The 5.29 Mega Thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Jul 6, 2018.
What gear oil do you use
  1. 75W-90
    42.5%
  2. 85w-140
    44.0%
  3. Other
    8.1%
  4. 75W-110
    5.4%
  1. Oct 18, 2018 at 7:25 AM
    #161
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    To the best of my knowledge [and others please feel free to correct me] the speedo/odo run off ONLY the wheel sensors. I recalibrated mine after going up in tire size. I also think that there is no need to recalibrate only for gear ratio.
  2. Oct 18, 2018 at 7:32 AM
    #162
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    As far as I can tell its spot on post regear, I believe all of that is set through the ABS Sensor. Only changing wheel size will have an effect
    0uTkAsT likes this.
  3. Oct 18, 2018 at 8:17 AM
    #163
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    That doesn't sound correct based on everything I have read/seen. I used a hypertech speedo calibrator.
    0uTkAsT[QUOTED] likes this.
  4. Oct 18, 2018 at 8:58 AM
    #164
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    Thanks for the detailed info. I live at 6000 ft. 1-70 and overdrive with these trucks is just not gonna happen except on the downhills. The OV tune makes a big difference and truck will still pull 4th in the fast lane even with the tent on it but it would be nice to have more gearing for 5th and 6th. Toyota really blew the 5th gear ratio on these trucks.
    pop.tremuloides likes this.
  5. Oct 18, 2018 at 8:59 AM
    #165
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    Grears don’t impact speedo on our truck. As the OP mentioned, it’s the ABS Sensor.
    MCDavis likes this.
  6. Oct 18, 2018 at 4:42 PM
    #166
    K_Sandhu
    K_Sandhu Well-Known Member
    Karan
    Castro Valley, CA
    2017 Double cab TRD off-road 4x4 long bed
    Does hypertech spedo calibration works good? I have been thinking about it, but wasn't sure because people had mixed reviews online. Some of the people even said that they don't have the right tools for 3rd gens?
  7. Oct 18, 2018 at 4:50 PM
    #167
    JoeCOVA
    Joe
    Colorado Springs
    As far as I know it works, I plan to use it. My understanding is you only put in the tire size, if you had more info like gear ratio and such it messes all up
    K_Sandhu[QUOTED] likes this.
  8. Oct 18, 2018 at 6:08 PM
    #168
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    works fine for me. I have an install video i made somewhere if you want it. I haven't had any issues in 40k miles
  9. Oct 18, 2018 at 7:08 PM
    #169
    K_Sandhu
    Karan
    Castro Valley, CA
    Can the same device be used for more than one truck or it has a single user license?
  10. Oct 19, 2018 at 7:20 AM
    #170
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Well, the device gets mounted "in between" the dash cluster and the truck. So it's single use in the sense that if you take it out, the truck will revert to stock speed and tach ratios.
    K_Sandhu[QUOTED] and JoeCOVA[OP] like this.
  11. Oct 19, 2018 at 8:04 AM
    #171
    K_Sandhu
    Karan
    Castro Valley, CA
    ahha...I see what you mean. Thanks for the info! I will probably order during holiday if I can find some good deal on it.
    JoeCOVA[OP] likes this.
  12. Oct 19, 2018 at 8:19 AM
    #172
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    https://www.youtube.com/watch?v=rx44N8sImFU&t=2s
    shameless self-promotion but an excellent install video in my opinion. I got mine off Amazon.
  13. Oct 22, 2018 at 3:47 PM
    #173
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    Just ordered my 5.29 gears.
    Tire size is 285/75/16.
    I will post up some info in a few weeks, once they are installed.
    I will then be moving to 285/75/17 and will post reviews again.
    I am a little worried about screaming RPMs, but as @JoeCOVA mentioned.... overdrive should save the day.
    geoyota760, Vitalzone and JoeCOVA[OP] like this.
  14. Oct 22, 2018 at 3:55 PM
    #174
    K_Sandhu
    Karan
    Castro Valley, CA
    RPM aren't too bad. At 70 mph I was at 2200. Which I Don't think is too bad.
    Blackout Z7 likes this.
  15. Oct 22, 2018 at 3:57 PM
    #175
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    thats with 285/75/16?
  16. Oct 22, 2018 at 3:58 PM
    #176
    K_Sandhu
    Karan
    Castro Valley, CA
    No. With 35's
  17. Oct 22, 2018 at 4:00 PM
    #177
    JoeCOVA
    Joe
    Colorado Springs
    If hes at 2200 and I'm at 2400 you will likely be at 2300
  18. Oct 22, 2018 at 4:00 PM
    #178
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    Tedward likes this.
  19. Oct 22, 2018 at 6:02 PM
    #179
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    Are you auto or manual? Im on 285/75/17 manual trans. Either way, the more reviews the better. I’m about ready to drop some cash on gears.
    0uTkAsT likes this.
  20. Oct 23, 2018 at 5:24 PM
    #180
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    I’m auto.
