The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Nov 11, 2019 at 9:44 AM
    #1661
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Keel us posted if possible. Sounds like a stump puller!
    BSCowboy[QUOTED] likes this.
  2. Nov 11, 2019 at 9:54 AM
    #1662
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Was discussing 5.29's with someone and he said to achieve the higher ratios, the pinion gear has to become smaller and will make it the weak point in the driveline. What are people thoughts about this? Hate to break a pinion going rock crawling in moab.
  3. Nov 11, 2019 at 12:37 PM
    #1663
    4X42HEL
    4X42HEL Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    To achieve a numerically higher ratio, the pinion does have to get smaller (in relation to the ring). The reason being is because the carrier/housing can't grow in size to accommodate a taller ring gear.
    That being said, a smaller pinion head can technically translate to being weaker. But I don't think that it's fair to blame the smaller pinion as the "weak point". I
    if your pinion head breaks (not tooth, but neck) then I challenge the setup. Is someone running 40" super swampers on a tiny stock front clamshell with a thin 5.29? And a supercharger under the hood?
    If so, I can see how it would break.
    If a setup is well balanced (axles, gearing, tire size), I think it will be fine.
  4. Nov 11, 2019 at 4:53 PM
    #1664
    taco.fighter
    taco.fighter Active Member
    brian
    17 Tacoma TRD OR
    Icon Suspension, C4 Winch carrier, Victory skids roof rack and rear bumper
    when I talked to the Nitro gear guy over the phone in the course of deciding between 4.88 and 5.29, that came up, and while it is true, I agree with them that the bigger problem is hanging 35 or 37 inch tires on the ends of a sub nine inch diff. I REALLY doubt I will ever go bigger than 33's. I cant get there on those, I'll find another place to go.
    Nu2taco likes this.
  5. Nov 12, 2019 at 7:14 AM
    #1665
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    :spy:
    Hoping to see a black friday deal from ECGS for the assembled third members.
    whatstcp likes this.
  6. Nov 12, 2019 at 7:20 AM
    #1666
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    As of now, 5.29 gears from ECGS for complete set is $1400. If you have such a new truck that you dont need new bearings, you can get the gear sets, minor install kits, and clamshell bushing for $902. They usually run a 10% black friday deal on everything but fully assembled thirds. So full set for $1250 or minor set for $810. If you guys send me your diffs, I can do the gear set up for less than $500. If you bring me your truck, I can get it done for less than $750. Some parts you'll want from Toyota is the rear elocker connector, little blue guy that breaks when you look at it for $20. Then you'll want Toyota front and rear pinion seals. Anyone interested, please send me a PM.
    mcharfauros likes this.
  7. Nov 12, 2019 at 7:26 AM
    #1667
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I can do an assembled front and rear (w/REM) for less than $2k, including gear oil, tax, and return shipping.
    Looks like you would be a bit cheaper, but unfortunately I can't afford to have my truck down as it is my only vehicle.
  8. Nov 12, 2019 at 7:29 AM
    #1668
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    The thing with me is that I am cheaper, if scheduled correctly I can be done same day, but I cant offer a warranty. I do stand by my work man ship though.
  9. Nov 12, 2019 at 7:29 AM
    #1669
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Man I just don't mechanically know that front diff.
    Maybe I should start a new thread.
    My shop Mule Expedition says that when air locker is installed in front no need to install/replace the needle bearing with the bushing. The air locker somehow takes it out of the equation. Anyone know?
    thefatkid likes this.
  10. Nov 12, 2019 at 7:32 AM
    #1670
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yes, the new carrier replaces the toyota needle bearings so the clamshell bushing isnt needed. If you need to know anything at all about the front clam, let me know and I'll be happy to help.
    Pablo8[QUOTED] and thefatkid like this.
  11. Nov 12, 2019 at 7:33 AM
    #1671
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Yes the ARB eliminates the carrier needle bearings in favor of bushings
    ^Texoma beat me while typing^
    Texoma and mcharfauros like this.
  12. Nov 12, 2019 at 7:42 AM
    #1672
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Good information. Thanks!
    Texoma[QUOTED] likes this.
  13. Nov 12, 2019 at 8:18 AM
    #1673
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    What's the break in procedure for the front diff? Throw it in 4hi on straight sections of the highway, and change the oil after a month or so?
  14. Nov 12, 2019 at 8:20 AM
    #1674
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Same as the rear, initial 15-20 min run/cool cycle. Must have 4wd engaged to actually break in, so track your 4wd miles to 500.
  15. Nov 12, 2019 at 8:25 AM
    #1675
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I am ordering the rear with REM, so wasn't planning on any break-in procedure. Just changing the oil at 500mi and 1000mi.
  16. Nov 12, 2019 at 8:29 AM
    #1676
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Even with REM, I would highly recommend that you still go through proper Break-in period. Thats what my Shop told me and I did as careful as possible and documented in detail for my peace of mind.
  17. Nov 12, 2019 at 8:31 AM
    #1677
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Get on ECGS web site and look for Tech Articles. You'll find their explanation of break in procedure. For the front, you must be in 4wd to break in or the R&P wont spin.
  18. Nov 12, 2019 at 8:32 AM
    #1678
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    no kidding :duh:
    :thumbsup:
  19. Nov 12, 2019 at 8:33 AM
    #1679
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    You're the one asking questions, I'm trying to give you the best answer.
    xxTacocaTxx likes this.
  20. Nov 12, 2019 at 8:40 AM
    #1680
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    When I asked my shop regarding front diff break-ins, if I should drive in 4High to engage font diffs:
    His response: “No, that's not the best idea on pavement. The front diff still spins when you're in 2wd enough to break the bearings in.”
