The Blower Motor Replacements Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reinhardtius, Jan 2, 2020.
  1. Mar 6, 2021 at 5:03 AM
    #41
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
  2. Mar 23, 2021 at 10:36 PM
    #42
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I just replaced my blower motor resistor and blower fan at my local mechanic while getting an oil change and coolant flush. 137k miles on the truck. The BLR died about 12k miles ago lol, but I remembered that the blower was starting to make the scratching sound.
  3. Aug 14, 2023 at 7:08 AM
    #43
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    my blower motor makes constant clicking/chirping noises. dealership says "they can't hear anything" so i can't get it replaced under warranty. bastards.
  4. Aug 14, 2023 at 9:40 AM
    #44
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    There still putting in noisy blower motors in the 3rd gens
    cryptolime likes this.
  5. Aug 14, 2023 at 9:57 AM
    #45
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    OEM or bust on my truck too
  6. Aug 14, 2023 at 11:45 AM
    #46
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Just noticed this in mine this morning with the radio, good info. When it gets worse I’ll get the Oem replacement.
  7. Aug 14, 2023 at 11:50 AM
    #47
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    When I bought my truck used 5 years ago. That was the first thing I fixed. Definitely buy OEM . I had a aftermarket one at it was noisier than the one that was in there
  8. May 1, 2024 at 7:01 PM
    #48
    TacoTuesday1
    FL
    is this really worth adjusting
    Versus throw in a new one
    Just noticed vents stopped moving much air even though wiring looks fine, resistor was replaced, and cabin filter not that old. 3D printed shield on top that still has room to suck air.
    leaning towards condemning the blower motor. Pretty common on any other vehicle.
    gonna check if RockAuto has genuine brand for less
    Or if not, probably online dealer then
  9. May 17, 2024 at 3:42 PM
    #49
    gauchomigo
    gauchomigo Member
    dd
    2017 Inferno TRD Sport, Pro Grill, KDTune Max, Clazzios
    My ac blower started vibrating noises. nothing in there. Shopping around, I noticed the OEM from the dealers were same or less costly as the knockoffs. I went with OEM. I knew it would NOT be louder. Rock Auto and others were not really competitive, and didn't offer OEM.
  10. May 17, 2024 at 6:17 PM
    #50
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    ive read a lot of you guys comments. i had to replace my blower motor last week. mine had a chinese knock off in it. I got a duralast from autozone. its even noisier than the chinese knock off. it blows well. i usually have music screaming in my truck, so, i never know it unless its off with other passangers in the truck
  11. Sep 23, 2024 at 5:18 PM
    #51
    Vinchez78
    Vinchez78 Well-Known Member
    Alvin
    Black Taco TRD sport
    My blower motor I believe has gone out, I checked the fuse, relay and the clutch engages when I turn the ac on but no air coming out, I visually inspected the blower motor resistor looks ok to me but then again I'm not mechanic, so based on the research I've been doing here and YouTube, I'll be replacing both the blower motor and resistor soon.
  12. Sep 23, 2024 at 5:20 PM
    #52
    ToyotaMan2015
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    What happend with mine is the connector pretty much melted and the plug expended on the motor itself. Turn your blower on and wiggle the plug. If your motor kicks on. The motor is junk.
  13. Sep 23, 2024 at 5:26 PM
    #53
    Vinchez78
    Alvin
    Ahh.... Makes sense I'll try that
  14. Sep 23, 2024 at 5:27 PM
    #54
    Vinchez78
    Alvin
    I did noticed when I slammed the hood it cut on for about 10 seconds the it cut off
  15. Sep 23, 2024 at 6:04 PM
    #55
    ToyotaMan2015
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    If your plug is melted, you can get the plug and new wire ends at your dealer for not that expensive. @Dm93 did a great write up on the tacoma on how to bulletproof the ac systems on these.
  16. Sep 23, 2024 at 6:08 PM
    #56
    Vinchez78
    Alvin
    Awesome can u shoot me the link?
  17. Sep 23, 2024 at 6:09 PM
    #57
    ToyotaMan2015
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    Yeah, let me find it
  18. Sep 23, 2024 at 6:10 PM
    #58
    ToyotaMan2015
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
  19. Sep 23, 2024 at 6:11 PM
    #59
    ToyotaMan2015
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    The first link is to help you with diagnosis. The 2nd one is how to install a relay to keep your fan switch from overhearing. I did mine, it's not hard. Just do exactly what he says. After all that, their will be nothing to cause problems again. The reason why the blower motor fails is its because of the resistor. Toyota has a updated part #. I think it's in that link.
  20. Sep 23, 2024 at 6:41 PM
    #60
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This happened on mine. I had to cut off the harness and take the blower to my shop bench to pry apart the melted connection. After cleaning the blower connector male leads, I made a harness with .110 female butt blades. That was about six years ago and the oem blower has not failed since. I had previously replaced the resistor connector. In that situation, fan speed #3 did not work. Looking at the connector you could clearly see one of the pins was burnt. Now, gotta fix the temp display, again.
