The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Jun 11, 2020 at 7:54 AM
    #2681
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    Premier gearing in Riverside will do it for $1,600 or $1,700 if you join the group buy. I do know people that had problems after the re gear there. My regear went fine but they did do something to the parking sensor and I still haven't figured out how to fix it.
    They'll install either revolution or nitro for that price. But they strongly recommend revolution if you ask. They'll tell you that nitro installations cause winning or grinding up to 40% of the time. They say they have yet to have any winning or grinding from the revolution gears.
    Glockzilla likes this.
  2. Jun 11, 2020 at 8:14 AM
    #2682
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    It appears you'd have a small margin between the tailgate and the jack for tight turns in parking lots.
    I faced a similar issue and bought a jack-e-up removable jack device so turning radius isn't a concern with the tailgate down.
  3. Jun 11, 2020 at 8:15 AM
    #2683
    Quatro Taco
    Quatro Taco Active Member
    Rugged Off-road 2.25” and 1” blocks. 285/70r17 on TRD 4Runner SEMA wheels
    Darth,
    Larry at Yotaman in Santa Rosa.
    They are a Toyota and rock crawler specialist.
    MudShark likes this.
  4. Jun 11, 2020 at 8:51 AM
    #2684
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    Dude I run WY and MT at 65-70 when speeds are set at 80. No one cares, not enough traffic to matter, just chill in the right lane and enjoy the ride. There is always someone slower.
  5. Jun 11, 2020 at 9:09 AM
    #2685
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Check out my post #16 here with pics of my setup. I've stress tested it and i'm comfortable towing with the tailgate down 100%. Only time the jack post would come close would be an extreme uphill angle but i still think i'd be fine. I'm actually going to really be putting my 5.29's and truck to the test next month if the campgrounds finally open up. Towing the trailer with 2 dualsports loaded in the back of the truck. up near downieville ca.
    Gen3TacomaOBX[QUOTED] likes this.
  6. Jun 11, 2020 at 9:21 AM
    #2686
    Gen3TacomaOBX
    S
    Cool. I now see your extended ball mount that makes it possible. :thumbsup:
  7. Jun 13, 2020 at 12:05 PM
    #2687
    Lygrin
    Lygrin Well-Known Member
    Mark
    Tacoma, WA
    2019 Cement Tacoma TRD Off Road 4x4
    I just picked up my Tacoma after having 5.29s installed and am going through the break-in period. It feels like a painful process, but I can already feel the gears at work hearing them row through the first four gears.
  8. Jun 15, 2020 at 6:06 AM
    #2688
    Glockzilla
    Glockzilla Well-Known Member
    Cole
    San Diego
    2018 TRD OR 4x4 Quicksand
    That’s crazy! I haven’t heard that before with Nitro Gears!
    Brothers 4x4 in San Bernadino said they would do it for between 1500-1800 and would use Revolution Gears. Anyone have experience with them?
  9. Jun 15, 2020 at 9:09 PM
    #2689
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Had my gears installed here in Bend, OR at Gear Works. Friend of mine uses him for his shop projects. $1410 out the door. Nitro gears. About done with break in. Loving the change. 285s now but 315s go on this week
  10. Jun 16, 2020 at 2:13 AM
    #2690
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Is that including gears or just labor?
    Glockzilla[QUOTED] likes this.
  11. Jun 16, 2020 at 8:39 AM
    #2691
    mhshark
    Bend, Or
    With gears
  12. Jun 16, 2020 at 9:31 AM
    #2692
    JoeCOVA
    Joe
    Colorado Springs
    Must be with mini-kits because it's $1300 for the full kit so I can't imagine their labor is only $200-$500
  13. Jun 16, 2020 at 10:26 AM
    #2693
    CP40
    Love my 5.29 revolution gears - smooth as silk. I guess the Jeep communing knows something after all.
  14. Jun 16, 2020 at 11:14 AM
    #2694
    mhshark
    Bend, Or
    I just had mine done with master kits for $1410 w/ fluids. I think a few shops can get these gears cheaper than we think. I personally found them for $1100 so I’m sure a professional shop is sub 1k on them.
  15. Jun 16, 2020 at 6:35 PM
    #2695
    Glockzilla
    Cole
    San Diego
    Can you explain what a mini kit is? I haven’t a clue :)
  16. Jun 16, 2020 at 6:51 PM
    #2696
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    Just a guess, I think it has the bare amount of seals or none at all. Maybe gears only?
  17. Jun 16, 2020 at 7:20 PM
    #2697
    JoeCOVA
    Joe
    Colorado Springs
    Mini kit basically comes with shims and seals. The full kit includes all new bearings.
  18. Jun 16, 2020 at 7:22 PM
    #2698
    JoeCOVA
    Joe
    Colorado Springs
    Idk, I guess it doesn’t matter as long as we get a good deal right.
  19. Jun 16, 2020 at 9:43 PM
    #2699
    Glockzilla
    Cole
    San Diego
    Got it. Thanks. I will confirm it’s the full master kit before making an appointment!
  20. Jun 17, 2020 at 8:00 PM
    #2700
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    ^^ good deals if done right. I just paid my dealer $1100 to install ECGS preassembled members.
    With the OvTune 2.0 final and 5.29s the truck is finally an easy and enjoyable drive. Highway mpgs unchanged, however a few mpg better in town.
    Governor and CocaineAndCreatine like this.
