The battery just exploded
Discussion in 'General Tacoma Talk' started by jsi, Jan 22, 2024.
  1. Jan 23, 2024 at 3:09 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Boiled out the go go juice and it was full of hydrogen. Bad connection, little spark, and kerblooie!
    I ONLY use tenders for long term storage. Anything else is watched carefully. I have a AC/Delco wheeled plug in one that will push 300+ amps.
    soundman98 and MadNachos like this.
  2. Jan 23, 2024 at 3:15 PM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    Would this have happened if OP used jumper cables?
  3. Jan 23, 2024 at 4:30 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it happens.
    had a customer call in that their generator wasn't running. went to check battery voltage, and found this
    that is with generac's built-in charger/maintainer circuit, with cold weather heating pad.
    swapped in a new battery, verified charging voltage was still good, and never heard from him again...
  4. Jan 23, 2024 at 4:43 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Charging batteries produce hydrogen gas that's life but some thing needs to set it off. It's not the battery in 90 percent of the time
  5. Jan 23, 2024 at 4:47 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    I have an electric gate and the battery is charged by a solar panel. It tended to boil the battery dry after a time. Once the gate wouldn’t open and I had to get somewhere on schedule. I hooked up one of those mini jump boxes to the battery, got back in my truck and hit the remote. BANG!
    Did you check the water level in the battery before charging?
    I put a charge controller between the solar panel and battery which solved the boiling off problem.
  6. Jan 23, 2024 at 4:51 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Flex Tape will fix that right up, just make sure to fill it with distilled water.
    jsi[OP] and soundman98 like this.
  7. Jan 23, 2024 at 5:00 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I'm no battery pro by any means but when I was working with lift gates at work I had a battery that was giving off rotten egg smell and ca-boom. So the battery was old and as it's life died out itas you were cranking it it swelled and blew. Glad you were'nt hurt.
    As for the battery tender been using 1 for 30 years no way it caused that as it has a fuse in the line. There is only mode like you stated I have a 4 bank in the shop running now with all the zero degree weather we had.
    Batteries get old don't sweat it toss in another battery and call it a day and move on.:cheers:
  8. Jan 23, 2024 at 5:16 PM
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    Very lucky man you are!
    jsi[QUOTED][OP] likes this.
  9. Jan 23, 2024 at 5:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm glad you explained the issue. After reading your post my 1st thought was the tender wasn't tendering.
    Certainly glad you are ok!
    I'd pick up a can or two of CRC battery cleaner/acid neutralizer and redo underhood very carefully. Water and baking soda was a start. But if the acid got into any crevices, wiring harness joints/taped areas that you didn't reach, future problems will be tough to trace.
    Personal experience with an engine bay soaking with acid from a burst battery (vehicle accident) says trust me on this. Little expense, some effort, worth it.
