The Be All End All to Your Alignment!
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForestRunnerFrank99, Jul 6, 2022.
  1. Jan 8, 2025 at 9:09 AM
    #141
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I’m sure glad this forum has an “ignore” feature.
  2. Jan 8, 2025 at 9:51 AM
    #142
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    I am too busy for that.. this is not toyota parts. No need for toyota tech. And im.not asking if thru calculate first. I'm simply asking about how many degrees it moves per rotation. You are taking it too far
  3. Jan 8, 2025 at 9:57 AM
    #143
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Hello pot, meet kettle
    jubei, Wulf and Bucky13 like this.
  4. Jan 8, 2025 at 10:38 AM
    #144
    Goosie0080
    North East
    Thanks for nothing
  5. Jan 8, 2025 at 11:32 AM
    #145
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    This is one of the best mods I have done on my truck.
    Bucky13, TACOTU3, Parkvisitor and 3 others like this.
  6. Jan 8, 2025 at 11:44 AM
    #146
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Looks like a quality product to me!!
  7. Jan 8, 2025 at 12:07 PM
    #147
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Agreed on great quality. Definitely was on par with brackets received from Ruffstuff(High quality).
    Realistic expectations need to be had with fabricator level WIY kits from any manufacturer. Would probably take less time to just deburr the parts than emailing the company about deburring parts.
  8. Jan 8, 2025 at 2:32 PM
    #148
    Dare Devil Diablo
    Dare Devil Diablo Well-Known Member
    2000 TRD Offroad MT
    I am quite satisfied having installed this kit on my truck.
    @Goosie0080
    There are 5 possible locations for the adjuster to locate the bolt. That is five for each end of the bolt. So total there are 25 different angles the bolt could be at. That's 25 for the front LCA attachment and 25 for the rear LCA attachment. That is 625 possible angles your LCA can be adjusted to.
    The amount of bolt movement you get from each turn of the octagon is relative to the arc the bolt hole travels relative to the octagon when you rotate it. There are 2 different distances the bolt can travel. The angle, is dependent upon the distance the bolt travels, the location of the opposite octagon and the location of the octagon you are turning.
    Once you had that information wtf would you do with it. You going to hand that to the alignment guy and expect him to do anything with it?
    You must be frustrated about something. You need to take a couple of deep breaths and chill, brother.
  9. Jan 8, 2025 at 9:12 PM
    #149
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    move till the numbers are green. every frame will be slightly different in how it affects the numbers. suspension setup and all play a roll. these are not "precision" machines
    a setup like this will lock in numbers. you're a bit more fixed. but if you NEED these? you likely dont care for absolutely perfect numbers. you just dont want shit slipping while wheeling. (alignments are really over exaggerated on how important it is to be perfect... the reality is... you can be fairly sloppy and be fine.
