The 5150 Garage, build, and force fed help thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Justus, Jun 4, 2013.
  1. Aug 27, 2014 at 8:51 PM
    #481
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    DOOOOO EEEEEEEEEEET
  2. Aug 27, 2014 at 9:06 PM
    #482
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Check compression first... But yes
  3. Aug 27, 2014 at 9:09 PM
    #483
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    How does one accomplish that?
  4. Aug 27, 2014 at 9:28 PM
    #484
    AR15xAR10
    Have someone perform a Compression test. :D
    <3 you Mr. Craig
  5. Aug 27, 2014 at 9:33 PM
    #485
    AR15xAR10
  6. Aug 28, 2014 at 5:39 AM
    #486
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You can rent a compression tester at your local auto parts store. Thread it in, in place of the spark plug. Have someone crank the engine while you watch the gauge. I am currently have a brain fart, but they all need to be around ~10 % of each other. ( < That needs proper verification). The closer the psi to each other, the better.
    At 160k miles, I would switch to a 5w or 10w-40. Especially with an s/c installed.
  7. Aug 28, 2014 at 6:49 PM
    #487
    AR15xAR10
    Connecting rods? Cuz there are no push rods right?
  8. Aug 28, 2014 at 8:50 PM
    #488
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. The raised rpms are to much stress for the stock cast powder metal rods.
  9. Aug 28, 2014 at 9:08 PM
    #489
    AR15xAR10
    Shame i don't have the time to replace shit like that.... DD kind if gets in the way...
    Chalk another one up on the board for Toyota being a buncha cheap ****suckers. :(
  10. Aug 29, 2014 at 4:58 AM
    #490
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They are "sintered", such is a type of forging process. some engineers claim this method is superior to traditional forging.
  11. Aug 29, 2014 at 5:29 AM
    #491
    AR15xAR10
    Nothing like having your bottom end come apart! :(
  12. Aug 29, 2014 at 9:59 AM
    #492
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Learned something new today. Thank you. I found this pretty good description.
    The reason why our rods are so weak, is that they were made on the very thin, basically. Especially at the wrist pin end. That and the fact that they are inherently brittle. Unlike those made by other OEM's. Our were economy oriented versus performance.
  13. Aug 29, 2014 at 10:24 AM
    #493
    memario1214
    Colton
    Missoula, MT
    You didnt know this!? What a shame :p
    I actually thought that was a Chris4x4 attempt at spelling centered. His reputation... its flawless
  14. Aug 29, 2014 at 11:26 AM
    #494
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh.....it's flawed for sure. :eek:
  15. Aug 29, 2014 at 11:30 AM
    #495
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Same reccomendation for a 5vz with 120k on it?
  16. Aug 29, 2014 at 11:43 AM
    #496
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sir, you're math is not flawed you know when your getting fucked out of a 1/4lb of coffee....
  17. Aug 29, 2014 at 12:23 PM
    #497
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh....you got that right!
  18. Aug 29, 2014 at 8:17 PM
    #498
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    doooooooooooooo it!
    u mean sinister yes?
  19. Aug 29, 2014 at 8:18 PM
    #499
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    off to disneyland for a few days
    I hope to partake some REAL gas along the way
  20. Aug 29, 2014 at 8:20 PM
    #500
    AR15xAR10
    You now have 500 posts in here :spy:
