fluid in it at all times unless of course the drain plug is leaking.
    If it’s the seal the CV is going to sling oil everywhere so a lot of that smoke maybe burning up on things like your exhaust and other engine components.
    mcharfauros likes this.
  19. Mar 7, 2020 at 9:02 AM
    #2319
    zcweisman
    Zach
    San Diego
    Yea unfortunately I was doing 50-65 in 4Hi
  20. Mar 7, 2020 at 9:14 AM
    #2320
    JoeCOVA
    Joe
    Colorado Springs
    I think you’ll be ok but like others mentioned. Get in touch with the shop when they open.
    whatstcp and zcweisman[QUOTED] like this.
