The Adventures of Ash and Baby Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by BabyTaco, Feb 22, 2014.
  1. Jan 27, 2016 at 12:48 PM
    #1001
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How in gods name would a t56 bolt to a tacoma tcase?
    And the v6 has something going for it..its light. Way lighter then any ls motor that you could afford anyways.
  2. Jan 27, 2016 at 12:52 PM
    #1002
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    and the v6's are kinda.....EVERYWHERE....not exactly hard to find or work on.
  3. Jan 27, 2016 at 12:57 PM
    #1003
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    I wouldn't say a LS engine is hard to find. Probably easier than a v6.
  4. Jan 27, 2016 at 1:03 PM
    #1004
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    I wasn't trying to imply an LS was hard to find, though I guess I sorta did haha. My preference would just be the V6.
  5. Jan 27, 2016 at 1:05 PM
    #1005
    BabyTaco
    Wyoming
    2011 RC Tacoma
    If I was putting that kind of money into it...hard to be the power/weight of an ls. The v6 would probably be "easier" and cheaper to do though. More than enough power and reliable
    joshipps and stronghammer like this.
  6. Jan 27, 2016 at 1:06 PM
    #1006
    BradyT88
    BradyT88 Well-Known Member
    It was a shot in the dark. haha I'll bet somebody makes an adapter, but there is probably a better manual trans option. The 1GR is about 100 lbs lighter than the aluminum block LS's. Most of them are in the $3K-$4K price range used.
    LS's are really easy to find. Go to Ebay and you can find tons and tons of ads. Type in 1GR and you get less than 10...
  7. Jan 27, 2016 at 1:15 PM
    #1007
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea because there are probably over a hundred different ls motors.
    Exactly. 100lb for an aluminum one. Which is much more expensive. So most go for an iron block. Which I bet is probably what..150-250lb more?
    For a single cab tacoma..a v6 would be pretty ballsy haha add the tried and true Trd blower to it later for more craziness.
    Weight is every bit as important as hp.
    Seriously doubt a Toyota tcase bolts to a t56. Not worth making an adapter.
  8. Jan 27, 2016 at 1:22 PM
    #1008
    BradyT88
    Yeah the iron block is about 200 lbs heavier. You can pick them up for about $500 though. The 5.3L seems to be a pretty solid option. When I was trying to decide what motor I wanted I was searching on ebay for very specific LS motors, like the L92, LM7, etc and I usually got a lot of hits on each one. I think it's also because there is a larger resale market for a used Chevy V8 than a Toyota V6.
    While an S/C'd V6 would be sweet in a light single cab, the TRD S/C's are getting pretty hard to find too. Maybe it won't be so bad once Magnuson comes out with them again, but I won't be surprised if the price tag is similar to URD's S/C's.
    My plan was to do the L92 which is a 6.2L putting out just over 400 HP stock. With some minimal modifications it breaks 500HP at the wheels pretty easy. I think hte extra 150HP over a heavily modified TRD S/C'd 1GR is worth the extra 100 lbs.
  9. Jan 27, 2016 at 1:30 PM
    #1009
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea but there theres the issue that you'll need a whole new rear axle and say good bye to R&Ps in the front too. And CVs.
    Thats too much power for our trucks drive train.
    Might as well sell the taco and get something else.
  10. Jan 27, 2016 at 1:39 PM
    #1010
    BradyT88
    At this point we are probably getting unrealistic for Gage while he is still in school, but for me I was going to run a 6L80E trans which is a 6 spd auto and some sort of Tcase (possibly an Atlas if funds allowed). The 6 speed has a 4:1 first gear and I would likely pick a Tcase with at least a 3:1 so I would be geared a lot lower than I am now and with the auto it will be easy enough to baby the throttle when needed. That would hopefully get me by until I could upgrade the rear end to something bigger. The front end would be harder and more expensive though. With any luck it would hold out for quite a while. I haven't seen too many front diffs break on 2nd gens.
  11. Jan 27, 2016 at 1:42 PM
    #1011
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    LS swap all the things.
  12. Jan 27, 2016 at 1:42 PM
    #1012
    Blackdawg
    Monte
    Wyoming/St. Louis
    how many 2nd gens push 400+ ft/lbs or torque through the front diff? lol
    Lower gears also mean more torque..which actually ups the chances of breaking shit.
    Just doesn't seem worth it in the long run for any 4wd tacoma.
  13. Jan 27, 2016 at 1:42 PM
    #1013
    Blackdawg
    Monte
    Wyoming/St. Louis
    your subie is next right?
  14. Jan 27, 2016 at 1:44 PM
    #1014
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Duramax swap :cool:
  15. Jan 27, 2016 at 2:09 PM
    #1015
    BradyT88
    200 of that goes to the rear ;) haha Lower gears do move the stress down stream, but they also mean more control. Look at n0rth. He has managed to not ever break a CV with his crawlbox and 36's and he's even running cheap CV's! I'll get it figured out, though I may grenade a few diffs/axles while learning where the limit is:burnrubber:
    For me, I am way too under powered in the sand dunes. If I didn't go to the dunes all the time then it probably wouldn't matter since when I am mobbing the desert my stock V6 has no trouble getting me up into the 70's and 80's, but in the dunes, If I am going up hill it's just constant deceleration...
  16. Jan 27, 2016 at 3:50 PM
    #1016
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Money isn't exactly my concern. Obviously I shouldn't be sunk into a project that will likely total 20k. Thats dumb and I am smarter with my money than that. My concern is who the fuck would do this work!? I am far from anything amazing at working on cars. I am a tinkerer by nature but thats it. My past experiences prove that the cost of a project needs to be doubled cause ill fuck it up and have to do it again :laugh:.
  17. Jan 27, 2016 at 4:37 PM
    #1017
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    I agree .... I would rather do it myself than have somebody else do it right
    the first time
  18. Jan 27, 2016 at 6:52 PM
    #1018
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Forgot to mention I tried to order the milwaukee on tuesday night. I have Amazon prime so it should have been plenty of time to get here for friday. Well, apparently that is impossible and it would arrive until monday at the soonest.
    Probably go to a local store and see what I can do. Most places here favor dewalt so might end up with one of them. I guess if I don't like it I can return it and order the milwaukee.
  19. Jan 27, 2016 at 7:00 PM
    #1019
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
  20. Jan 28, 2016 at 4:46 PM
    #1020
    BabyTaco
    Wyoming
    2011 RC Tacoma
    2uz would be fun! Who knows...after this incident maybe the truck fund will start growing for something better in the future. Ordered the bike in preparation to fuck things up :laugh:. Figured I would start riding to school even if the truck is fixed. Save on gas, time, and well...it gives me another hobby.
    As far as the impact goes. I ordered sockets and extensions to make it work. Going to try the breaker bar one last time. If that doesn't work then Ill go buy the dewalt impact and decide if it's going to fit the bill...if not I might return or sell it.
