The Adventures of Ash and Baby Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by BabyTaco, Feb 22, 2014.
  1. Dec 27, 2015 at 6:13 AM
    #621
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    You will forget about the price when you regain power :laugh:
  2. Dec 27, 2015 at 8:08 AM
    #622
    BradyT88
    BradyT88 Well-Known Member
    ^^^This. Regearing is one of the most underrated mods because of how expensive it is everyone just skips doing it. It brings a lot of life back to your vehicle though!
  3. Dec 27, 2015 at 10:56 AM
    #623
    BabyTaco
    Wyoming
    2011 RC Tacoma
    My engine just took a shit. Limped back home and gonna have to use my gf's car to pick her up from the airport. I'll be taking it to a mechanic tomorrow.
  4. Dec 27, 2015 at 11:25 AM
    #624
    BabyTaco
    Wyoming
    2011 RC Tacoma
    @Blackdawg assuming the worst. We decided the v6 is as simple as the engine/wiring, right?
  5. Dec 27, 2015 at 11:59 AM
    #625
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That sucks. Sorry to hear dude.
  6. Dec 27, 2015 at 12:10 PM
    #626
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Ya, upsetting at just 50k but luckily it is happening close to when I have a large influx of money. Maybe it isn't that bad but if its close to a $1500 bill...gonna be hard to pass up a v6
  7. Dec 27, 2015 at 12:50 PM
    #627
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Wow damn Gage sorry to hear that dude...On the bright side BabyTaco is gonna scoot right along with a v6 under the hood. Thats incredibly odd though, at only 50k too??? WTF :notsure:
  8. Dec 27, 2015 at 12:53 PM
    #628
    BradyT88
    :cough cough:
  9. Dec 27, 2015 at 5:05 PM
    #629
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pretty much. Idk how the motor mounts line up. And not sure if you'll need a 6speed manual too or if you can keep the 5speed.
  10. Dec 27, 2015 at 5:15 PM
    #630
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Bummer on the motor, what happened?
  11. Dec 28, 2015 at 8:13 AM
    #631
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Hmm, well hopefully it doesn't come to that and it is just a seal somewhere causing me problems. Might start looking for DD's otherwise and start calling taco specific shops in CO :pout:.
    Well, it started eating oil and making weird noises. About 5-6 quarts of oil every 600-800 miles. I have just been "ignoring" while actively researching and waiting for funds/time to dig into the project. I got back from my trip yesterday, calculated the miles, and added some oil before going to pick my girl up from her flight. It's a longer drive being 2 hours one way but I barely made it through town. At a stop light it felt like my engine was shaking more than normal and it threw the check engine light. It just sounded like death and had the same shuttering sound I have heard in the past, only worse. I popped the hood, no smoke, idled fine. Drove it home and it was not doing well. I have it warming in the garage right now and I am going to check the oil. The only thing I think that could of happened was I put to much oil in. I quickly checked it but didn't let the truck sit for 15 minutes so it wasn't the most accurate reading.
  12. Dec 28, 2015 at 8:41 AM
    #632
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Can you see any visible leaks? My moms camry had an issue where it would eat oil but no leaks, almost to the point of running out before an oil change. But oil that is too fine (synthetics or just a low weight oil) can seep though the rings if the tolerance isn't up to spec, but with her camry we went to a higher weight and stuck with conventional oil to help remedy the issue. May be worth a try and check at 500-1000 miles to see if your still losing the same amount of oil
  13. Dec 28, 2015 at 8:43 AM
    #633
    BabyTaco
    Wyoming
    2011 RC Tacoma
    No visible leaks. Checked the oil, it was high but not anything crazy. Maybe the existing problem mixed with high oil finely did in a seal? I am draining all of it and adding the exact amount needed. Oil looks like how it should. Ill be calling shops and figuring out costs to diagnose the problem.
  14. Dec 28, 2015 at 8:49 AM
    #634
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Yeah no visible leaks/ losing oil means its burning off somewhere. Could always check compression of the cylinders
  15. Dec 28, 2015 at 9:37 AM
    #635
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Drove it around the block, seems fine. Still going to a mechanic. If its something I might be able to fix then I actually have the time for it.
  16. Dec 28, 2015 at 11:49 AM
    #636
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Got an appointment with a mechanic. ~$45 to check it out and diagnose it. My friend used him and he seems like an honest guy. She had an oil leak or something that essentially did the same thing that's happening to me. Instead of charging the heck out of an innocent and naive gal, he didn't charge her anything and offered to refill the oil at a discount. Hopefully he can find something out, might take my chances with the dealership if it seems like something that is not likely to be cause by water or dirt.
    ChandlerDOOM likes this.
  17. Dec 28, 2015 at 4:46 PM
    #637
    Blackdawg
    Monte
    Wyoming/St. Louis
    Fuck it. Let's swap it!
    BabyTaco[OP] likes this.
  18. Dec 28, 2015 at 5:13 PM
    #638
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    subbed for LS swap :popcorn:
    BabyTaco[OP] and BradyT88 like this.
  19. Dec 28, 2015 at 5:44 PM
    #639
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Aren't you all kinda jumping to conclusion lol
  20. Dec 28, 2015 at 9:51 PM
    #640
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Not really. It's gonna happen one day! Of course I am assuming the worst with the swap and really hope its a fairly simple fix. In the end it's a simple 4 cylinder and likely can be fixed under 1k. Not the best time for me to do something like that but it isn't the worse either. I told my girlfriend I might just swap in the v6 and she replied with "I thought you were doing that anyways?" :laugh:.
    Only time will tell. It gets me excited to think about having some power though.
