The 95-97 Taco Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by 3RZ Taco, Sep 23, 2012.
  1. Oct 25, 2015 at 9:24 PM
    #1781
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get some 1/4" trucker mud flaps and make your own. Or order some 1/16" abs plastic and mold your own.
  2. Oct 25, 2015 at 9:31 PM
    #1782
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    That's what I had in mind grainger sells 48" long sheets of thermoformable abs plastic that I was thinking of getting... I just don't know if that will be long enough
  3. Oct 27, 2015 at 1:45 PM
    #1783
    griz bruja
    griz bruja New Member
    griz
    fifty nifty usa
    taco 97 2.7 4 cyl 4wd flat black
    [QUOTTACOMABOSS, post: 5734969, member: 59499"]I hate you.
    Im at 144,000 exactly[/QUOTE]
    Ha!!!ive got 250k!!!!!
  4. Oct 27, 2015 at 1:49 PM
    #1784
    griz bruja
    griz
    fifty nifty usa
  5. Oct 27, 2015 at 1:52 PM
    #1785
    griz bruja
    griz
    fifty nifty usa
    Trying to figure out if i have an automatic disconnecting differential and differential lock..been on the horn with salvage yards trying to find a transfer case that won't break the bank. Also talked with probably twenty different dealerships around the country and not one could 100% tell me if I have add or not!!! They keep saying its not vin # specific....busted in kansas
  6. Oct 27, 2015 at 1:55 PM
    #1786
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    330k on my 2rz. Pulling it out January for some upgrayyydz
  7. Oct 28, 2015 at 6:00 AM
    #1787
    Minnetacoma
    Elliott
    Minnesota
    Anyone 2jz-gte swap?
  8. Oct 28, 2015 at 6:04 AM
    #1788
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Lowered 5 lugger guys have done more than once
  9. Oct 28, 2015 at 6:07 AM
    #1789
    Minnetacoma
    Elliott
    Minnesota
    It would be like having a baja truck
  10. Oct 28, 2015 at 3:17 PM
    #1790
    Blackdawg
    Monte
    Wyoming/St. Louis
    2jz is pretty easy swap.
    This is easy to figure out. The ADD diff is the front. If you don't have manual locking hubs it's an ADD diff.
    For the rear locker you should have a button on the dash on the driver side of the steering wheel.
    But if you don't evenhave 4wd. Chances are you don't ha e either.
  11. Oct 28, 2015 at 3:24 PM
    #1791
    Minnetacoma
    Elliott
    Minnesota
    So the add is all front 4wd without locking hubs? I'm seriously considering the 2jz swap even with a modest tune at 400-500 hp it would be well worth it wouldn't be sniffin this semis ass if I had some damn power
  12. Oct 28, 2015 at 3:27 PM
    #1792
    Blackdawg
    Monte
    Wyoming/St. Louis
    you want torque. Not power. Downsizing your motor isn't going to do that. Power and of the 2jz is not ideal for a truck.
    Th add is just the front. It's on the tube on the passenger side of the diff. Has an actuator that slides to lock the axle to the diff to give you 4wd drive. Early years are vacuum. Later models are electric.
  13. Oct 28, 2015 at 3:32 PM
    #1793
    Minnetacoma
    Elliott
    Minnesota
    Yes true but if I tuned a 2jz gte to 500 hp she should easily be making over 400 ft lb of torque and straight six twin turbo pretty sure I'd be extremely satisfied with the outcome and towing capabilities... Would my tranny bolt right up? My brother In law had a 2002 mr2 and I felt like I was driving my trucj
  14. Oct 28, 2015 at 3:44 PM
    #1794
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea well an mr2 weighs nothing.
    Sure yes a 2jz can do 500hp and 450ftlbs. But it won't be till 4-6 thousand rpms...
    I just got done going over this is great detail. The 5vz fe is a torque monster. You have over 85% of torque at 2k.
    A 2jz won't get to the same output till much higher in the power band.
    The tranny will bolt up with a different bellhousing. Then you need custom motor mounts. Drive shafts and engine harness. Priced out its about 7 grand.
    You're much better off turboing the 5vz
  15. Oct 28, 2015 at 3:49 PM
    #1795
    Minnetacoma
    Elliott
    Minnesota
    What all would need to be done to the block to be able to handle a twin turbo setup? And I'm sure I'd want to recam and lower my compression
  16. Oct 28, 2015 at 3:51 PM
    #1796
    Minnetacoma
    Elliott
    Minnesota
    And where would you tuck the intercooler
  17. Oct 28, 2015 at 3:52 PM
    #1797
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your over thinking it man. Twins would be like a 20 grand project.
    A small single will get you to 400hp easy and be at full boost below 2.5k rpms. There is lots of support for singles including headers readily made.
  18. Oct 28, 2015 at 3:53 PM
    #1798
    Blackdawg
    Monte
    Wyoming/St. Louis
    Up front. Behind the grill
  19. Oct 28, 2015 at 3:53 PM
    #1799
    Minnetacoma
    Elliott
    Minnesota
    Point me in the right direction lol what mods would need to be done to the drivetrain to handle that power
  20. Oct 28, 2015 at 3:54 PM
    #1800
    Minnetacoma
    Elliott
    Minnesota
    Is there room with ac up there
