The best way to get your truck unstuck out of mud?
Discussion in 'Off-Roading & Trails' started by IBATanker, Oct 16, 2012.
  1. Oct 23, 2012 at 11:01 PM
    #41
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Theres my ramps right there.
    I'll still cut down a tree if need be.
  2. Oct 24, 2012 at 12:04 PM
    #42
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Best bet in the snow is to always bring a shovel. Might take a bit, but you can pretty much always shovel your way out.
  3. Oct 24, 2012 at 2:08 PM
    #43
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The official "Pioneer Kit" for my M37 contains a short handed shovel, pick-mattock and michigan style ax. Plus with the troop seats full of soldiers, plenty of muscle to dig and push.
    Now imagine the hole that would require 10 men with pick and shovel to free you from.
    Howard
  4. Oct 24, 2012 at 2:54 PM
    #44
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I agree... you can almost always dig down
    having a passenger / digger is always good to :D
  5. Oct 30, 2012 at 3:58 AM
    #45
    IBATanker
    IBATanker [OP] ich bin die Scheiße
    Chuck
    Sin City
    11 TRD off road 4x4
    Future mods: Air compressor, winch, mud tires, 3 to 4 in lift, drop in air filter, throttle body spacer
    Well my next mod is to put on better tires like mudders.
  6. Oct 31, 2012 at 2:09 PM
    #46
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    Kinetic energy ropes help. They will give a little more pull if the truck that is pulling is the same size or smaller. In a pinch you can hook a strap to each truck with a tire (no rim) in the middle and it works better than nothing. The tire is screwed when your done though.
  7. Oct 31, 2012 at 8:47 PM
    #47
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    I one time ran into a guy in a 1st gen shoveling his way out by a local resevoir. Asked if he wanted a pull, he told me he had it. I think he had spent so much time at it that he was hell bent on it working at that point. He had what you had dug but was digging a semi circle so he could turn around. Must've taken hours. I kept on driving, before passing two more stuck vehicles, and eventually I stuck myself after forging a lot of new road. Used the ol pallet and winch trick since I had to get turned around. Winched myself forward out of the hole and rolled back onto a pallet while turning. Took a while but finally got all the way turned around and headed back. When I passed the two vehicles, the owners were there, I pulled them out and they offered to smoke me out. I said thanks for the offer boys but no thanks, and headed back home. 1st gen dude must've gotten himself out because I didn't see him on the way back. :rasta:
    inb4 cool story bro
  8. Nov 5, 2012 at 9:46 AM
    #48
    x2468
    x2468 Well-Known Member
    Tallahassee
    '02 TRD 4wd V6 Xcab Sr5
    Be careful man! Brunes might come after you for mentioning illicit drugs!:locked:
    (awesome story btw :cheers:)
  9. Nov 5, 2012 at 11:29 PM
    #49
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    lol thanks, I thought it was kinda funny at any rate! :D
  10. Dec 5, 2012 at 6:10 AM
    #50
    xsptaco07
    xsptaco07 Well-Known Member
    Jordan
    Atlanta
    2007 Tacoma Xsp
    xsp package, 20" enkei deep six wheels,33" cooper zeon ltz, borla exhaust, borla intake, carbon fiber trim, weathertech mats, Halo HID lights, black grille surround with mesh, smoked 3rd break and tails, 3" toytec coilovers with bilstein strut, AAL and bilstein 5160 in the rear, led tag lights, led interior lights, NTW plated bumper, anytime fog mod, blue and white cluster swap, UWS toolbox,
    Tore my bumper off.
  11. Dec 5, 2012 at 7:58 AM
    #51
    XXXX
    sKiP
    05 Prius
    I have done that before. It's pride, self reliance, and a thick head rolled into one. If I'm by myself and get stuck using a hi lift and shovel reminds me to be more cautious the next time.
    When I did this
    got myself all dug out
    hole tire dug
    truck jacked up, hole filled, base for traction
    Then when I'm all done a dude pulls up in a Jeep and asks if I need help. I said "I'm all good".
    He watched me get it out. Then we followed each other around the trails hitting harder and harder obstacles until we both needed each others help getting unstuck.
  12. Dec 6, 2012 at 11:39 PM
    #52
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    winch and a shovel
    straps if it's easy
  13. Dec 7, 2012 at 1:40 PM
    #53
    gwos25
    gwos25 Well-Known Member
    Gary
    Calgary, AB
    2012 TRD Sport
    Pretty cool that a the mud faries just showed up over night and got you out. I carry two recovery straps (20 and a 30'), a 20' tow strap, two tree saver straps, a hi-lift, with the ORK (winch kit) and 20' of chain. I usally wheel with a buddy that has a winch though, so my gear doesn't see much use. I got stuck once trying to get another guy out, we both ended up waiting around for a jeep to come by and winch us out. IF I had the kit I carry now, we would have been on our merry way in very little time.
  14. Dec 9, 2012 at 5:55 PM
    #54
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I remember the first time my buddy ever got stuck too. We spent about six hours digging the damn Suburban out of the mud. We damn near built a bridge with wood to dry ground, lifted the truck with a shitty jack, dropped it on the wood and drove it out.
    What you need:
    - Shovel (for you)
    - Shovel (for your buddy)
    - Jack (hi-lift with rim clamp)
    - Boots
    - Tampon remover :p
    - Recovery gear ( for who ever comes to pull you out)
    - Experience ( start small. If not, be willing to get messy)
    Just some advice.
  15. Dec 9, 2012 at 5:59 PM
    #55
    IgnorantlyAlberta
    David
    edmonton
    This is the exact reason I have a winch on my rear. Always remember you can never be over prepared.:cool:
  16. Dec 9, 2012 at 6:06 PM
    #56
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    Running start with a strap has always worked for me, use the biggest truck willing to do it.
  17. Feb 6, 2013 at 7:57 AM
    #57
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    05 Speedway Blue PreRunner TRD Off Road
    3 inch lift OME 885, 2in AAL, 5100's, Black Badges, Fog anytime, ABS on/off, window vents, Blacked grill and rear bumper, Afe pro s dry drop in filter.
    Dont go Ditch Diving. That can fuck so shit up in a real quick hurry.
  18. Feb 6, 2013 at 9:27 AM
    #58
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  19. Feb 6, 2013 at 4:29 PM
    #59
    IgnorantlyAlberta
    David
    edmonton
    Ive been stuck in shit like that on damn near level ground, slipperier than ice.
  20. Feb 6, 2013 at 4:49 PM
    #60
    jesse30002000
    jesse30002000 Member
    Jesse
    quebec
    2012 trd sport
    A cheaper alternative if yas are interested is to carry a sheet of foam around with your hijack, then when you're jacked up a bit, you can cut a few layers of that foam off and fill that hole.
    We use that at work for moving pianos around staircases with landings ( where I got the idea) and its worked for me the one time I used it.
