The Adventures of Ash and Baby Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by BabyTaco, Feb 22, 2014.
  1. Jan 6, 2016 at 4:56 PM
    #761
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea I run 10-30
  2. Jan 6, 2016 at 4:59 PM
    #762
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Do you not put oil back in a container that it could be measured? Thatd give you an idea how much youve lost at least.
    And i think you mean valve seals? Seals can be replaced with the head still on the motor. Or its rings, depends how much youre burning. If it starts puffing a lot more when you get on it then i would assume rings. You really should do a compression check or leakdown test to verify anything first. At the least have a mechanic do one so you know what is wrong, before jumping to replace an entire engine
  3. Jan 6, 2016 at 6:32 PM
    #763
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    Yep, I am talking about the seals. I have heard valve stem seals, valve guide seals, and valve seals. I am assuming they are all the same as I haven't seen a difference. I have been looking at valve seal replacement and it seems rather simple.
  4. Jan 6, 2016 at 7:08 PM
    #764
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Well you only used valve guide which is a totally different part which would require the head to be removed. Just wanted to make sure :thumbsup:
  5. Jan 6, 2016 at 7:14 PM
    #765
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I type quick on my phone and don't always double check :D
  6. Jan 6, 2016 at 8:03 PM
    #766
    BabyTaco
    Wyoming
    2011 RC Tacoma
  7. Jan 6, 2016 at 9:00 PM
    #767
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Found this video. May be of some help.
    https://m.youtube.com/watch?v=zFmC66YU6zI
    These guys replace valve seals on a dohc Honda engine without removing the head. I didn't know it could be done this way. In the vid the valve cover and cams are already removed. I know it's a Honda but any dohc should at least be similar.
  8. Jan 6, 2016 at 9:01 PM
    #768
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I saw that earlier. Pretty helpful and those guys had me laughing with their commentary. There is also this write up that helped explain the process in more detail.
    http://lextreme.com/valve_seals.html
  9. Jan 6, 2016 at 9:20 PM
    #769
    weldo
    Pittsburgh, pa
    Right on, man! If you do this job yourself take a few photos for us. I have a 2tr also and I'd love to see inside of it. Also it'd be good reference in case others have this problem.
  10. Jan 6, 2016 at 9:40 PM
    #770
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Pictures will be taken, mostly for reference, but also because I was only able to find one photo of this engine cracked open.
  11. Jan 6, 2016 at 9:55 PM
    #771
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Get one of those Haynes repair manuals. They are awesome. I have one for my truck, a lot of info.
  12. Jan 6, 2016 at 10:11 PM
    #772
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I planned on buying the online version tomorrow :thumbsup:. Looks like it will be useful for quite a few things.
    gray223[QUOTED] likes this.
  13. Jan 7, 2016 at 12:36 PM
    #773
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Cleaned up the throttle body today. Took maybe 30 minutes at most. I used the CRC throttle body cleaner and whatever was caked on there came off easily with a spray and a quick wipe.
  14. Jan 7, 2016 at 4:44 PM
    #774
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    This is gettin Good now !
    Interesting vid's , reading.
    Wish I was there to help, and learn at the same time.
    Good luck , and keep at it :thumbsup:
    BabyTaco[OP] likes this.
  15. Jan 7, 2016 at 5:14 PM
    #775
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I am pretty excited to dig into this project. Up to this point I have done everything to my truck and learned a lot. I was going to pay for the work because working on the engine scares me. You have to learn some howthe 2tr-fe is pretty damn basic when you start looking at it. The exact reason I bought this truck was to teach myself the basics that I never had the chance to learn. Hell, I started with learning how to drive stick the day I bought it. Drove it 2 hours home by myself and never had anyone teach me :laugh:.
    I guess there is a chance I may screw up but it can't get much worse than it is now.
  16. Jan 8, 2016 at 1:12 PM
    #776
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Ok, question! Valve seals are $15 a piece through toyota. I believe there are 16 total (coming to ~$240). The parts guy told me he hates passing up a sale but I should probably go to napa and go aftermarket as he has had good look on his own vehicles. Is it worth paying for OEM or should I try out aftermarket and save some money? Or, should I wait until I open the engine and have time to inspect the seals. And only replace the ones that are bad?
    I ordered a new cover and throttle body gasket to replace just for good measure.
    On one hand, I am upset the dealership has even questioned my warranty with an engine at 50,000 miles but they always seem to be very helpful in the parts department. He showed me the diagrams and what needs to be done on the computer. He said it was a pretty basic job and as long as you take your time, it is pretty easy.
  17. Jan 8, 2016 at 1:16 PM
    #777
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Saving for later. Also, @Konvict KROG since you are the one that took this photo, do you have any advice?
  18. Jan 8, 2016 at 2:29 PM
    #778
    weldo
    Pittsburgh, pa
    If it were me I'd go oem, just to be sure. Usually oem stuff is best. There are lots of 2trs with lots of miles on them, which is a testament to the quality of oem parts.
  19. Jan 8, 2016 at 3:12 PM
    #779
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Well, I ordered felpro valve seals. $40 for the complete set...vs toyota at $220 for a small piece of rubber. Lots of people use and have good things to say about felpro so I feel alright going this route. I can pick them up tomorrow when they arrive at the parts store. If the cost was within $50 I probably would have went OEM but I am not paying the outrageous price they are asking.
  20. Jan 9, 2016 at 4:51 PM
    #780
    Explor
    FUN
    Pretty much how a dealership makes its money , not to mention the cash Toyota is making. There's not much mark up on the original purchase , it's the parts and service that bring in the cash !
    There are many accidents needing parts , I checked on the price of my 2013's cheap , low light fogs .... $192.oo fore 1 .... ONE !! Geez !
    Anyway , that's how the big bucks are made .
    You have me wondering Why .... No Warranty ? 50,000 miles ?
    This endeavor is more into the advanced stage of learning :D
