The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Aug 9, 2022 at 2:20 PM
    #4121
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    You may drop your RPMs but the rotational force needed to turn bigger tires negates any savings.
    Muajilong[QUOTED] likes this.
  2. Aug 9, 2022 at 7:37 PM
    #4122
    Muajilong
    Muajilong Well-Known Member
    Joe
    2019 Black Tacoma TRD Pro
    Hm interesting, thanks for the info. I was hoping to go with a 35 tire that is similar in weight as my 33 tire. Guess still no mpg savings?
  3. Aug 9, 2022 at 9:51 PM
    #4123
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    You would be very hard pressed to find a 35 that is as light as a 33. My MTRs are one of the lightest 35s you can get and regeared I’m down 2mpg or so on average than stock gears and 33s.
    That being said being in 1st gear, 4L with 5.29s is incredible on hills. It’s almost like a crawl gear, don’t have to touch the brakes on steep descents and goes up hills like nothing compared to stock gearing where I’m flooring it and barely making it.
  4. Aug 10, 2022 at 12:10 AM
    #4124
    mauctopa
    mauctopa Well-Known Member
    I have 5.29s, 35s and Overland tune ( 91 octane ), would adding octane boost help my mpg in my case? Also does it make sense on going for a lighter gear oil? 85-140 currently ?
  5. Aug 10, 2022 at 4:04 AM
    #4125
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Traffic jams in VT/NH are more of a quick pause :D
  6. Aug 10, 2022 at 6:59 AM
    #4126
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Maybe over in your area. I know Burlington gets some decent traffic. I live in Lancaster NH. The only traffic I see over here is if a moose is present or the leaf peepers are up.
    JDSmith[QUOTED] likes this.
  7. Aug 10, 2022 at 7:24 AM
    #4127
    Muajilong
    Joe
    I found that my MPGs we're better with Valvoline 80w-90 vs Lucas 5w-140, both non-synthetic. Lol but then I lifted the rear a bit and now the MPGs are down!
    mauctopa[QUOTED] likes this.
  8. Aug 12, 2022 at 3:23 AM
    #4128
    JDSmith
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Right outside Burlington. Every time I travel, I remind myself it could be way worse here
  9. Aug 12, 2022 at 3:35 AM
    #4129
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I'll chime in a same that with the 5.29 Nitros and a recent YotaWerx (BlackHawk) tune the truck finally feels like it should. Added the gear lock to the tune too. Now I can actually wheel near or at redline without a shift when you least want it.
    MountainManGuy likes this.
  10. Aug 12, 2022 at 4:36 AM
    #4130
    Vegasstunts
    16 TRD sport
    All of them.
    The shift lock out is the best part of the tune.
  11. Aug 12, 2022 at 5:11 AM
    #4131
    Freeheelbillie
    Billie
    Saint Clair, MI
    Its high on the list for sure. The shifing off road when you need the revs was enought to make me loose my mind. Its nice while towing too...
  12. Aug 12, 2022 at 9:30 AM
    #4132
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    Don't you use the manual selector offroad? Or will it shift on its own at a certain rev?
  13. Aug 12, 2022 at 9:45 AM
    #4133
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Even with the manual mode, it can still shift to lower gears. For example, if you put it into S2, it can still drop to S1...
  14. Aug 12, 2022 at 9:49 AM
    #4134
    Taco X
    James
    2022 SR 4x4 V6
    If it's only doing it when the revs are so low that it isn't transferring power that would be okay
  15. Aug 12, 2022 at 10:00 AM
    #4135
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It's more about the delay of the shift and the sudden change in revvs/power, that can create slippage. More control is always better.
  16. Aug 12, 2022 at 3:47 PM
    #4136
    Freeheelbillie
    Billie
    Saint Clair, MI
    hits red line and shifts…sucks.
  17. Aug 12, 2022 at 3:50 PM
    #4137
    Freeheelbillie
    Billie
    Saint Clair, MI
    No. 4 low, high rev. it shifts to next gear up and bogs the motor. Gear lock keeps it in the gear you have selected unless revs go crazy low, then it will down shift.
  18. Aug 14, 2022 at 2:09 PM
    #4138
    Muajilong
    Joe
    Just an update. Got a wheel alignment and my MPGs are back up! Personally experiencing better MPGs with 80w-90 vs 85w-140 dino.
    snakeplissken likes this.
  19. Aug 14, 2022 at 4:37 PM
    #4139
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    I think you're reading into things too much bro. Alignments and gear oil aren't going to affect your mpg in a noticeable way. It's all about how much skinny pedal you're using and where you're driving.
  20. Aug 14, 2022 at 7:41 PM
    #4140
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    For me it's all about the wind direction. That affects my mileage more than anything else.
