The 5150 Garage, build, and force fed help thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Justus, Jun 4, 2013.
  1. Oct 30, 2014 at 7:42 AM
    #961
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    PM either one of us lol. I know Brock knows what i'm talking about
  2. Oct 30, 2014 at 8:00 AM
    #962
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You could tell URD to not change the rev limiter. Simple as that. You can also buy the thermostat without having to buy the UCON. I am actually running a 170* T-stat which I originally purchased for my Subi. Lol. Of course, my thermostat housing is modified by me.
    The only company which has actual plug for the '09+ models is unichip. A resourceful individual could buy that unit and then make a plug n play harness from their plugs. Possibly*** Otherwise, it is a wire in job. If I had an '09+ I would buy plugs and install them inline, to make it adaptable to a flying lead harness. Plenty of GM plugs are available, or even older Toyota plugs. It would be tedious and timely, but still do-able.
    The man Matt has been there. :bowdown: I went through the UniChip, Map-ECU2, and APR X-1, before I found the ProEFI. My ProEFI is even plug n play. I did just that which you said. Went big. Problems solved. Tuned it in right, and it adapted on its own, and has far more safety features that an X-1 or UCON. In my case, they even work compared to the X-1.
    See above. ^^^^^ AEM Infinity. Cheaper than the ProEFI. However, there is a new ProEFI product in the works, which is supposed to heavily compete with the AEM Infinity price point.
  3. Oct 30, 2014 at 8:29 AM
    #963
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    im not that talented.. i want something thats plug n play.. so until that happens.. i stand by my statement of nothing available for me.. lol
  4. Oct 30, 2014 at 8:35 AM
    #964
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If only I lived closer. ;) I will be passing through though, tomorrow. ..........
  5. Oct 30, 2014 at 9:23 AM
    #965
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    through Az??
  6. Oct 30, 2014 at 9:28 AM
    #966
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. On I-10
  7. Oct 30, 2014 at 9:41 AM
    #967
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I should make an interception
  8. Oct 30, 2014 at 9:56 AM
    #968
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :spy: If you can keep up. :p
  9. Oct 30, 2014 at 9:59 AM
    #969
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is much better weather for a road trip to SD than in July. I was sweating bawls last time!
  10. Oct 30, 2014 at 10:20 AM
    #970
    AR15xAR10
    SHOTS FIRED. Lol :laugh:
  11. Oct 30, 2014 at 10:29 AM
    #971
    AR15xAR10
    It really grinds my gears...all the hypertechs and shit that are available for full size trucks and all the GAINS that can be made in no time and for cheap
  12. Oct 30, 2014 at 10:32 AM
    #972
    BradyT88
    BradyT88 Well-Known Member
    You can thank Toyota for that for keeping the ECU coding so locked up. GM, Ford and Chrysler ECU coding is practically open source so it is really easy to build mods for.
    I have a friend who works at Bully Dog and helped them crack the code to build the tuner they have for the 2nd gens and he said they basically got the code opened and just started changing things to see what changed what and they are still learning more all the time.
  13. Oct 30, 2014 at 10:36 AM
    #973
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I thought bully went belly up or changed hands
  14. Oct 30, 2014 at 10:39 AM
    #974
    BradyT88
    Not that I am aware of. I know they moved to a new building in a different town (but the 2 towns are right by each other basically).
  15. Oct 30, 2014 at 10:46 AM
    #975
    Manwithoutaplan
    ID
  16. Oct 30, 2014 at 10:56 AM
    #976
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oh reaaaallllyyy.. dude.. if you want to grab some food or something on your way through.. would be cool to meet the man himself..
  17. Oct 30, 2014 at 11:00 AM
    #977
    Manwithoutaplan
    ID
    So brock when we going to meet up and get pumped ?
  18. Oct 30, 2014 at 11:00 AM
    #978
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Freaking lunch box hands
  19. Oct 30, 2014 at 11:02 AM
    #979
    Manwithoutaplan
    ID
  20. Oct 30, 2014 at 11:04 AM
    #980
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Tor, I sent for the choppa........ Imma catch u
