The beginning of my mid travel expo build
Discussion in '2nd Gen. Builds (2005-2015)' started by 10trdtaco, Oct 10, 2016.
  1. Oct 10, 2016 at 7:46 AM
    10trdtaco
    10trdtaco [OP] American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    I need to carry weight (tent, bed rack, tools,spare) and then a front winch bumper... I know aerodynamics, but this is going to be a weekend warrior here at home too! So I want a nasty mud travel setup:
    What I'm looking at now:
    Rear:
    Dmz spring under leaf kit
    Bamf shock relocator kit
    King PR2012-SS shocks
    Front:
    I have no clue where I need to be to compete with the rear end???
    Maybe some icon 2.5 ext travel ??? I just want a setup that can match my rear off road... obviously uca's as well
    ... help me out guys ... trying to keep my budget around $3500 or less lol
    ChadsPride likes this.
  2. Oct 10, 2016 at 1:01 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Up your budget.... ditch the SUA. If you're gonna load her to the tits for overland Travel you'll need weight capacity and if you ever plan on visiting the west coast you'll need every inch of height and travel you can muster.
    I would also select a thinner body shock depending on your wheel and tire combo you'll run into rubbing issues.
    agunday21 likes this.
  3. Oct 10, 2016 at 4:08 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    This would be the ticket:
  4. Oct 11, 2016 at 6:47 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    ^^ Well that got expensive real fast....
    My12DCLB and 10trdtaco[OP] like this.
  5. Oct 11, 2016 at 8:11 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    Yeah I'm not looking to go sas ... just a simple mid travel... my budget is maxed at $3500 ... any other suggestions?
    Bruce988jl likes this.
  6. Oct 11, 2016 at 8:41 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
  7. Oct 11, 2016 at 9:12 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    If you're looking to stay with a mid-travel setup, just go with some good upper control arms and either Icon or King 2.5" with remote reservoirs.
    10trdtaco[OP] likes this.
  8. Oct 11, 2016 at 10:01 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    If I did the icon stage 3 or 4 will that carry the load though or am I gunna need an aal
  9. Oct 11, 2016 at 10:52 AM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    i have the Icon Stage 4 my truck with aal and recall leaf springs, it doesn't bottom out when i load up 2 dirt bikes and gear any more but for overland i would look into a set of Dakars or OME's.
  10. Oct 11, 2016 at 1:17 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    so i can do icon stage 3 with tubular uca's, and dakar leaf pack kit i should be set? btw what is the difference in icon shocks 2.0 vs 2.5 ??? and will i be ok without getting remote reservoir front coilovers and just getting the regular 2.5 front coils?
  11. Oct 11, 2016 at 2:02 PM
    Maggot61
    Jose
    Sky Valley, CA
  12. Oct 11, 2016 at 2:13 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Icons are digressive shocks...is that what you want? They also have to be sent back to Icon for rebuild while competitors products can be rebuild at an off-road shop (or in your garage if you have the tools and skills).
    Extended travel Fox 2.5s with LR UCAs got me an additional 2 inches of down travel and I'm very happy with the ride both on and off road.
  13. Oct 12, 2016 at 3:08 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    How much total lift did the fox shocks give you... still have to wedge these 33-12.5 tires lol
  14. Oct 12, 2016 at 7:21 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    They are coilovers so the lift can be increased but they come set at 2".
  15. Oct 12, 2016 at 7:27 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    So you think my 33"s will fit? Does it give at least 3.5" of lift?
  16. Oct 12, 2016 at 10:49 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    33's usually require cutting and cab mount chop...depending on the offset of your rims. I'd suggest you contact @HeadStrong Off-Road as they have much more experience with this than I do.
    Coilovers cranked to give you 3.5" of lift will possibly ride poorly so you may be needing taller springs.
    HeadStrong Off-Road likes this.
  17. Oct 12, 2016 at 12:39 PM
    Crosis
    Dunedin Fl
    Do the longer CV shafts of the LT style eliminate the need to do the cab chop since the track is wider? What widens the rear track?
