The 5150 Garage, build, and force fed help thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Justus, Jun 4, 2013.
  1. Nov 14, 2014 at 2:36 PM
    #1221
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    You're a peeRunner..... :(
    And who likes single din? Fuck that shit.
    Brock, you need to dyno this thing man....i'm curious.
  2. Nov 14, 2014 at 2:39 PM
    #1222
    BradyT88
    BradyT88 Well-Known Member
    Yeah I'm enjoying my double din.
  3. Nov 14, 2014 at 2:42 PM
    #1223
    Justus
    Justus [OP] fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I love my single din.... Less attention, plus I frenched in the Scangauge below it into the pocket :)
  4. Nov 14, 2014 at 2:42 PM
    #1224
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Nothing near me cept a heartbreak dyno
  5. Nov 14, 2014 at 3:03 PM
    #1225
    AR15xAR10
    Heartbreak?
    I want to put a double din in but would have to get my windows tinted first, i don't live in the safest area and i'll be damned if some dickhead thinks he gon bust my window and pry my radio out.
  6. Nov 14, 2014 at 3:06 PM
    #1226
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Mustang dyno.... They read low
  7. Nov 14, 2014 at 3:22 PM
    #1227
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are pretty close formulas available for Mustang to Dyno Jet power estimations. Dyno Dynamics are usually the lowest reading. Still worth it since you've done mods since your last dyno.
    I am a single din kind of guy as well. Weighs less and doesn't need anything more. A guy made a run of 3 or 5 of those triple gauge pods, some year a ago. Carbon fiber. They were so nice. My only complaint is that they are so far out of the line of sight of the driver. Those would have to be something like temp gauges, for me.
    Last time I weighed mine, it was 3800 even. Still need to get it lower though. If I could drop 400 or so pounds, that would be a very nice improvement!
  8. Nov 14, 2014 at 3:22 PM
    #1228
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2021 Tundra TRD Sport 4wd
    Yes, I sold my '13 Taco. :'(
    Bad for numbers, PHENOMENAL for tuning. ;)
    Yimi Sport only a few hours away in Santa Clarita has a Dynojet.
    2 Paul's work there, the tuner and the owner. Both pretty knowledgable dudes. "Tuner Paul" has put excellent tunes on my friend's GTR and my 2 other buddies' STi's.
    http://yimisport.com/dyno/
    ...just putting it out there. :D
    They're pretty busy this time of year with all the time attack series events, but I'm sure they could squeeze someone in for a simple dyno pull.
  9. Nov 14, 2014 at 3:24 PM
    #1229
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Boom :thumbsup:
    If not them, then FSR Motorsports.
  10. Nov 14, 2014 at 3:27 PM
    #1230
    AR15xAR10
    What have you removed for weight savings Mark?
  11. Nov 14, 2014 at 3:51 PM
    #1231
    STiLL WILL
    CA
    What's nice here in Cali is when there's a band of dyno's and tuner shops all within a radius of each other they will sometimes print out a secondary dyno readout for the customer with a correction factor applied to "kinda/sorta" compare their numbers to another brand of dyno.
    Dyno Dynamics and Mustang dynos are the best of both worlds being that they feature a static load(the rollers) as well as a dynamic weight(vehicle weight set by user) & a second dynamic weight based on the drag of aerodynamics(I believe defined usually as "hp @ 50mph"). The beauty of all these combined, WHEN CALIBRATED CORRECTLY BY THE OPERATOR, let the tuner simulate as close a load a vehicle would encounter on the street. Again, what I typed in all caps is crucial.
    Dynojets, usually read higher, but really only have the static load based off the weight of the rollers as a "load" to tune with. You can still tune very thoroughly on a DJ, but it's always recommended to confirm calibration thoroughly on the street, post-dyno tune.
    Dynapaks, while giving the operator endless ways to dial in a load curve, is not that good at simulating real world street conditions. Not too keen on these kinds of dynos but I believe the static sweep rate for a defined rpm range is only able to apply load in a linear slope for a defined number of seconds. So for example if you have an 800whp car and a 150whp car----the 800whp car will be seeing a LOT more load due to the nature of the defined linear sloped static sweep rate for the user-inputted rpm range(say for example a pull from 2000rpm-6000rpm to take place over 11 seconds). Basically, the flaw is when you are out on the street: a 150whp car vs an 800whp car will basically see the same load(assuming they are the same car, same equipment). This is why sometimes it's normal to see ridiculously high torque readings from a turbocharged car.
    For sheer bragging number rights, usually a Dynojet will work in someone's favor over most other brands. For tuning, I would prever a DDynamics/Mustang/SuperFlow chassis dyno. :)
  12. Nov 14, 2014 at 4:02 PM
    #1232
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Matt made brain hurt.... Too early
  13. Nov 14, 2014 at 4:10 PM
    #1233
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I love the superflow, however at my place of work we have everything but a chassis dyno. My experience with a dyno dynamics was with my t444e at a diesel shop. I thought it was OK, didn't know about them being a heartbreaker till after the fact. It was extremely consistent.
  14. Nov 14, 2014 at 4:32 PM
    #1234
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    VIS Hood, 1 piece aluminum drive shaft, 17 lbs Braille battery.....yeah, that's all I can remember right now. Lol. Can't say wheels and tires until I get new wheels. These are about 65 lbs each corner. :( Still lighter than the old set of 35's on ProComp wheels though.
    ***Edit*** Oh yeah. No front differential, and a lighter transmission (no transfer case), lighter BBK. BBK alone shaved 15-20 lbs. I'd have to look back to be sure.
  15. Nov 14, 2014 at 4:36 PM
    #1235
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :pout:
  16. Nov 14, 2014 at 9:06 PM
    #1236
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Wuz wrong mooshy?
  17. Nov 14, 2014 at 9:32 PM
    #1237
    AR15xAR10
    He wasn't included. :(
    I'd gladly take a ride along in any of these boosted chariots. Especially Lord Tor's :eek:
  18. Nov 14, 2014 at 9:39 PM
    #1238
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Josh..... U do have an edge with the vb upgrade buddy
  19. Nov 15, 2014 at 12:09 AM
    #1239
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    But I'm running 285's and 4WD. Not the lightest on it's feet. :eek:
    Other than that I think we have very similar setups.
  20. Nov 15, 2014 at 12:17 AM
    #1240
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Remember its the size of the fight in the dog
