The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.2%
  2. 85w-140
    44.3%
  3. Other
    8.0%
  4. 75W-110
    5.5%
  1. Sep 19, 2018 at 2:29 PM
    #81
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Hindz57 likes this.
  2. Sep 20, 2018 at 9:17 AM
    #82
    Hindz57
    Hindz57 New Member
    Patrick
    1979 Toyota pickup on 40s 4locked hydro
    Full hydro Dirty 30s Trunion eliminator Arb studs throughout Dual cases (4.7-2.28) 254-1 crawl ratio 40” irocks 5.29 gears Interior cage Pro suspension seats Prp harnesses Chevy 63” springs Dual shackle Ruf swap 1” bore master cylinder And a bunch more shit
    I’m running 5.29 gears and the only thing I don’t like is that the piñon shaft is so small!! I’ve snapped the piñon before when one of my 40”s got sucked under a log and started binding. Probably would have broke the shaft or hub if they where stock. I have since gone from arb hub studs back to stock to provide my axle a cheaper weak link that’s an easy trail fix.
    blairrad and RedBeard1 like this.
  3. Sep 20, 2018 at 11:13 AM
    #83
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Apples to oranges as the 8.75 rear locker is yuge compared to what you're running. The gear contact patch is almost 2 times the surface area and the 5.29 pinion gear in the 8.75 is larger than a stock 4.10 in in an 8". I'm going to have a custom housing built around one of these for my 4runner, though due to power band differences and transmission ratios only run 4.88s.
    Now the non off road trucks, sorry about your 8" luck. Your rear differential is smaller in ring and pinion size than your front.
    johntoyota, 0uTkAsT, rlx02 and 2 others like this.
  4. Sep 24, 2018 at 8:09 AM
    #84
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    The recent factory elocker thread had a comment about how much smoother ATRAC seems in the manual, with 4.30s, vs the auto. Have you tried your CC and MTS with the new gears @JoeCOVA ?
    K_Sandhu likes this.
  5. Sep 24, 2018 at 8:35 AM
    #85
    K_Sandhu
    K_Sandhu Well-Known Member
    Karan
    Castro Valley, CA
    2017 Double cab TRD off-road 4x4 long bed
    Damm... I was hoping after switching to 5.29's my top speed would be limited to less than 4-5 mph, but I guess not. With stock gears (3.90) I was able to do close to 10 mph in 1st gear in 4Lo and that sucked big time when coming down the steep hill during off roading. I guess I will be still riding those brakes.
    Bullnettles and mcharfauros like this.
  6. Sep 24, 2018 at 8:43 AM
    #86
    K_Sandhu
    Karan
    Castro Valley, CA
    I am not sure how changing gear would make any difference in this case because Toyota's CC uses brakes not the diff.
  7. Sep 24, 2018 at 8:44 AM
    #87
    Enfield1
    Brad
    Bryan, Tx
    12mph@5000rpms
    JoeCOVA[QUOTED][OP] likes this.
  8. Sep 24, 2018 at 8:48 AM
    #88
    Enfield1
    Brad
    Bryan, Tx
  9. Sep 24, 2018 at 8:59 AM
    #89
    K_Sandhu
    Karan
    Castro Valley, CA
    I am not sure what he mean exactly by "tractable". If he is referring to engaging and disengaging, I am sure MT has an advantage. At first when I bought the truck I was having tough time locking the rear diff and getting in to 4Lo, but after playing around I found out that I was moving the truck too much. But when it comes to CC or MTS I am not sure what he means by "tractable".
    JoeCOVA[OP] likes this.
  10. Sep 24, 2018 at 10:06 AM
    #90
    Enfield1
    Brad
    Bryan, Tx
    I was just assuming "less throttle manipulation" which makes sense, due to torque multiplication. Look at marlin crawler's tacobox vid...
    K_Sandhu[QUOTED] likes this.
  11. Sep 24, 2018 at 11:50 AM
    #91
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    With what size tires? I am guessing if I run 33-34 I would get to slower at that rpm.
    KanPanic and JoeCOVA[OP] like this.
  12. Sep 24, 2018 at 11:59 AM
    #92
    Enfield1
    Brad
    Bryan, Tx
    That's stock tires. Bigger tires will raise your effective great ratio, so you should go sightly faster.
  13. Sep 24, 2018 at 12:25 PM
    #93
    mauidogg
    16 DCSB TRDOR
    Crap. Sorry I should have quoted @JoeCOVA since I believe he has largertires. I am assuming that with 5.29 gears and smaller than 35” tires I should be able to slower for the given rpm.
    Enfield1[QUOTED] likes this.
  14. Sep 24, 2018 at 5:21 PM
    #94
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    I havent tried CC or MTS with the new gears but I have only a limited sample from the stock gears. CC was terrible the two times I used it and just bucked all over, and MTS is a new feature that I havent explored much. I'm a little old school in that I just use my locker when needed but MTS is something I will definitely try more.
    We have some offroad trips coming up in the next couple weeks that I can test out.
    K_Sandhu and Enfield1[QUOTED] like this.
  15. Sep 24, 2018 at 5:28 PM
    #95
    JoeCOVA
    Joe
    Colorado Springs
    I just filled the tank for the first time running the new gears on stock tires and mpg was 18.6. Not alarming however 200 miles were on I-25 at about 70mph, the rest were local driving.
    I would occasionally get into the 18s when driving exclusively local or during offroad trips so I am led to believe that there is a slight mpg drop by about 1 mpg. This is likely due to two factors:
    1. The truck drives much better and been having a little more fun with it so this likely contributed to loss of mpg
    2. Truck no longer operates at optimum engine levels for fuel efficiency as well as the general increase in rpms across all gears.
    It seems that the bulk of mpg loss is from local driving, engine runs higher and shifts much faster.
    jholc21, rlx02 and K_Sandhu like this.
  16. Sep 24, 2018 at 6:28 PM
    #96
    Enfield1
    Brad
    Bryan, Tx
    That's crazy. Math don't lie, but I really figured you would be revving to the sky with those gears.
    Interbeing likes this.
  17. Sep 24, 2018 at 6:36 PM
    #97
    K_Sandhu
    Karan
    Castro Valley, CA
    I can care less about CC. Like you said, I have tried it couple of times and hated it. I feel I can do a better job than CC with all electronics turned off in 4Lo. I haven't tried MTS and don't know how it can help. I just drop down to 4Lo and lock the diff when needed and just drive kinda person.
  18. Sep 24, 2018 at 10:37 PM
    #98
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    You're still on your stock tires though right?
  19. Sep 25, 2018 at 5:24 AM
    #99
    JoeCOVA
    Joe
    Colorado Springs
    Yup. Just got my wheels yesterday but need new valve stems. I hope to have the 35s ready to go by the end of the week.
    SpeySquatch, 90yota and rlx02[QUOTED] like this.
  20. Sep 25, 2018 at 7:20 AM
    #100
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Great! I'm looking forward to how the rpms and mpgs are affected with the 35s. So far, it looks like 5.29s are the way to go if you have some weight and going to 35s.
    mcharfauros likes this.
