The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Mar 18, 2019 at 6:24 PM
    #421
    jhipwundah
    jhipwundah Well-Known Member
    Oahu, Hawaii
    2018 Cement TRD Off-road DCLB 4x4
    @SSM, I'm in the same situation too lol (285/75/17 tires). But for me, because I tow a boat almost every weekend, my gutt is telling me to go with the 5.29s.
    alexplb and SSM Taco[QUOTED] like this.
  2. Mar 18, 2019 at 6:40 PM
    #422
    ferntr33
    ferntr33 Well-Known Member
    To be honest for me it really comes down to my 6th gear rpms at 75mph. For the MT 5.29 with 35’s (315/75r16) is too high for my liking.
    2736 rpms (529)
    2523 rpms (488)
    2224rpms (433)
    SSM Taco likes this.
  3. Mar 18, 2019 at 6:53 PM
    #423
    SSM Taco
    SSM Taco Well-Known Member
    Mesa, Arizona
    2016 SR5 4x4 DCSB
    Overland Bound #4340
    Decisions, decisions! I am actually leaning toward the 4.88 since I go on a lot of longer trips and do quite a bit of highway driving. If my plan were to go to 35's eventually I would go with 5.29 but I'm on 285/70/17 and planning 285/75/17 or 295/70/17.
  4. Mar 18, 2019 at 7:20 PM
    #424
    jhipwundah
    Oahu, Hawaii
    Yea, that's what my concern is too (high RPMs at highway speeds). I rarely go over 70mph so not sure if that would still be an issue for me.
  5. Mar 18, 2019 at 7:52 PM
    #425
    alexplb
    alexplb Well-Known Member
    as far as RPM go I've seen different figures used than ones you've posted. So confusing ;/ But like someone said here, not enough data to support a definite con/pro. One thing I remember even from my 2nd gen was that it was running lower RPMs with a larger size tires but because it was such a heavy pig it kept downshifting at any slightest hills and also putting strain on transmission constantly. In the end MPG still sucked basically even with lower RPM range. Several shops told me to re gear to 5.56 or 4.88 and RPM would jump up BUT MPG would be better because motor is not working as hard, it's just spinning ... not sure how true this myth is lol I guess it's too late for me, I'm half way in for 5.29s by about now with Nitro gears
    jhipwundah likes this.
  6. Mar 18, 2019 at 7:58 PM
    #426
    jhipwundah
    Oahu, Hawaii
    Give your feedback once it's all done!
  7. Mar 18, 2019 at 8:01 PM
    #427
    alexplb
    whats the general impressions ? any change in MPG? whats sort of set up are you running ?
  8. Mar 18, 2019 at 8:01 PM
    #428
    alexplb
    100% will for sure! I'm picking it up this Saturday.
    jhipwundah[QUOTED] likes this.
  9. Mar 18, 2019 at 8:45 PM
    #429
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    So the MT in my opinion gets a little screwed on the top end when it comes to gears. The MT gets a better first gear but then it sucks after that.
    The ATs are what really benefit from the lower gearing. If you daily your truck or use it for general use then the 4.88s are probably better on the MT. If you tow all the time or offroad a lot then 5.29s are probably the better way to go.
    Really just comes down what you mainly use the truck for
    alexplb and rlx02 like this.
  10. Mar 18, 2019 at 9:43 PM
    #430
    alexplb
    I was wondering if what
    jhipwundah
    mentioned earlier is for MT and not AT as far as the calculations for RPM go. "2736 rpms (529)" does seem high for going 75 especially with 35" tires.
  11. Mar 18, 2019 at 9:45 PM
    #431
    JoeCOVA
    Joe
    Colorado Springs
    That rpm is for MT, the AT would be around 2209. Basically the 5th gear on the AT is the same ratio as the 6th gear on the MT
  12. Mar 18, 2019 at 9:51 PM
    #432
    alexplb
    Ok beautiful ! I was hoping to hear that... though Im going to be on 33s for a while but still at least it's not redlining lol
  13. Mar 19, 2019 at 6:35 AM
    #433
    ferntr33
    http://www.grimmjeeper.com/gears.html
    Here is the calc that I use in case anyone wants to run their own numbers.
    .71 6th gear for manual transmission (MT)
    .58 6th gear for automatic transmission (AT)
    Also notice if you put in tire size in metric is shows you actual height in inches. 285/75r16 (32.8”)
    315/75r16 (34.6”)
    That being said actual height of a 35x12.5 varies between manufacturers and is usually around 34.5” anyways.
    mcharfauros likes this.
  14. Mar 19, 2019 at 8:49 AM
    #434
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    General impressions: Really happy with them. Much more power at lower speeds, and it doesn't feel like a challenge to get up to highway speeds anymore. I am running steel armor front and rear, winch, RTT, gear, etc. On 255s currently until next week when the 315s/LT kit go on. It's been a huge delay with the shop and my life so I have been waiting to get that all in. I will update you all when the new gear goes on!
  15. Mar 19, 2019 at 7:01 PM
    #435
    alexplb
    Nice will be very curious to hear how you like the LT going from mid travel icons. I'm taking delivery of the truck and it has brand new set of BP51s with upgraded ome HD leaf and camburg uca... But I've been wondering about those LT set ups it's just so much $$$ cab chop, fender shop etc if you're planing to run 35s
  16. Mar 19, 2019 at 7:05 PM
    #436
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    For sure, I'll put the updates on my thread so I'm not cluttering up too much TW haha.
    I agree, its a ton of money. I have a shop close by that has been working with me on it all which helps, but yeah, there's a lot of custom work with MT/LT kits that there isn't with other lift options. It's not really as bolt on as I'd like, but that's part of the fun! :sawzall:
    alexplb[QUOTED] likes this.
  17. Mar 20, 2019 at 11:00 AM
    #437
    youngster77
    youngster77 Well-Known Member
    2017 TRD OFF-ROAD
    Dang, I was sold on going 5.29's with my LT setup on 35's. I even ordered them. But now that this speed governing issue is coming to light i'm a little concerned. Even Matt has mentioned in the OVTUNE thread that this is an issue he's heard of from multiple people running 5.29s. If governed at 85mph that means the speed will be limited at 75mph. Not an absolute deal breaker but would suck just to know I wouldn't be able to go past 75mph if I needed to.
    Doomsday likes this.
  18. Mar 20, 2019 at 12:19 PM
    #438
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    It's not though.
    I have driven my truck [stock gears + 33s] over 85 -- 89 confirmed by radar. I have driven 5.29s + 33s over 75. I will confirm the 5.29s + 35s with radar when it get installed next week.
  19. Mar 20, 2019 at 1:30 PM
    #439
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    OMG, WOW...:eek: What a beautiful truck, do you have a side picture?:drool:
  20. Mar 20, 2019 at 1:59 PM
    #440
    youngster77
    2017 TRD OFF-ROAD
    Awesome! Hopefully you'll report back with some good news.
