The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.2%
  2. 85w-140
    44.0%
  3. Other
    8.3%
  4. 75W-110
    5.5%
  1. Apr 5, 2019 at 5:12 PM
    #561
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    I now have a whining noise at higher speeds and when decelerating which is louder at higher speeds.Idk what to even do but i'm desperate at this point bc I just don't want to mess anything up. It really all feels ok as far as shifting and driving but the whine just doesn't seem it should be there. East coast gear supply and a local well known mechanic that does a lot of gear work honestly on jeeps says that aftermarket gears will just be louder and that things should be fine as long as everything seems normal other than the whine and it doesn't get worse. At lower speeds like 50 or below its almost non existent. I also just had new suspension installed and I do think i need some adjustments to be perfect there,i had a light light whine even after the lift and before the gears and had some pretty heavy vibrations at first but putting a couple hundred pounds in the bed brought the rear down some and helped the vibrations out almost completely. About advice would be greatly appreciated, any one else dealing with this? Are these gears really just louder and do this? Should I be concerned? Is there anything I should or can do to help it? Thanks
  2. Apr 5, 2019 at 6:10 PM
    #562
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    I have a gear whine around 70. It’s pretty much non existent below that. Pretty common to have gear whine with aftermarket gears. Not sure why.
    Mack411[QUOTED] and mcharfauros like this.
  3. Apr 5, 2019 at 6:31 PM
    #563
    Mack411
    Does it seem more upon declaration at higher speeds?I just don't know what's an acceptable amount of noise/whine or not honestly, as I said I'm just trying to do everything without any issues and this far I've followed everything to a T as recommended. It seems to run great, shifts smoothly and pulls good on the inclines and roads I used to have trouble on with an empty bed and I've had about 250lbs extra in the bed all week!Does the whining i'm dealing with possibly get any better, i'm still only at about 744 miles since install
    rlx02 likes this.
  4. Apr 5, 2019 at 9:00 PM
    #564
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Two biggest reasons;
    -Performance gears are cut for performance, not NVH
    -Shorter gears have fewer teeth on the pinion gear
    3.91=43/11 tooth count
    5.29=37/7 tooth count
    xxTacocaTxx, Paul631 and rlx02 like this.
  5. Apr 8, 2019 at 5:30 AM
    #565
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Me, my dad, and a buddy got my gears put in this weekend. So far ive babied it but can already tell a bit of a difference. Now to get them broke in.
    JoeCOVA[OP] and mcharfauros like this.
  6. Apr 9, 2019 at 10:53 AM
    #566
    SrSquirrel
    SrSquirrel New Member
    Dave
    Just an FYI for anyone looking to get 5.29's from Nitro in the near future, they are currently on back order for the next 3 to 4 months. I found out the hard way!
    JoeCOVA[OP], Rus$ and tweakit88 like this.
  7. Apr 9, 2019 at 11:51 AM
    #567
    Cavalry_PRO
    Cavalry_PRO Well-Known Member
    Ian
    Los Angeles, ca
    Cavalry blue
    Stock
    Sub
    Synergy001 likes this.
  8. Apr 9, 2019 at 12:29 PM
    #568
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Pretty fuckin’ stoked for you @tweakit88 cant wait to catch up in TN for the ATR 2019
    Synergy001 and tweakit88[QUOTED] like this.
  9. Apr 9, 2019 at 12:31 PM
    #569
    tweakit88
    Leroy IL
    Only the best.
    Man i cant wait either. Thats gunna be a damn good trip for sure.
    mcharfauros[QUOTED] likes this.
  10. Apr 12, 2019 at 10:39 AM
    #570
    Hunter399
    Hunter399 Well-Known Member
    2018 White Tacoma TRD Off-Road
    TRD Pro Grill, TRD Pro skid plate, tuff skins stickers, rekgen mudflaps, 33'' tires, 17'' wheels. Nitro 5.29 Gears. Bilstein 8112 front/8100 rears. Icon delta joint UCA’s and RXT leaf pack. Baja designs Fog, squadron ditch lights, and 30” S8 light bar.
    Can someone elaborate on the governing issue? I was dead set on 5.29’s, but the governing issue has me worried.
  11. Apr 12, 2019 at 10:46 AM
    #571
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    I seriously don't think there is an issue. Currently no issues for me [5.29s+33s] -- I have yet to find the governor at all during my ownership of the truck. The gears should have basically nothing to do with the speedo as the Tacomas read off the ABS sensor unless I am mistaken.
    Hunter399[QUOTED] likes this.
  12. Apr 12, 2019 at 11:23 AM
    #572
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Correct. The speed is measured off the ABS sensors.
  13. Apr 12, 2019 at 11:23 AM
    #573
    Hunter399
    Thanks for the reply, maybe it’s just a few rare circumstances. I am pretty much stock on 33” tires and sliders. Another thing i have heard is that the 4.88’s get better gas mileage over 5.29’s? Doesn’t make sense to me as lower gears would be better mileage?
  14. Apr 12, 2019 at 11:36 AM
    #574
    JoeCOVA
    Joe
    Colorado Springs
    Lower gears getting better mileage is a bit of a myth and I don't have any empirical data to support the claim. Moving from stock gears 3.90 to 5.29s on stock tires I lost an average of 1 mpg combined. I lost much more if I was driving exclusively stop-and-go or city driving.
    The biggest hit to mpg is tire size. When I shifted to 35s my mpg ranges between 13-16mpgs. I never ran 35s on stock gearing so I can't account for whether or not mpg is improved with lower gearing on larger tires.
    Most people are reporting a slight mpg increase with the lower gearing and larger tires but I have seen no real metrics to support it so it's a bit anecdotal
    mcharfauros likes this.
  15. Apr 12, 2019 at 11:41 AM
    #575
    Luisd1215
    Luisd1215 New Member
    Luis
    2019 Cavalry Blue DCSB Off-Road
    5100s & OME 888 up front with Dirt King Uniball UCAs and 5160s with Icon AAL in the rear. 285/70R17 on 17x8.5 Method 312s.
    Now that you have the 35s how’s it driving overall?
  16. Apr 12, 2019 at 12:14 PM
    #576
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Yep, I never really understood that either. The whole engine efficiency, torque and HP curves, transmissions, drive train efficiency, vehicle weight, geography/terrain, driving style makes the whole thing murky and unpredictable from one person to another. To say "____ tire size and ____ gearing with result in the better mpg." is silly. I throw that whole idea of "lower rpm gets better mileage" BS in with the other offroad internet myths like "beadlocks are illegal".
  17. Apr 12, 2019 at 1:21 PM
    #577
    Hunter399
    Thanks for the input guys! Sorry if it was a dumb question just trying to decide what route to go with.
  18. Apr 12, 2019 at 2:10 PM
    #578
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    BUT, what if the speed limiter is governed by rpm/gear, or some other calculated data, rather than just wheel speed alone? That would explain why the limiter varies between vehicles with different gear/tire diameter setups...
    Disclaimer: I have no actual answer, just thinking out loud...
  19. Apr 12, 2019 at 2:21 PM
    #579
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    TS7xTaco[QUOTED] likes this.
  20. Apr 12, 2019 at 7:15 PM
    #580
    H3llRid3r
    SLcUT
    What the cpu does with the data, I can’t say because I don’t know.
