The Beer Nerd - what are you drinking / brewing thread
Discussion in 'Homebrewing' started by TnRedNeck721, Jul 1, 2013.
  1. Nov 20, 2019 at 6:31 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Here you go...
    OG: 1.057
    FG: 1.014
    IBU: 22
    Color: 28 SRM
    ABV: 6.0%
    Boil: 90 min
    Batch Size: 6 gal
    BHE: 85% (I actually hit 90.2%, so OG came in @ 1.062, FG was dead on @ 1.014, and ABV clocked in @ 6.2%)
    8.0 lb 2-Row
    1.5 lb Munich
    1.0 lb Carapils/Dextrine
    .38 lb Chocolate (350L)
    .25 lb De-bittered Black (550L)
    .25 lb Black Barley (500L)
    1 oz Willamette @ 60m (17.3 IBU)
    .5 oz Cluster @ 10m (5.2 IBU)
    WLP835 German Lager X @ 52°F
    Mash temp/duration as needed to achieve stated FG with your choice of yeast. I mashed @151°F for 75 min.
    Notes: Now, you're probably looking at the recipe and thinking to yourself, this sure doesn't look like a German grain bill and those sure aren't German hops. Well, you'd be right. Actually, I created this recipe as a clone attempt of New Belgium's 1554 Enlightened Dark Ale (Note that they decribe it as an ale, but they say they use lager yeast, so whatever. Perhaps they ferment the lager yeast at ales temps - I chose to ferment it at lager temps). I made all the grain assumptions based on this description from NBB's website and subbed in hops that I had on hand. I figured they are using grain from domestic maltsters, with the exception of the Munich and de-bittered black, so I went with domestic 2-row, Carapils, and chocolate. Is 1554 actually a Schwarzbier? I don't know. It's definitely not a porter or stout and regardless of what NBB claims, it's not Belgian. Schwarzbier seemed to fit the recipe best, so that's what I called it. A true German Schwarzbier should be slightly roasty, but not overpowering and I achieved that with this recipe. Also, the ABV of this recipe is a bit high for a Schwarzbier, but I won't hold that against it. In a comparison with the real deal (I.e. 1554), it was definitely very close, but something was slightly off. I believe it was the black barley. Next time, I'll keep everything else the same, but take out the black barley and up the de-bittered black accordingly to .5 lb total.
    RickS, nDub, irayfz6 and 1 other person like this.
  2. Nov 20, 2019 at 6:49 PM
    relkins0413
    relkins0413 Well-Known Member
    Kings Mountain, NC
    2013 Silverado 2500HD Duramax
    Sounds great! Thanks for the recipe. I’m trying to get a dark mild and another pale ale brewed up and then I’ve got some lagers to work on. This will be one of the first two I do.
    Beer:30[QUOTED] likes this.
  3. Nov 20, 2019 at 7:09 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    For tonight's Tree House drinking festivities, Eighty One.
  4. Nov 20, 2019 at 8:15 PM
    theandyj
    theandyj Well-Known Member
    Orange County, CA
    2019 Cement OR
  5. Nov 21, 2019 at 2:25 AM
    relkins0413
    Kings Mountain, NC
    I’m good with Christmas on Nov 1, but I still have to give Halloween it’s time lol.
  6. Nov 21, 2019 at 8:21 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    I keep thinking of trying pressure transfers but I'm just too cheap to use the C02 :rofl: Do you see a real difference in beer quality, or is it convenience so you dont have to reach and lift stuff/jostle it up?
    *Canned hipster response* It's not as good as it used to be. 2 yrs ago CBS was awesome, hasn't had the same syrup kick since it seems. Also, KBS has always been a little bitter for me. Both still a lot better than most stouts, but i'm just a picky asshole :D
    relkins0413 and disconnected like this.
  7. Nov 21, 2019 at 8:36 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Sounding like someone else :rofl:
    christyle[QUOTED] likes this.
