The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Jun 4, 2021 at 7:41 AM
    #3501
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Also the fact that there are more teeth on OEM gear.
  2. Jun 4, 2021 at 7:44 AM
    #3502
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    There would be more teeth on the ring gear of a 5.29 than the stock 3.90, to my understanding, or am I wrong about that?
  3. Jun 4, 2021 at 7:49 AM
    #3503
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Someone told me you do not need to replace the diff oil after break in if the gears were installed by a knowledgeable installer. Thoughts?
    I changed mine anyways yesterday after about 1200 miles of break in and the oil looked clean. Very little metal on the drain plug.
  4. Jun 4, 2021 at 7:50 AM
    #3504
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    I got my gears before moving to larger tires. There aren't any problems at all.
    I went with 4.88s b/c I never thought I'd have a heavy rig w/ 33s. Then things kept piling on. My advice--if you plan to go larger tires at all in the future, go 5.29. It's better to have a limited top end for a little while than have limited power forever.
    helix66 likes this.
  5. Jun 4, 2021 at 7:51 AM
    #3505
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Usually it's 500 break in, then change every 15k.
  6. Jun 4, 2021 at 7:53 AM
    #3506
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    If you ever have the opportunity to count them out, you'll see that the stock gears have more teeth on both the ring and pinion.
  7. Jun 4, 2021 at 7:55 AM
    #3507
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Still need to do it because during break in the gear friction heats the oil more than normal and breaks down its lubricating properties. The fact that the gears were done correctly or not plays no role in that.
  8. Jun 4, 2021 at 7:58 AM
    #3508
    MountainManGuy
    Colorado
    I was told 500-1000 for the break in. Don't think it has to be a hard 500.
    Gotcha, glad I did it anyways! Should I be changing it every 15k if I wheel often?
  9. Jun 4, 2021 at 8:16 AM
    #3509
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Truthfully, only if you think you got some water in it. I think 30k is fine otherwise.
  10. Jun 4, 2021 at 8:32 AM
    #3510
    Stocklocker
    17TRDORDCSBAT
    Ahh. I did not know that. For whatever reason I though it would be more on the ring, like it would be on a bicycle.
  11. Jun 4, 2021 at 8:45 AM
    #3511
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    5.29 is a 7 tooth pinion and 37 tooth ring gear in the 8" third member, The 4.88 is a 8/39 configuration and stock (manual) 4.11 is 10/41.
    37/7=5.29
    39/8=4.88
    41/10=4.1
  12. Jun 4, 2021 at 3:58 PM
    #3512
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    I just counted on my 14bolt
    41/10=4.1
    43/8=5.38
    AODRN[QUOTED] likes this.
  13. Jun 4, 2021 at 8:16 PM
    #3513
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    What is stronger - more teeth - or thicker teeth?
  14. Jun 4, 2021 at 9:24 PM
    #3514
    JoeCOVA
    Joe
    Colorado Springs
    It’s really more surface area contact
  15. Jun 8, 2021 at 4:58 PM
    #3515
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Just confirming it's 85w-140 for both front and rear diffs -- swapping to LT and gotta top off the front diff a bit.
  16. Jun 8, 2021 at 8:17 PM
    #3516
    AODRN
    STL
    That's what ECGS recommended
  17. Jun 8, 2021 at 10:11 PM
    #3517
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    yeehaw, thanks
  18. Jun 10, 2021 at 5:05 AM
    #3518
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Front diff install just went up on the channel. So much more work. I will have a fallow up video on the break in process. Currently need around 100 miles to hit the 500.
    https://youtu.be/TnRm7S-ha1k
    JDSmith and japjoe7 like this.
  19. Jun 10, 2021 at 8:29 AM
    #3519
    MountainManGuy
    Colorado
    So this might stir the pot a bit here but I'm not as impressed with my 5.29 gears as much as I thought I'd be. The truck still struggles like hell to get up hills. It still struggles like hell to hit or maintain 70+ mph on the highway. My MPG's have actually gone down a little since having them installed.
    I do have to throw out the disclaimer that I live in Colorado and the elevation here just robs power, and our hills are BIG hills. I'm going to be driving to Arkansas in a month or so and will be looking forward to seeing how it performs at lower elevations because I know how much of a difference elevation can make. My truck also may be a bit on the heavy side but it's certainly not as heavy as a lot of tacomas I see on here. Maybe I should have it weighed. Also, for those wondering I have 315/75r16 tires.
    I use ECT mode at all times and it still feels sluggish. Everything I've read says a tune makes even more of a difference than the gears so maybe I need to go down that route, but I just wanted to throw out there for those looking to do this mod that it's not as drastic as a lot of people make it seem. It's definitely better than the factory gears, but it's marginal, especially with how much it costs to do this.
    davidstacoma and clayota like this.
  20. Jun 10, 2021 at 8:56 AM
    #3520
    clayota
    clayota Well-Known Member
    San Francisco, CA
    2018 TRD Off-Road DCSB 4x4
    you’re not alone. I’m having a similar experience. I regeared to 5.29 a couple months ago and haven’t been super impressed so far. I live in San Francisco so there’s a lot of hills and stops in the city, but I’m struggling to hit 12 mpg when I used to get 14 on stock gears. My highway mpg’s have similarly been worse
    the truck definitely accelerates better from a stop and shifts through the gears quickly, but the stock tune shifts into 4th way too quickly which makes the truck still feel sluggish to me. I’m getting tuned next week so hopefully that helps
    I’m also noticing on the highway that I’m generally 1 gear higher than I was before the regear, so 5th is now 6th, 4th is 5th, etc. The truck used to be pretty responsive when I dropped into 4th to pick up speed prior to the regear. But now, dropping into 5th at similar speeds feels really sluggish and I really have to step on it (even dropping down to 4th) just to go a few mph faster. That’s been a frustrating experience for me on the highway and was wondering if anyone else experiences that. Hoping a tune will work wonders here as well
    I’m on 33s E load and have skids, sliders, bed rack, RTT, and roof rack
