The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Oct 29, 2019 at 11:50 AM
    #1601
    Coreysamson
    Coreysamson Well-Known Member
    Corey
    Nassau Bay Tx
    2018 cavalry blue pro
    6” BDS lift w/Fox dsc on 35x12.50R18 Nitto trail grapplers Method wheels
    Out of curiosity, how many of you guys are running 35’s?
  2. Oct 29, 2019 at 11:54 AM
    #1602
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    You won’t see mpgs gains really especially as you move up in tire size.
    In my first two posts you can see I dropped MPG with the regear and it continued to drop from stock to 33s and 35s
    300 miles per tank with a 33” tire sounds about right.
    I hope you read this thread before taking the plunge.
    Speeds over 65 will tank your MPG, likewise with stop and go short distance stuff
    pr0b[QUOTED] and mcharfauros like this.
  3. Oct 29, 2019 at 12:13 PM
    #1603
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I need you guys to stop me or tell me I am nuts.....
    It's the whole 5.29 with MT question. I'm losing sleep. Should I just go 4.30 to 4.88?
    Is 4.30 to 5.29 gearing just too much?
    Trails, mud, snow......Hills more hills Need lower gears!
    Help.
  4. Oct 29, 2019 at 12:17 PM
    #1604
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Is it worth the few thousand dollars to go from .3 to .88?
    Edit: just saying if you're looking at an upgrade the at benefits much more but if you're an mt and looking to upgrade I'd imagine 529 are more noticeable
    Pablo8[QUOTED] likes this.
  5. Oct 29, 2019 at 12:22 PM
    #1605
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    I can look at that two ways.
    Why do anything at all?
    Why not go all the way?
    I am adding F and R air lockers.
    Will the higher revs drive me nuts?
    Will I be shifting more/too much ?
    Will I go crazy with occasional freeway driving?
    RyanDCLB likes this.
  6. Oct 29, 2019 at 12:41 PM
    #1606
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    What size tires are you going to run? I went with 4:88's on stock tires, but If I had your truck with full lockers, full skids, and larger tires, then I'd go with 5:29's. The guys at ECGS are good at giving advice. Especially if you're ordering over 4g's worth of parts from them. My post on price breakdown is here.
  7. Oct 29, 2019 at 12:50 PM
    #1607
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    31.5" until they wear out then 33" tires.
    I will talk more with Mule.
  8. Oct 29, 2019 at 1:15 PM
    #1608
    RyanDCLB
    4/19 DCLBOR
    Believe it or not, the sissy crawl control feature helped me make my decision. With MT, you have to rely more on the gears for downhill descents.
  9. Oct 29, 2019 at 1:18 PM
    #1609
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    How much highway/freeway do you do ? MPH?
  10. Oct 29, 2019 at 1:23 PM
    #1610
    RyanDCLB
    4/19 DCLBOR
    A lot of highway miles when camping, etc., and, at a high rate of speed (when I'm not towing the boat) :notsure::burnrubber:
    Pablo8 likes this.
  11. Oct 29, 2019 at 1:26 PM
    #1611
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    So how are the RPMs cruising down flats and straight runs down freeway hills?
  12. Oct 29, 2019 at 1:33 PM
    #1612
    RyanDCLB
    4/19 DCLBOR
    The RPMs seem good with 4:88's and OVtune as long as I keep it below 70ish. The truck still hunts from 4th gear to 5th when moderately loaded while going above 70.
    Pablo8 likes this.
  13. Oct 29, 2019 at 1:38 PM
    #1613
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Aside from the hunting part that type of input would be extremely valuable from a MT owner particularly with 5.29, but 4.88 as well.
  14. Oct 29, 2019 at 1:43 PM
    #1614
    JoeCOVA
    Joe
    Colorado Springs
    You dont use CC for descents, you downshift just like the MT
    Just go big dude and wheel it hard.
    Alesimo and mcharfauros like this.
  15. Oct 29, 2019 at 1:46 PM
    #1615
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Well I do typically go too conservative on such things and end up full of regret.
  16. Oct 29, 2019 at 1:57 PM
    #1616
    RyanDCLB
    4/19 DCLBOR
    Right at 70, the truck literally can't decide between 4th and 5th and cycles back and forth. I'm hopeful the next OVtune 2.0 release will change this, but I doubt it. At some point the wind resistance is too much.
    I agree, and that's typically what I would do.
    But they sure do use it at 2:00 minutes in on both these videos...
  17. Oct 29, 2019 at 3:33 PM
    #1617
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Lucas SAE 85W-140 Gear Oil. I believe as recommended by ECGS and used by the installer.
  18. Oct 29, 2019 at 3:37 PM
    #1618
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    That howling sound is not so much noticeable now. However I’m now getting this “Whir-Whir...” pulsing/pulsating type of annoying sound/vibration between 60mph-70mph and then it goes away over that speed. And of course I didn’t have this before the ReGear. Fyi, ECGS clamshell bushing was installed before the ReGear and the shop did install a new with the Re-Gear.
    When driving downhill, that “Whir-Whir” pulsating sound/mini vibration is still there but definitely not as noticeable as driving uphill.
    Checked with my shop to get his thoughts and he mentioned someone else had about same sound. Ended up being his driveshaft. It was unbalanced or the U-Joint was going out.
    Any thoughts guys?
  19. Oct 29, 2019 at 7:44 PM
    #1619
    JoeCOVA
    Joe
    Colorado Springs
    Bummer, was hoping for an offroad video
    PcBuilder14 and mcharfauros like this.
  20. Oct 30, 2019 at 6:08 AM
    #1620
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    @JoeCOVA
    In your opinion, would the benefits of cryo out weight, the void in warranty of said gears after cryo; if I am the kind of person who uses this rig as a camper/hauler mainly.
    Aka I don’t bounce my taco on anything, I creep up what I can.
    The FJC is my bouncer.
    I know it’s a loaded question, I am about to buy these from my buddies shop and that’s the last thought in this process.
    JoeCOVA[OP] and mcharfauros like this.
