The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Jun 19, 2019 at 1:45 PM
    #841
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Yep ECU doesn’t know the R&P. That’s why we are hitting cutoff at ~85 as opposed to 104mph. The ECU thinks the truck must be going 104 because it’s in 6th gear at 2600rpm. Because we changed gearing we hit it at a lower speed.
    @JoeCOVA do you know what ECU version your on? Maybe this isn’t necessarily related to vintage but to ECU version. I am on A61.
    @im2122 are you A60 or A61?
    xxTacocaTxx likes this.
  2. Jun 19, 2019 at 2:11 PM
    #842
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    This is easy to prove with a scan tool that reads data parameters. Look at fuel cut status when hitting stated speeds. Until then, y'all just toying with each others emotions.
  3. Jun 19, 2019 at 3:11 PM
    #843
    im2122
    im2122 Well-Known Member
    2018 OR
    Eibach Pro Truck lift, Icon AAL, TJM front and rear bumpers, RCI Sliders/Skids, 285 Duratrac’s, mk6/blk rhino roku, Ovtune
    I’m on a61 with ovtune 1.05.1 Gearlock 91 Octane
    I have a scanner app that ill use later.
  4. Jun 19, 2019 at 4:05 PM
    #844
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    I'm not on a tune. I'm stock.
    I definitely can't speak to your trucks but I know my truck does not limit the speed because its at 2600 rpms in 6th gear. The would have made my trucks top speed 77 mph. My truck cruises all the time at higher rpms in 6th gear.
    When I was in Utah I easily hit 90 on stock tires with 5.29s..
    mcharfauros likes this.
  5. Jun 19, 2019 at 4:33 PM
    #845
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Got to get into the nittiust of the gritties!
    mcharfauros and JoeCOVA[OP] like this.
  6. Jun 19, 2019 at 5:27 PM
    #846
    sixlxvi
    sixlxvi "break stuff"
    Is it true the locker seal is not compatible with synthetic oil? Or is that only for the ARB air locker?
    Edit: I got the Lucas 80w140 non-synthetic anyway since that has a lot of recommendations.
  7. Jun 19, 2019 at 6:58 PM
    #847
    im2122
    2018 OR
    https://youtu.be/3tOG2xuYuig
    https://youtu.be/YNQdskCSdV0
    I made two screen recordings. The first video is 6th gear. Notice the two gauges at the top. The right is the accelerator pedal position, the left is the actual throttle position. Neither one goes to 100%, not sure why.
    I was wrong about fuel cut off, the truck doesn’t cut fuel when it’s limiting speed, it limits the throttle position.
    Notice when on the first one at the :06 mark the throttle is limited to 50% even though the pedal position is still max. Then when the truck is still speeding up(0:11) it shuts it all the way down to 24% until the truck speed goes down, then slowly ramping it back up. Notice I’m both videos the accelerator pedal position doesn’t change.
    I posted two to show what the lower gears do, in 4th it allows the truck to almost read 90. As you can see the gps speed is significantly higher, so I’m not too concerned with the limitations, but it’s good to know when you’re overtaking someone.
    You may notice in the second video, there is a point where both the vehicle speed and gps speed match, that is because I didn’t set the range high enough on the gps gauge. Notice it maxes at 90.
  8. Jun 19, 2019 at 7:19 PM
    #848
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    I have a set of used nitro 4.88s front and rear if anyones interested
  9. Jun 20, 2019 at 6:12 AM
    #849
    JoeCOVA
    Joe
    Colorado Springs
    I’m sure there are some people interested in the 4.88 thread. :)
  10. Jun 20, 2019 at 6:23 AM
    #850
    JoeCOVA
    Joe
    Colorado Springs
    Those videos are weird. It shows an increase in rpm when the throttle is pulled back. It also shows a massive spike in speed when you lift the accelerator position.
    5.29 and 33s at 90 mph is 2800 rpm. That’s where you were cut off.
    5.29 and 33s at 100 mph in 4th is 5300 rpm. That’s where you were cut off.
    EDIT. My calculations were off but now corrected. So basically you are limited to 90 in 6th but in 4th can go to almost 100
    Good info if anyone ever intends to race their truck.
    I wonder now if it’s an Overdrive thing. Try a test in 5th
  11. Jun 20, 2019 at 11:01 AM
    #851
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Best decision ever going with 5.29 at 1000+ lbs on a 3rd gen AT and on 285/75/17’s the before and after difference is HUGE!
  12. Jun 20, 2019 at 11:28 AM
    #852
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    It’s the upgrade you kick yourself for not doing sooner! Welcome to the club!!!
  13. Jun 20, 2019 at 1:02 PM
    #853
    TWTaco
    TWTaco Well-Known Member
    Dave
    How many have changed from 4.88's to 5.29's ?
  14. Jun 20, 2019 at 1:04 PM
    #854
    Chunk
    2016 DCSB OR
    Baby Ruth
    Better question is how many have changed from 5.29 to 4.88z
  15. Jun 20, 2019 at 1:07 PM
    #855
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
  16. Jun 20, 2019 at 2:17 PM
    #856
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    How much?
  17. Jun 20, 2019 at 2:19 PM
    #857
    Chunk
    2016 DCSB OR
    Baby Ruth
    But they are 4.88!! Go big or go home!
  18. Jun 20, 2019 at 2:20 PM
    #858
    Usethe2nd
    Justin
    Fall city
    Welded metal
    No one has replied to my question about a second gen 6MT on 5.29’s yet
  19. Jun 20, 2019 at 2:23 PM
    #859
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Most likely because this is in the third gen section.
    thedriza, PB FAB, mcharfauros and 3 others like this.
  20. Jun 20, 2019 at 2:41 PM
    #860
    Uscgamecock7
    Nick
    West Columbia, SC
    They are for a 16+
