The 5150 Garage, build, and force fed help thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Justus, Jun 4, 2013.
  1. Apr 9, 2014 at 1:16 PM
    #181
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Lmao..... That's why I take my meds
  2. Apr 9, 2014 at 1:29 PM
    #182
    Manwithoutaplan
    ID
    to grow up big and strong like Brock lesner ?
  3. Apr 9, 2014 at 1:30 PM
    #183
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    No.... Anticrazy pills
  4. Apr 9, 2014 at 1:35 PM
    #184
    Manwithoutaplan
    ID
  5. Apr 10, 2014 at 9:34 PM
    #185
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Oil pressure? Since our sensor doesn't warn until after the damage is done......:eek:
  6. Apr 11, 2014 at 12:24 AM
    #186
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'm sorry all I see here is..... Darton 4.4
    I kid I kid.
    Iirc I seen a simple way to set one up on xru.... Something about the area below the oil filter base plate?
    Does that make sense?
  7. Apr 11, 2014 at 4:28 AM
    #187
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cool:
    You are correct. There is an Allen plug underneath the filter. Two actually. Just need to remove it to find out what the thread pitch/diameter is, and get an adapter for the sensor. Which will likely be a 1/8 npt.
    :thumbsup:
    These are my new favorite gauges - http://www.tanabe-usa.com/vls.asp
  8. Apr 11, 2014 at 12:46 PM
    #188
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Does that count for the tow package?
    It has the oil cooler.
    Thanks Tor
  9. Apr 11, 2014 at 3:17 PM
    #189
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes it does. :thumbsup:
  10. Apr 11, 2014 at 4:41 PM
    #190
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Toe package
  11. Jun 19, 2014 at 12:54 PM
    #191
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    have a huge magnaflow (the one that comes with the URD MK2 exhaust) if anyone wants to donate some cash.
    installed a super44...............yes, a chokemaster
    sounds much better and with the other parts I have, I think I can live with some minor restrictions from the muffler
  12. Jun 19, 2014 at 12:55 PM
    #192
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    URD TCAI in transit as I type this also
    so I may have the AFE stage 2 SI for sale
  13. Jun 19, 2014 at 12:57 PM
    #193
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  14. Jun 19, 2014 at 1:01 PM
    #194
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Hi Craigers :wave:
  15. Jun 19, 2014 at 1:04 PM
    #195
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  16. Jun 19, 2014 at 1:10 PM
    #196
    Manwithoutaplan
    ID
  17. Jun 19, 2014 at 4:17 PM
    #197
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    wasssabi brother......................sorry I was charging the go pro and got distracted.
    Then was ordering an extra 200mm fan for my computer case (coolermaster HAF X), a touch screen fan controller/card reader, 2 120mm fans (1 for vid card, 1 extra to have onhand), and also ordered an MX mesh grill insert to protect the trucks radiator/intercooler from rocks.
    Gotta love Amazon prime...........they got errrything and ships fast.
    URD intake just showed up actually, so Ill be afk again
    FWIW, the HDD cage from an antec 900 will slide into the HAF X case and the HAF X screen cover snap right back on.
  18. Jun 19, 2014 at 4:30 PM
    #198
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    gotta say tho, this is the most used install ever
  19. Jun 19, 2014 at 11:33 PM
    #199
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  20. Jun 20, 2014 at 7:54 AM
    #200
    BradyT88
    BradyT88 Well-Known Member
    Same for me (except mine is an Ultragauge) I use it for little random things here and there, but it literally is my speedometer. I have it calibrated and look at it now rather than the actual speedo. Been doing it so long it's weird to even look at my speedo.
    :jellydance: I need to graduate and find a good job so I have some spending money!!