  8. Nov 21, 2019 at 8:40 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    Did the sour beer shuffle yesterday. For explanation... Middle carboy is my Solera project, hasnt been empty in close to 5-6+ years. I brew up a base beer and ferment it "normally" with a Saccharomyces ale strain (like the carboy on the right) when I feel the solera is at a good sour profile. I transfer out the solera onto fruit or into a keg (like the left carboy) to age until ready to drink. So last night I kegged the left carboy after sitting on 6+ lbs of cherries and a few oak chips for a few months, transferred the solera onto the cherries for a second use, and the far right base beer into the solera carboy, on top of about 1-1/5 gallons of old beer. The cheries will provide minimal flavor pickup but I needed somewhere for the solera to go and those cherries are going to be impossible to remove, so why not. I might transfer again to some rasperries or something later on, we'll see how flavor develops. I now have a keg of mango sour and cherry sour kegged and ready to go. Maybe a gallon or less of my passionfruit sour left before I put one of these on.
    Next up I decided to pull a sample of a group beer I made almost 2 years ago, where we bought a monsters park barrel from Modern times and 5 of us brewed up 10 gallons each of an Imperial stout. Aged it for about 7 months in there and pulled it. This is my second keg of it that's been sitting for awhile now. Colder weather means it's time to get it on tap. I've been soaking some cacao, cinnamon and chiptoles in vodka for a little while to add in for a mexican hot chocolate treatment. So far, the base stout tastes decent, but a bit woody and thin. I added a bit of my tincture and some vanilla to the sample to try it out and it's not bad, but i get more heat than the cinnamon and chocolate, so I might try a direct soak of them in my stainless mesh basket deal.
  9. Nov 21, 2019 at 8:41 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    WHOEVER COULD YOU MEAN?!
  10. Nov 21, 2019 at 8:47 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Why do you think he and I get along so well
    christyle likes this.
  11. Nov 21, 2019 at 8:52 AM
    uhplifted
    Brian
    16 DCLB OR
    Beers while banned:
    Happy Hawk - a stout brewed by Horus you can only get at Disneyland. Fucking delicious.
    study break - bottle logic. Snicker inspired sweet/lactose stout. Also delicious
    Pally Pils - green cheek. Great crispy boi. Got a 4 pack to go
  12. Nov 21, 2019 at 10:41 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Collective Arts Bourbon Barrel Aged Chocolate And Pistachio Connoli
    Imperial Stout
  13. Nov 21, 2019 at 2:23 PM
    BFRT_King Ranch
    BFRT_King Ranch Well-Known Member
    Northern VA
    '18 Cement TRDOR DCSB
    Hers and his. . Three notched biggie s'mores imperial stout and Adroit theory Nullentropy imperial ipa. IMG_20191121_171707.jpg
  14. Nov 21, 2019 at 3:03 PM
    relkins0413
    Kings Mountain, NC
    Still working on my stash of Celebration. I think in 2019 this could almost be classified as a Red IPA. No matter what, it’s such a great example of an old school IPA.
  15. Nov 21, 2019 at 3:20 PM
    uhplifted
    Brian
    16 DCLB OR
    Have not had any of this years batch, need to go find me some
    relkins0413[QUOTED] likes this.
  16. Nov 21, 2019 at 4:11 PM
    BFRT_King Ranch
    Northern VA
    I bought a bottle today. Will drink this weekend. Always a good one.
    RickS and relkins0413[QUOTED] like this.
  17. Nov 21, 2019 at 4:13 PM
    BFRT_King Ranch
    Northern VA
    IMG_20191121_182537.jpg IMG_20191121_182530.jpg Delicious beer. Kind of a mix between east and west coast styles. Not overly bitter or overly juicy. Good balance and good hop profile.
  18. Nov 21, 2019 at 6:46 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Little CA beer drop... Thanks and welcome back from your time off @uhplifted haha!
  19. Nov 21, 2019 at 7:40 PM
    Cativelense
    Nuno
    CT
    Tonight's beer of choice for the Tree House drinking festivities: Autumn.
  20. Nov 21, 2019 at 7:46 PM
    uhplifted
    Brian
    16 DCLB OR
    Having a nice crispy boi while grilling
