The 5150 Garage, build, and force fed help thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Justus, Jun 4, 2013.
  1. Aug 18, 2014 at 2:56 PM
    #461
    BradyT88
    BradyT88 Well-Known Member
    rctoy put his on his 1st gen at arpund 170K and it's still doing fine after another 50K miles of rough abuse by him
  2. Aug 18, 2014 at 3:19 PM
    #462
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Huh! Didn't know any of that....and the UCON has hiccups? :(
  3. Aug 18, 2014 at 6:08 PM
    #463
    BradyT88
    The ucon is a work in progress basically. Last I knew they released a version 2 that fixed most of the issues but there are possibly still some lurking around.
  4. Aug 18, 2014 at 6:28 PM
    #464
    AR15xAR10
    I just want to not be so limited. Tor knows what i mean, we've talked on the subject. :wink:
    More air in and more air out is also appealing as well as lower coolant temp, an adaptive add on computer and i really would like to have a higher rev limiter without blowing my motor to pieces...i've always hated that the Frontier's V6 has a higher rev limiter :pout:
  5. Aug 26, 2014 at 10:30 PM
    #465
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  6. Aug 27, 2014 at 12:13 AM
    #466
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Reasoning in going back to stock?
  7. Aug 27, 2014 at 1:08 AM
    #467
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    :D
  8. Aug 27, 2014 at 1:11 AM
    #468
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I did notice I went from 8lbs to 7lbs of boost..............same elevation, and 60 degrees outside.
    coincedence?
  9. Aug 27, 2014 at 1:42 AM
    #469
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    5150 Build ?? You and you're fuzzy math... I dunno braahh....:p
  10. Aug 27, 2014 at 7:10 AM
    #470
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :facepalm: mah bad. It was late.. was probably reading it with one eye. Lol.
  11. Aug 27, 2014 at 7:38 AM
    #471
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just don't go past 6k, with stock rods. Not safe in the long haul.
    The inspection Nazis......why my build has been done the lengthier harder way.......
  12. Aug 27, 2014 at 10:49 AM
    #472
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Dougers, where did u go?
    U got the hamma thrown down on ye!?
  13. Aug 27, 2014 at 10:55 AM
    #473
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Check out the banned members memorial thread, he was asking for it.
  14. Aug 27, 2014 at 3:33 PM
    #474
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I see now :cool:
  15. Aug 27, 2014 at 3:37 PM
    #475
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Begged for it really..It was all in fun tho'....:)
    :D
  16. Aug 27, 2014 at 3:44 PM
    #476
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    back from the dead?!
  17. Aug 27, 2014 at 3:51 PM
    #477
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    yep pretty much..
  18. Aug 27, 2014 at 6:26 PM
    #478
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Everytime I watch your videos.. I wanna make videos. Lol. Your more motivated than I am. Lol
    Ill be makin a bunch here soon once the exhaust is done.. :D
  19. Aug 27, 2014 at 7:04 PM
    #479
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Just running out of ideas
  20. Aug 27, 2014 at 8:51 PM
    #480
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Think I'd be ok throwing on a TRD s/c with 160K on the clock? :confused:
