The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.3%
  2. 85w-140
    44.1%
  3. Other
    8.2%
  4. 75W-110
    5.4%
  1. Nov 22, 2019 at 11:07 AM
    #1761
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    You will likely have/want to install a second button for it. I suppose you could probably figure out how to wire it to the stock rear one, but I personally would rather have a button for each locker.
    H3llRid3r likes this.
  2. Nov 22, 2019 at 11:09 AM
    #1762
    Woodzyzewski
    Woodzyzewski Well-Known Member
    Woodrow
    West Virginia
    2018 Inferno TRD Off Road DCSB
    okay sweet. is this Harrup Elocker something I can get from ECGS? This is the first I’ve heard of this option.
  3. Nov 22, 2019 at 11:13 AM
    #1763
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Looks like it:
    https://eastcoastgearsupply.com/i-23993470-toyota-t8-clamshell-harrop-elocker-3-90-up.html
    I would assume they would be able to install it if you are doing a swap, but I do not know for sure. I did not go with a front locker with my 5.29s -- I haven't found a situation that my rear locker won't get me out of, personally. Not recommending that you go one route or another, just some information.
    Woodzyzewski[QUOTED] likes this.
  4. Nov 22, 2019 at 11:34 AM
    #1764
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You only want to lock the front when absolutely necessary. I'd suggest a separate switch for it. You can absolutely get it from ECGS
    mcharfauros likes this.
  5. Nov 22, 2019 at 11:41 AM
    #1765
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    These guys know their stuff. You can get away with some steering wheel turning through some loose junk but you do NOT want both gripping and attempting to purposely turn the vehicle with front locked. Something will need to give. Ditto the back, but of course a bit more leeway there.
  6. Nov 22, 2019 at 2:05 PM
    #1766
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Can someone point to the thread that has the breakin process? Can’t seem to find the page it was discussed.
    @Texoma what’s the oil change periods again?
    The shop has done three heat cycles. Was curious about the recommendation for oil changes. I know everyone has their own opinions on oil, but wanted to ask you. Thanks man
  7. Nov 22, 2019 at 2:59 PM
    #1767
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Go to ECGS web site, scroll to bottom of page and look for tech articles.
    Built2Ride[QUOTED] likes this.
  8. Nov 22, 2019 at 7:48 PM
    #1768
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Picked up the truck today. Gears are definitely pretty loud about every other time I get above 55mph. The shop said it should quiet down over time, especially if I upgrade to larger tires :notsure:
  9. Nov 23, 2019 at 9:09 AM
    #1769
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    That’s an odd statement from the shop. I’d like to know how larger tires would make a difference in diff noise.
  10. Nov 23, 2019 at 9:41 AM
    #1770
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Less rotations less noise:p
    JoeCOVA[QUOTED][OP] likes this.
  11. Nov 23, 2019 at 9:44 AM
    #1771
    PcBuilder14
    Brent
    Nor Cal
    Agreed. Their reasoning was that large tires reduces the speed that everything rotates at. While true, I wouldn’t think that ~3” larger tires would effect the rotational speed that much.
    The last guy that they installed 5.29’s on stock tires for had the same problems. They messed with it and checked things multiple times but could never find anything wrong. When he installed larger tires the sounds mostly went away apparently. I’m skeptical, but I guess I’ll see.
  12. Nov 23, 2019 at 11:32 AM
    #1772
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    What kinda noise?
  13. Nov 23, 2019 at 1:07 PM
    #1773
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    Big tires = more aggressive tread pattern , which in turn = more tire noise so you can’t hear the diff
  14. Nov 23, 2019 at 4:48 PM
    #1774
    PcBuilder14
    Brent
    Nor Cal
    Sounds almost exactly like you’re driving a vehicle with aggressive mud terrains when going a consistent speed above 55mph. Then on decel below 20mph coming to a stop it’s a high pitch whine.
    Only ~120 miles on the rear gears right now.
  15. Nov 23, 2019 at 6:47 PM
    #1775
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Doesn't sound normal but I am no expert.
  16. Nov 24, 2019 at 7:12 AM
    #1776
    taco.fighter
    taco.fighter Active Member
    brian
    17 Tacoma TRD OR
    Icon Suspension, C4 Winch carrier, Victory skids roof rack and rear bumper
    i can >just barely< hear the 5.29s whirring in mine, with 285 BFG AT's, and then only sometimes. i doubt i could produce a video where the sound was detectable. Is the shop that put yours in established, and reliable with standing behind their work? if I had heard discernible noise from my rear end when I picked it up, id have turned around and dropped it back off, and rented a car till it was fixed.
    https://www.knowyourparts.com/technical-resources/drive-train/diagnosing-differential-noise/
    hawaii_dave and Pablo8 like this.
  17. Nov 24, 2019 at 8:47 AM
    #1777
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I know a lot of people recommend ecgs and that’s who I’ll be going with when I regear. For those that have used them. How’s your gear noise?
  18. Nov 24, 2019 at 9:52 AM
    #1778
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    The only noise I have heard out of all the ones I have built is the same noise that most OEM gearsets have. The throttle release whine at 55mph. You almost have to try and make it make this slight noise. Imagine about a second or so noise just as the throttle is released at the range between forward drive load and engine decel braking.
    JoeCOVA[OP] likes this.
  19. Nov 24, 2019 at 10:19 AM
    #1779
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Do lower gears make the torque converter and overdrive disengage with less load?
  20. Nov 24, 2019 at 3:29 PM
    #1780
    PcBuilder14
    Brent
    Nor Cal
    They are very well known in the Las Vegas area and said bring it back if I have any concerns. They average 2 regears a week. I am currently running the stock size tires, so hopefully it’ll go away when I upgrade...
