The Blower Motor Replacements Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reinhardtius, Jan 2, 2020.
  1. Feb 26, 2020 at 4:27 AM
    Drtnap19
    Drtnap19 Well-Known Member
    Bluegrass
    2011 DC Tacoma 4x4
    Sub for later use.
  2. Feb 26, 2020 at 5:53 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
  3. Feb 26, 2020 at 10:57 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Which also reminds me, people talk about the "click" and the "chirp". These are two different issues, right?
    Mine chirps which I believe is the bearing, since I've disassembled it twice and a drop of motor oil on the bearing always stops the chirp for about 3 weeks. Sometimes changing the fan speed stops it for a few minutes too.
    People talk about this click and adjusting screws, but I've never heard what I would call a click or tried that solution.
    Yukon DoIt likes this.
  4. Feb 27, 2020 at 8:37 PM
    ATacomaCalledQuest
    ATacomaCalledQuest New Member
    North Carolina
    2008 Tacoma 5 Lug SR5 Access Cab
    If I remember right, I believe 87103-04044 is Toyota's the 4th or 5th attempt at this blower motor. I think the first year 2nd gens shipped with a part number ending in 04040 and there have been 04041, 04042 (?), 04043, and 04044 since. Supposedly, they finally got it right with the 04044.
  5. Mar 7, 2020 at 6:34 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Question for you guys who have replaced with the oem? I just did mine and the cover does not fit now. The new motor has holes for the wires to click in for the harness. So it looks like the cover is no longer needed has any one else had the same
  6. Mar 7, 2020 at 11:37 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'd have to look up the part number but I went with an OEM replacement when mine started chirping and I haven't had an issue since. I did it close to 7-8 years ago.
  7. Mar 26, 2020 at 1:39 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    https://youtu.be/mgj7wKDbEHk
    My OEM one has made noise forever... just sick of it, ordered a TYC from Amazon and might even put dynamat on the walls of the box when I install it and try to pull apart and rework the OEM one for later
  8. Mar 26, 2020 at 1:46 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    sounds like the plastic blades are hitting something in there
  9. Mar 26, 2020 at 3:28 PM
    Shaggs
    NorCal
    There's nothing in there. I pulled everything there was one leaf and that is after I took it out. I was fully expecting a family of rodents to pop out, thank goodness there wasn't any.
    BillsSR5[QUOTED] likes this.
  10. Mar 26, 2020 at 3:29 PM
    BillsSR5
    bill
    2014 SR5
    that's pretty loud
  11. Mar 26, 2020 at 3:46 PM
    ATacomaCalledQuest
    North Carolina
    I feel like that's a significantly more aggressive sound coming from your motor than the higher pitch chirping I've heard. Hope the TYC motor fixes it.
  12. Mar 26, 2020 at 3:48 PM
    BillsSR5
    bill
    2014 SR5
    there seem to be mixed reviews on the aftermarket motors from what ive read but they should be quieter than the one in that Vid
  13. Mar 26, 2020 at 9:33 PM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    lmao. Pretty sure you have a dead squirrel in your blower.
  14. Mar 26, 2020 at 9:35 PM
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
  15. Mar 27, 2020 at 1:47 AM
    #35
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    My TYC motor that I took out was definitely louder. The new oem one is so quiet now
  16. Mar 28, 2020 at 3:50 PM
    #36
    Shaggs
    NorCal
    just put in the TYC. It definitely has a different sound, more like an electrical interference sound. The air flow is a little bit less but definitely much quieter than the one that came out.
  17. Mar 4, 2021 at 1:04 PM
    #37
    D-co
    D-co Member
    2011 TRD
    Sound system, tinted windows, bilstine 3100, 2 inch lift
    Mine went out this morning but, after reading the threads I gave the motor a knock with my palm... vola she is back in action pushing air threw the vents.
  18. Mar 4, 2021 at 1:44 PM
    #38
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    Sounds like it's on its way out. I need to lube mine as it is doing the cricket sounds.
  19. Mar 4, 2021 at 2:31 PM
    #39
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I've had a TYC for a year and a half, now it sounds like a bearing in it is bad. Annoying sound but it still works. Will get OEM next, at least OEM lasted 6 years until the blade cracked.
  20. Mar 5, 2021 at 3:09 AM
    #40
    D-co
    D-co Member
    2011 TRD
    Got 210k on the oem so far. When my motor does go I'll get oem again.
    EdinCincinnati likes this.
