The big TRS group buy again! Due to high demand
Discussion in 'Group Buys' started by LEDsolutions, Jan 25, 2012.
Thread Status:
Not open for further replies.
  1. Feb 2, 2012 at 10:03 AM
    #101
    Themaggots
    Themaggots New Member
    Jimmy
    Quebec, Canada
    Not a Toyota
    I'm in for a set of FX-R
    Anybody knows if the projectors will be v1.1 or v3.0?
    1. Southern01Taco- Bi-xenon Morimoto Mini Stage III Kit (H1)
    2. ProjectCBR - Bi-xenon Morimoto Mini Stage III Kit (H1)
    3. Boost_Lee - Bi-xenon FX-R Stage III Kit
    4. Cabbs - BI-XENON MORIMOTO MINI STAGE III KIT (D2S)
    5. Jeffro69 - FX-R stage III Kit
    6. Zombie runner - Bi-xenon Morimoto Mini Stage III Kit (H1)
    7. TacoSuzuki - Bi-xenon Morimoto Mini Stage III Kit (H1)
    8. kcasido -Bi-xenon Morimoto Mini Stage III Kit (H1)
    9. skidoo6100 -Bi-xenon Morimoto Mini Stage III Kit (H1)
    10. Mauibuiltyota - FX-R Stage III Kit
    11. dmb - Bi-xenon Morimoto Mini Stage III Kit (H1)
    12. Billm0066 - Mini H1 stage 3 kit (Remax Realtor from Hidplanet)
    13.baldd86- BI-XENON MORIMOTO MINI STAGE III KIT (H1)
    14. rayofsi - Bi-xenon Morimoto Mini Stage III Kit (H1)
    15. 02nyc- BI-XENON MORIMOTO MINI STAGE III KIT (D2S)
    16. mikel - Bi-xenon Morimoto Mini Stage III Kit (H1)
    17. crayers16- Bi-xenon Morimoto Mini Stage III Kit (H1)
    18. 07tacos - BI-XENON MORIMOTO MINI STAGE III KIT (D2S)
    19. Frostbyte - BI-Xenon Morimoto Mini Stage III Kit (H1)
    20. stattonmw - BI-Xenon Morimoto Mini Stage III Kit (H1)
    21. QUiEtStOrM360 - BI-XENON MORIMOTO MINI STAGE III KIT (H1)
    22.allmotorrex - BI-Xenon Morimoto Mini Stage III Kit (H1)
    23. lanceb1b - BI-XENON MORIMOTO MINI STAGE III KIT (D2S)
    24. Maverick904- BI-Xenon Morimoto Mini Stage 3 (H1)
    25. Themaggots - Bi-Xenon Morimoto FX-R Stage 3
  2. Feb 2, 2012 at 10:07 AM
    #102
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I don't know the specs on the Denalis, but given that they fit I would recommend the H1.
    The 3.0 hasn't been released. 90% of the reason I haven't upgraded my setup yet.
  3. Feb 2, 2012 at 10:12 AM
    #103
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Theres 25 orders! We need tha code!!!!!!!
  4. Feb 2, 2012 at 10:25 AM
    #104
    stattonmw
    stattonmw Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    Just confused as these are conflicting which was stated in your prior post.
    "I will discourage you from getting the Mini D2S" I am not trying to be rude just would hate to see people get confused.
    I am assuming you meant the fxr kit which yes, you do have to heavily modify the headlight, but to my knoweldge both the mini D2S and mini H1 are for the most part plug and play.
  5. Feb 2, 2012 at 10:34 AM
    #105
    memario1214
    Colton
    Missoula, MT
    I don't think I was conflicting (EDIT: I can see how that post may have been misread), but I will try to elaborate further on what I was saying. The Mini D2S and the Mini H1 are both "mini" setups which mean that they utilize a little smaller projector and they are built to be installed without any major modification to your existing headlight structure.
    I have the Mini D2S, and I will honestly say that I am not impressed as much as I thought I would be. The Mini H1 has a light output that is more representative of a full blown retrofit (FX-R or LS460). When going through pics and comparing the two kits when I was looking to get my retro done, I didn't like the "Angel-wing" look that the H1 had. Having driven for nearly a year now with a retrofit, I can honestly say that the wing look that I was worried about would not be noticeable at all, and would actually provide greater width in the beam.
    Better? :notsure:
  6. Feb 2, 2012 at 10:54 AM
    #106
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Mini H1 provides a sharper cutoff, more colorful cutoff, wider beam, and general better performance than a Mini D2S. I see many more complaints about Mini D2S than H1 on here and HIDplanet
    Both are as plug and play as a retrofit can get though.
  7. Feb 2, 2012 at 11:08 AM
    #107
    Somekindagenius
    Somekindagenius New Member
    26. Somekindagenius - BI-Xenon Morimoto Mini Stage III Kit (H1)
  8. Feb 2, 2012 at 11:09 AM
    #108
    stattonmw
    Statton
    Redmond, WA
    LOL much, much better! Lots of really good info here! I had been going back and forth between the two for quite a while... My vote at this point is the H1 hopefully I will be happy enough with that, and maybe later tackle the fxr just a little intimidating at this point.
    By the way when do we get the ball rolling on getting these orders submitted, and paid for with the code?
  9. Feb 2, 2012 at 11:30 AM
    #109
    baldd86
    baldd86 Member
    That what I have been reading that the mini h1 is overall better
  10. Feb 2, 2012 at 11:33 AM
    #110
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I just emailed TRS to let them know we reached our 25 member mark
  11. Feb 2, 2012 at 11:50 AM
    #111
    baldd86
    baldd86 Member
    Sweet
  12. Feb 2, 2012 at 11:51 AM
    #112
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    For the order process. is there anywhere we need to include our forum name for TRS reference?
  13. Feb 2, 2012 at 11:55 AM
    #113
    Fstrsn
    Fstrsn New Member
    Checking in from HIDPlanet.
    27. Fstrsn -Bi-Xenon Morimoto Mini Stage III Kit H1
  14. Feb 2, 2012 at 12:07 PM
    #114
    billm0066
    billm0066 New Member
    If you look at the comparison output photos on hidplanet you will see the H1 is better. They appear a little wider. That's why im going with them. I would really like to just use oem d2s bulbs, but I can live with H1 if it means better output.
    I also emailed TRS.
  15. Feb 2, 2012 at 12:12 PM
    #115
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    they will give us a discount code.
  16. Feb 2, 2012 at 1:27 PM
    #116
    Cabbs
    Cabbs New Member
    WA
    Here's a link for anyone curious. I'm also getting the H1s instead of the D2S now.
    http://www.hidplanet.com/forums/sho...Output-Comparison-TL-E55-Murano-FX-IS-e46-LR3
  17. Feb 2, 2012 at 1:37 PM
    #117
    rayofsi
    rayofsi Well-Known Member
  18. Feb 2, 2012 at 2:14 PM
    #118
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    R5TacomaWorldGB gentleman. Order 'em up! :)
    Andrew @ TRS
    PS: No free shipping as always. One coupon per order. Thanks guys!
  19. Feb 2, 2012 at 2:23 PM
    #119
    anethema
    J
    Dawson Creek,BC
    As you can see in those comparisons, Mini H1 BLOWS Mini D2S away in width brightness and cutoff.
  20. Feb 2, 2012 at 2:29 PM
    #120
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    wow this one filled up quite fast
Thread Status:
