The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Feb 26, 2019 at 12:02 PM
    #361
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    What thing?
  2. Mar 1, 2019 at 11:06 AM
    #362
    three zero seven
    three zero seven Well-Known Member
    2016 TRD ORDCLB
    I read through the first 15ish pages of this thread and didn't see anything about it. I installed the 5.29s and when I drive down to St. George UT on I-15 where the speed limit is 80 is the only time I have had a problem with it. The truck governs out at about 82 mph, and you have to let your speed dip below 80 for the truck to give you any power back. I have contacted OV tune and they said they plan on making a specific tune for the 5.29s sometime in the near-ish future that would fix this issue. Is there a cheaper way to deactivate or re-calibrate the governor that anyone knows of?
    0uTkAsT likes this.
  3. Mar 1, 2019 at 12:26 PM
    #363
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    That's odd, I've gone over 80 before without issue. I think the truck governed out at 95 if I recall.
    Are you on stock tires?
  4. Mar 1, 2019 at 12:55 PM
    #364
    three zero seven
    2016 TRD ORDCLB
    If you’re accelerating pretty fast you can get to 90. If you accelerate slowly the power cuts back at about 82.
    I’m running 33s so my actual speed is 4-5 mph faster than what my speedo reads.
    Just sucks when you need to go just a couple mph faster to pass someone in the shit show that is southbound I-15.
  5. Mar 1, 2019 at 1:02 PM
    #365
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    Hypertec speedo calibrator will allow you to recalibrate for change in tire size
    http://www.hypertech-inc.com/vehicle-results.aspx?AAIAID=469405
  6. Mar 1, 2019 at 1:37 PM
    #366
    three zero seven
    2016 TRD ORDCLB
    Sounds like I need 35s or 37s!!
    jlusmc likes this.
  7. Mar 1, 2019 at 2:17 PM
    #367
    three zero seven
    2016 TRD ORDCLB
    I read earlier in this thread that the speedo runs off of your ABS sensor or something like that.
    Which makes sense because I double checked my speed with a GPS and the difference didn’t change before and after my gears. It’s still a few mph fast because of the 7.18% difference in tire size from factory.
    I also got a speeding ticket doing 86mph a couple weeks ago... which confirms this.
  8. Mar 1, 2019 at 2:22 PM
    #368
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Well if it reads at the wheel, then yeah, the gear change shouldn't affect it
  9. Mar 1, 2019 at 2:28 PM
    #369
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    I retract my earlier statements, I called Nitro gear, they confirmed the speedo is reading at the ABS on the wheel, and you only need to account for tire size changes. I will delete my earlier comments to keep from confusing anyone.
  10. Mar 1, 2019 at 3:26 PM
    #370
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    I think the ECU may make some speed assumptions via gear and RPM as well. Mat was talking about it in the Ovtune thread. I think he stated that the ecu governs speed at 105mph. Which should be about 2600 RPM stock gear and tire size (auto 6th gear). 2600RPM should be 82.5 Mph on “33” and 5.29’s (auto 6th gear). Seems to match @three zero seven observations above.
    It would be interesting to know if the hyper tech actually changes the ecu behavior. Mat is creating gear calibrated tunes but it’s currently not clear (doubtful) this will change what’s displayed on the speedo.
    This leads me to believe the ecu is running off of internal tables not the speedo signal. If that’s the case hypertech will not be a solution for the governor.
    @OVTune prob the only one that knows unless someone with a hypertech, 4.88’s and “33’s” can do >90. For science... on a closed course.
    jlusmc and BEAR_KNIFE_FIGHT like this.
  11. Mar 1, 2019 at 3:44 PM
    #371
    JoeCOVA
    Joe
    Colorado Springs
    This is an interesting discussion. I don't really have a stake in it since my new tires have a max speed of 65 but I am curious to what is going on in the ECU
  12. Mar 1, 2019 at 3:45 PM
    #372
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    I can do some radar testing when I am off shift regarding speeds at different gear sizes.
    1, speedo is read off the ABS and is independent of the gears, so don't recalibrate your hypertech if you get different gears, only different tire sizes.
    2, stock gears + 33s can do 89 confirmed via radar.
    0uTkAsT and JoeCOVA[OP] like this.
  13. Mar 1, 2019 at 3:51 PM
    #373
    KanPanic
    State of Jefferson
    2018 OR
    3.9’s plus 33’s @2600rpm (6th auto) is ~111mph. Please don’t!
  14. Mar 1, 2019 at 5:34 PM
    #374
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    I don't know what to tell you other than I know it goes 89 with that setup. Not sure what the RPMs were but your math seems incorrect.
  15. Mar 1, 2019 at 9:56 PM
    #375
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    245’s 16 inch rim bounced off speed limited at 114 mph auto trans 3.91 gears...
    TS7xTaco likes this.
  16. Mar 2, 2019 at 11:24 AM
    #376
    Trident904
    Brian
    17 4Runner TRD OR
    I have 4.88’s, 35’s, OVTune, and hyper tech and I do 90-95 all the time without a problem.
    whatisraytaco likes this.
  17. Mar 2, 2019 at 12:27 PM
    #377
    KanPanic
    State of Jefferson
    2018 OR
    Interesting! 2600 rpm with 4.88 and 35’s 6th AT would be 94MPH.
    If MT share the same 105MPH limiter it would happen at ~3500rpm on stock tires and gearing. Does the ECU know what gear you’re in on a MT?
    So @Trident904 theoretically you should hit the limiter at 103.4. But don’t please!
  18. Mar 2, 2019 at 2:17 PM
    #378
    Trident904
    Brian
    17 4Runner TRD OR
    At 95 I’m at 3300 RPM in 6th. At 70 I’m at 2500.
    I’ve hit 105 but being on 35s and heavy, the truck didn’t like it too much.
  19. Mar 3, 2019 at 2:17 PM
    #379
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Kind of curious too,I have 3 weeks until my appointment and I'm still just trying to decide if I'm making the right choice. I drive a short highway drive most days of the week, but here in the deep mountains of Tn you'd be lucky to move a mile without multiple up and downs. I have no doubt the gears are needed as its almost unenjoyable to drive anymore, its just the ratio choice I am stuck on.
  20. Mar 3, 2019 at 2:36 PM
    #380
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    I got mine I just haven't put them in yet. Probably going to wait till I find someone who wants these 4.30s that are in my axles to eat up the cost. They fixed a lot of problems for me but just not enough uhmp to get up the mountains and the grapevine in Cali.
    Mack411[QUOTED] likes this.
