The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Aug 6, 2024 at 9:11 AM
    #4581
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    There is no setup with ECGS, they come assembled and ready to go, you just bolt them in place.
    Place the order for third member and clamshell, pay for core charges
    When they arrive you install
    Send beck your cores within 30 days and receive core charges back minus return shipping ( $150 in my case)
    helix66[QUOTED] likes this.
  2. Aug 6, 2024 at 10:47 AM
    #4582
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Ahhhh ok that makes sense for that time frame.
    How’d it ship, in a crate? ….which carrier?
  3. Aug 6, 2024 at 11:10 AM
    #4583
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don't know how ECGS does it, but 3rd members are pretty small. Two cardboard boxes from Lowe's, one inside the other is more than good enough. Filled with packing of course and some support on the bottom. I shipped some via UPS for about $70 each.
  4. Aug 6, 2024 at 11:34 AM
    #4584
    guaco.supreme
    MN
    Yep, two thick boxes, one inside the other, with a bunch of shredded cardboard packing, and wrapped in a plastic bag. They have you use the same boxes for the core returns. Shipped UPS ground. ECGS ships to you for free, and pays the return core shipping at their rate but subtracts the cost from your core refund.
    ClassyTacos and helix66[QUOTED] like this.
  5. Aug 6, 2024 at 5:32 PM
    #4585
    helix66
    DPRC
    2017 DclB TRDor MgM
    When I questioned the install time I assumed guys were installing the gear sets and setting backlash etc themselves.
    Putting in a prebuilt third is far less complicated. I did the 3rd on my old pathfinder, when changing out the LSD to an open with a lock-right locker.
    Didn’t touch the front or the gears.
  6. Aug 7, 2024 at 10:10 AM
    #4586
    guaco.supreme
    MN
    regarding break-in...
    According to ECGS there is a break in procedure for towing. Do I do this before changing fluids at 500 miles or after? And if it's after, do I need to change fluids again after the trailer break-in? It's only a ~1500lb trailer, so nothing heavy.
  7. Aug 7, 2024 at 1:09 PM
    #4587
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    call ECGS for that. I wanna say do the 500 mile break in, then fluids are done, then you do whatever trailer break in and not need new fluids
  8. Aug 26, 2024 at 7:17 AM
    #4588
    guaco.supreme
    MN
    I'm about to wrap up my first full tank after break in was completed. I've noticed a bump in mpgs. Average mpgs used to read mid 15's before, now its mid 17's. So far trip mileage the truck is reading is about the same as GPS trip, so we will see what it hand calcs out to. I did go with the lite/mild OTT tune this time vs mild/medium I had before.
    So far zero complaints. The trucks drives sooo much better. No gear hunting, no downshifts on simple hills that shouldn't cause any vehicle to downshift. Pulled the camper awesome with no issues, even pulled in S5 without unnecessary downshifting or unlocking of TC. As long as nothing changes this was by far the best money spent on the truck. It actually feels driveable and usable now.
  9. Sep 6, 2024 at 6:49 AM
    #4589
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Thanks for the videos. This will be my next project.
    Question, if someone knows. If I am just changing the front clamshell (no new hubs or spindles), do you still have to completely disassemble the hub, or can you get the CV axle out by disconnecting the upper ball joint, etc.?
  10. Sep 6, 2024 at 6:52 AM
    #4590
    BLtheP
    Plano, TX
    Just take the two bolts out at the bottom of the steering knuckle. That will let you move the knuckle enough with the CV to get the CV out of the diff and out of the way.
    ClassyTacos likes this.
  11. Sep 6, 2024 at 6:58 AM
    #4591
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Thank you, I figured there was a simpler way.
    I had another question but searched around and found the answer. I was concerned about the speedometer/odometer being even further off than it is now with 285/75R16 tires, but apparently the 3rd gen uses wheel speed -- so gearing doesn't affect the speedometer. It's not far off, but I ordered the Hypertech doohickie to correct things anyway.
  12. Sep 6, 2024 at 7:20 AM
    #4592
    BLtheP
    Plano, TX
    Yeah, no need to do anything with speedo for gears, only tires.
    Decide if you want the odometer or speedometer accurate. You can’t have both. In stock form, the speedo reads fast by 3.5% and the odometer is spot on. Many know that stepping up the tire by 1” or one aspect ratio size fixes the speedo, but most don’t know that doing so actually makes the odometer underreport. Which is not a problem, just something I think is worth knowing. This is probably because they know they can’t short people on warranties on stock tires, so they have to make the odometer accurate.
    If you want to calibrate the speedo to be accurate (and don’t care about odometer), then use 31.6” as your “stock” tire size and 32.8” or whatever for your new size. If you use 30.6”, like stock is, then the speedo will be fast by a bit just like stock was.
    Canadian Caber likes this.
  13. Sep 6, 2024 at 7:33 AM
    #4593
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Thanks, I knew this was true on the 2nd gen, but I hadn't heard this for the 3rd gen. Based on GPS readings, I thought the speedo was pretty accurate in stock form. I'll probably just go with stock size and get the odometer back to accurate so the MPG calculation is a bit closer to reality.
    EDIT: Well, that was easy. Amazon delivered within 24 hours, took about 10 minutes to run the updates and configure it and 10 minutes to install. Seems to work well.
    Ran down to get my daughter from college (30 minute highway drive) and it seems to be accurate, and it's giving me a much more realistic MPG calculation (17 for the round trip). With the wind at my back and on level ground or going downhill, it would actually shift into 6th for a little bit. On the way back against the wind, I don't think it ever saw 6th. I need to regear . . .
  14. Sep 12, 2024 at 2:11 PM
    #4594
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    H3llRid3r and ERod27 like this.
  15. Sep 13, 2024 at 9:23 AM
    #4595
    r3k
    r3k Well-Known Member
    did u get better mpg after regear?
  16. Sep 13, 2024 at 11:22 AM
    #4596
    guaco.supreme
    MN
    I saw the same and sometimes 1-2mpg better depending on where I was. But most tanks are the same as before.
    I did gain about 1.5 avg while pulling my trailer. Before the regear I consistently saw 13mpg average, now I see 14.5avg.
    r3k[QUOTED] likes this.
  17. Sep 22, 2024 at 1:57 PM
    #4597
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    So the ECGS 2-week lead time was actually only 2 days. Rears are in! I took it for the first run break-in ride and I'm already seeing my MPG jump, but I'm driving gently. That said, I barely have to hit the gas and it will go. No highway driving yet, so the jury is still out there. I might disconnect the battery for a bit and force it to re-learn everything, but it already seems to hold gears better.
  18. Sep 28, 2024 at 1:43 PM
    #4598
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Working on the front now but waiting on security bits so I can get my cat shield off (don't know wtf I did with those, coulda sworn they were in the center console). I know some have said you don't have to separate the CV from the hub, but all instructions I find have it being removed. In case I run into clearance issues, I want to make sure I have the right tools.
    The ECGS instructions say the axle nut is 36mm. Other sources say 35mm.
    Which is it?
  19. Sep 28, 2024 at 1:51 PM
    #4599
    BLtheP
    Plano, TX
    Don’t need to separate the CV from the hub. Definitely need the security bits for your cat shield though.
  20. Sep 28, 2024 at 1:54 PM
    #4600
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    OK, thanks, I'll try it without. But if I did have to swap a CV axle, would I need a 35mm or 36mm?
