The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    39.8%
  2. 85w-140
    46.1%
  3. Other
    8.5%
  4. 75W-110
    5.6%
  1. Mar 27, 2019 at 10:49 PM
    #521
    alexplb
    alexplb Well-Known Member
    Did you do a cliff hanger? On a Tacoma? Photos or that didn't happen lol :))
    JoeCOVA[QUOTED][OP] likes this.
  2. Mar 27, 2019 at 10:51 PM
    #522
    alexplb
    what kind of voodoo magic is that? 20.1 MPG!??? Is the truck completely stock with just the 33" tires?
    Warhawk likes this.
  3. Mar 28, 2019 at 5:37 AM
    #523
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    complete OME lift, hidden winch and sliders. no full bumpers or skids as of yet. Also keep in mind this is the break-in period so it's not going over 60 mph. I fully expect this number to go down when normal driving resumes. It's still way better than the 14-15 mpg I was seeing on the same drive.
  4. Mar 30, 2019 at 3:16 PM
    #524
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Well I'm sitting at 497 miles since picking it up from having 5.29 put in. Everything seems ok although i've been driving it like a granny but I can tell some major improvement on hill climbs on the highway especially the 287 mile drive home. I will say this, after picking it up there is a noticeable whining sound that seems to be from the rear end area. Curtis said that unfortunately these have been common to do this and that to them on the test drive it seemed much quieter in mine vs the trucks that did not do the REM polishing. It seems to be most common when decelerating and at higher speeds but I also just had all new suspension put on this month so I'm chasing down vibrations and I'm not sure after all the reading ive done the whining noise is my gears or my rear end suspension. Im reading so much conflicting info but its time for my 500 mile oil change. Can anyone tell me what size sockets I need for this job and we do just change the rear diff oil correct?
    alexplb and Bigdaddy4760 like this.
  5. Mar 30, 2019 at 3:39 PM
    #525
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    24mm
    jlusmc likes this.
  6. Mar 30, 2019 at 3:42 PM
    #526
    alexplb
    I assume most people are going with 80-90 lucas oil?
  7. Mar 30, 2019 at 3:56 PM
    #527
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Gear shop put 85-140w Oriley's Master Pro in mine. Said when I do the 500 mile fluid change to make sure and use a GL-5 milspec rated gear oil.
    TacoNesian and JoeCOVA[OP] like this.
  8. Mar 30, 2019 at 3:56 PM
    #528
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    Ford F350, Lexus RX450h, FZJ80, Jeep YJ
    And a 10mm allen for the front I believe.
    I run 85-140
  9. Mar 30, 2019 at 4:00 PM
    #529
    alexplb
    wow well once again everyone is all over the place, rogue off road told me to go with Lucas 80-90 or similar ... so many opinions on this
    mcharfauros likes this.
  10. Mar 30, 2019 at 4:02 PM
    #530
    JoeCOVA
    Joe
    Colorado Springs
    Most gear manufacturers and differential shops will recommend the heavier oil.
    It will protect the gears better and won’t break down as fast as lighter oils.
    TacoNesian and mcharfauros like this.
  11. Mar 30, 2019 at 4:05 PM
    #531
    Mack411
    thank you, we are only due to change rear diff at 500 miles correct?
    85 140 Lucas non synthetic I was told
    thanks, I'm pretty sure he said its only necessary to change the rear at 500 miles. Does this sound accurate?
  12. Mar 30, 2019 at 4:29 PM
    #532
    alexplb
    Is it about 4 quarts that we need ?
  13. Mar 30, 2019 at 4:31 PM
    #533
    Mack411
    2017 Trd off road auto 4.2 qts
    alexplb[QUOTED] likes this.
  14. Mar 30, 2019 at 4:32 PM
    #534
    JoeCOVA
    Joe
    Colorado Springs
    Technically you should be performing the break in on both diffs and will need to change both oils.
  15. Mar 30, 2019 at 4:35 PM
    #535
    Mack411
    I kind of thought that would make sense I wonder why Ecgs said only rear oil changed?
  16. Mar 30, 2019 at 4:36 PM
    #536
    mcharfauros
    MO
    Dumb Truck Thangs
    @JoeCOVA from what I recall your set was cryo treated correct?
    Mack411 likes this.
  17. Mar 30, 2019 at 4:39 PM
    #537
    JoeCOVA
    Joe
    Colorado Springs
    I can only assume they mentioned only the rear because that’s what you use the bulk of the time. It’s somewhat impractical to run 500 miles in 4x4 for most people. The front diff has to run heat cycles like the rear and perform a break in.
    Yes Sir!
  18. Mar 30, 2019 at 4:44 PM
    #538
    mcharfauros
    MO
    Dumb Truck Thangs
    Definitely looking into the re-gear and locker install sooner than later. How did you manage the front gear set break-in?
  19. Mar 30, 2019 at 4:47 PM
    #539
    alexplb
    I was also told the same thing. Front gears pull and don’t push like the rear so technically they don’t have the same kind of stress as rear diff does. I ran mine for a bit in a 4x4 just to put some miles on front as well.
    Mack411[QUOTED] likes this.
  20. Mar 30, 2019 at 6:25 PM
    #540
    JoeCOVA
    Joe
    Colorado Springs
    Mine are also REM polished which eliminates that break-in but I just did it on the highway, ran it on the long stretches.
    Mack411 and mcharfauros[QUOTED] like this.
