The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. May 1, 2019 at 7:23 PM
    #721
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    Are you driving up to Washington or is there a location in Oregon? I live in Portland BTW.
  2. May 1, 2019 at 11:05 PM
    #722
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    I drove up to their location in Cashmere, WA and spent the night at Leavenworth while they had my truck
    rlx02 and mcharfauros like this.
  3. May 2, 2019 at 5:37 AM
    #723
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Seen those pics from Chris, and Charlie up at Just Differentials. Hella stoked for you brotha!
    Tacomania and Synergy001[QUOTED] like this.
  4. May 2, 2019 at 6:21 AM
    #724
    Tofuma
    Tofuma Active Member
    Tony
    San Francisco
    2019 Cement Grey TRD OR DCLB
    Nice, I literally just did the same today. Drove 14 hours from norcal straight to JT diffs. If all goes well I should be breaking it in on my drive back home in 2 days.
  5. May 2, 2019 at 8:10 AM
    #725
    Synergy001
    PDX
    Nice! The guys are super chill at the shop. You won’t regret it once u get your truck back.
    mcharfauros likes this.
  6. May 2, 2019 at 8:11 AM
    #726
    Synergy001
    PDX
    Thanks brotha!
    mcharfauros[QUOTED] likes this.
  7. May 2, 2019 at 8:21 AM
    #727
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Meee, so much nicer on rockclimbs and hils, very little effort is needed to bump up onto boulders, when before even in low it took some throttle. And 4hi can actually be used again. Before 4hi on any decent hill just wouldnt happen, the truck would bog so bad.
    KGTaco[QUOTED], rlx02 and mcharfauros like this.
  8. May 2, 2019 at 11:20 AM
    #728
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    Thanks for the response! Definitely 4hi is not useable for any incline as it is lol
    I might make the switch and add a front locker while I'm at it
    H3llRid3r and tweakit88[QUOTED] like this.
  9. May 2, 2019 at 11:29 AM
    #729
    tweakit88
    Leroy IL
    Only the best.
    I thought about it, but i wheel pretty hard and id break to many axles if i did that.
    alexplb, mcharfauros and rlx02 like this.
  10. May 3, 2019 at 5:14 AM
    #730
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Looked into having ECGS provide and install Nitro 5.29's, but was advised both Nitro and ECGS are out of the 5.29 kits...and no real definitive ETA for them being restocked. The pricing seems reasonable, not to mention I'm located between Richmond and Virginia Beach, so ECGS in Raleigh, NC isn't that far of a trip, coupled with their reputation and warranty, it almost is a no-brainer to use them both for purchasing and installing the 5.29 package.
    I guess I'm kind of like @inksin as I am not built up entirely for 5.29's (but running stock 3.90 on my '17 TRD OR DCSB automatic), but between currently running 33's, @Mobtown Offroad bolt-on sliders (future full skids in the works) and hauling a 6'4"x10' trailer typically with loaded with wood (for our woodstove, as well as trash/recycle runs to the local dump), the 5.29 seemed like the better option compared to 4.88s...granted most of my trailer hauling involves interstate driving with speed limits ranging from 65-70mph and typical round trip is about 70 miles (depending on where the tree guy's jobs are located).
    Any insight, input, etc. is always welcomed!
    inksin and tweakit88 like this.
  11. May 7, 2019 at 2:38 PM
    #731
    Stump_Pro
    Stump_Pro New Member
    White TRD Pro
    33 tires 3/2 lift
    How does it
    Do pulling trailer will it
    Pull in 5,6 and if so are you hurting transmition pulling in 5,6 where those gears are overdrive gears?
    So
  12. May 7, 2019 at 2:52 PM
    #732
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    5.29 will pull better then anything else cause they're lower gears, making our RPMs higher where the power is. OVtune also mentioned that we should be using ECT when we pull as well to avoid constant downshifting which makes sense. I need to stop buying other stuff so I can get my 4.30s swapped out for the 5.29s in my garage. :annoyed:
    If it don't happen soon I'll probably just sell them to fund my crawler project. :anonymous:
    JoeCOVA[OP] likes this.
  13. May 7, 2019 at 11:30 PM
    #733
    alexplb
    alexplb Well-Known Member
    hopefully just the nose... :typing:
    Gazziza likes this.
  14. May 8, 2019 at 2:05 AM
    #734
    Dbodz58
    Dbodz58 Active Member
    Dylan
    Hawaio
    2017 Tacoma TRDOR-SW 6MT
    Go Rhino Raptor Running Boards, switch pros 8100, ditch lights, hidden bumper lights, OEM+ and Prinsu Roof Rack.
    @JoeCOVA sorry if this seems lazy, but you seem to have a really good grip on the math/statistics, but I noticed a lot of it is for ATs going with 5.29s, is there any comparisons/ other posts that focus on the MTs? Since they have slightly different trans gearing? In other words would an MT with 4.88 be comparable to an AT with 5.29s?
    The Pirate likes this.
  15. May 8, 2019 at 7:10 AM
    #735
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Any shops you guys recommend in Texas or florida? Before i drive out to nitro gear in Washington, rogue offroad in vegas, etc
    Alesimo likes this.
  16. May 8, 2019 at 7:40 AM
    #736
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    @Trident904 you got your gears yet?
  17. May 8, 2019 at 8:08 AM
    #737
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    17 DCLB AT w/ 5.29's and 295/70r17's. Just came home from Texas Toyota Jamboree at Barnwell Mt.. The lower gears were a godsend when decending steep loose terrain. Just shift to S and 1st. then let the gears and motor walk you down, no brakes needed. Also much easier to traverse steep inclines and ledges without a ton of throttle input. Slow and controlled is far better than fast and on the edge of control.
    Bigdaddy4760 and mcharfauros like this.
  18. May 8, 2019 at 8:09 AM
    #738
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    How about ECGS in NC?
  19. May 8, 2019 at 8:10 AM
    #739
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Texas Auto Gear in Magnolia TX did mine. They are just a bit north of Houston. Great job and a decent price.
    Bigdaddy4760 likes this.
  20. May 8, 2019 at 8:11 AM
    #740
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Gears arrived, hoping to get them installed next week. How much lucas 85-140 oil do I need for both? 1 gallon?
