The Blurry Future of the Mid-Size Truck Segment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pgtr, May 27, 2013.
  1. May 29, 2013 at 9:29 PM
    #101
    mikeag11
    mikeag11 Active Member
    San Antonio, Texas
    2013 PreRunner Texas Edition
    I like this look a lot!
  2. May 29, 2013 at 9:31 PM
    #102
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I had a '95 Suburban and an '06 CCSB 4x4 Duramax.
    Hated parking those beasts. I'd do my damnedest to catch an end spot where I could drive straight in and back straight out.
    Angled parking wasn't bad. Straight-in parking was a bitch because a) the drives aren't wide enough to park a Prius without at least one reverse-align-forward sequence b) idiot drivers hanging 3 feet out of their stall c) idiot drivers putting their tires ON the white line d) idiot drivers crowding and not giving you room to maneuver into a parking spot.
    At home, I'd back in.
  3. May 29, 2013 at 11:52 PM
    #103
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
  4. May 30, 2013 at 3:46 AM
    #104
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    I still disagree, because you park them side by side, anyone but a blind man can see the 1st Tundra was a small truck in the full size category.
    What I'd really like to see is actual volumetric data. I could care less about the cab, I bought a truck because a need the use of the bed, and it seems to me they keep getting smaller all the way around. My coworker has a 1986 Silverado long bed, it's freakin huge. I don't see any bed on any truck out there period with that amount of volume.
    Now I have another coworker that just bought a new blue and silver F-150. When I park my Tacoma next to it, it's pretty obvious my Taco is only a little truck, and doesn't even approach full size.
    I look at a lot of comments and it's clear people are missing the point of a truck. If you don't care about what the bed can fit, go buy an SUV. The whole purpose of a truck is to have a bed to haul and to be able to tow. Some people don't need to tow 10k pounds however, or throw a ton of gravel in the bed, thus the need for a mid size truck. You want creature comforts ? Go buy an SUV. Big or small, the whole concept of why trucks were ever marketed in the first place is slowly being lost, it seems to me :rolleyes:
  5. May 30, 2013 at 5:48 AM
    #105
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I guess all those 70's and 80's crew cab chevy's and fords aren't really real...
  6. May 30, 2013 at 7:19 AM
    #106
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    doesn't matter
    the sum total of
    parts and components wear and longevity,
    and off-road ability,
    in the Tacoma, still wins above any other light truck
    it all depends on what you use it for. if I was a contractor making money
    with the truck it'd be an F-150 I could beat the tar out of and dispose in 3 years...
    the Taco is my keeper, will own it at least 14 years if fire/total wreck doesn't take it
    I use to to haul delicate stuff (glass and music electronics) over hill and dale, where most
    4wd would hang up... or not make it at all without serious damage to bodywork or cargo
  7. May 30, 2013 at 10:53 AM
    #107
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    One problem here and that is the manufacturer. Jeeps are junk since Chrysler took them over. Just look at the problems all of their models exeprience. Some of them are downright comical unless you own one. Like the faulty valve in the gas inlet that refuses to let you fill the tank. My ex fell in love with a 2008 Liberty. I had to get her the loan on it and I am paying it off per the decree. At 75k she basically had to rebuild the front end. At 60k she complained that her drivers side window switch did not work. I did not want to take a chance that the problem was not the switch so I had her order one. I took the switch out of the panel and found out that the wiring connector was not fully seated. JUNK, JUNK, JUNK
  8. May 30, 2013 at 11:03 AM
    #108
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    The AMC era Jeeps aren't any more innocent either. I had a 80 CJ5 and it nickel and dimed me to death. Most all Jeeps need more love to keep on the road, just the way they are. Even the vintage ones were Heeps in lots of ways.
  9. May 30, 2013 at 11:07 AM
    #109
    2004TacomaSR5
    Jon
    Montana
    Thing I think that is killing the midsize and compact trucks is the fact that for a few thousand dollars more you can be in a fullsize easy. That and like the OP said, fullsize trucks are getting better gas milage every year. My old man used to have a 02 Duramax diesel and it would get 25mpg on the highway at 65 without a load. Even with 8,000lbs hooked to the bumper it would typically manage 15. Kinda sad that those numbers are the average mileage for small trucks like Tacomas and a big ass honking diesel 3/4 ton gets the same or better. That is what is killing the small truck segment I personally believe.
  10. May 30, 2013 at 11:19 AM
    #110
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Yep, I think you're spot on.
  11. May 30, 2013 at 11:35 AM
    #111
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    Agree!
  12. May 30, 2013 at 11:42 AM
    #112
    ATHiker
    Tom
    Tennessee
    My understanding is that Ford actually corrected the issue in 2012, rather than issuing a TSB.
  13. May 30, 2013 at 12:21 PM
    #113
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    So jeep has been talking about bringing out the "Gladiator"
    http://www.futureamericancars.com/jeep/2013-jeep-gladiator/
    It is basically the above. But instead of a V6 duramax that should be in it thy want to put the Fiat 2.8 liter diesel in it. This will be a huge mistake.
  14. May 30, 2013 at 12:31 PM
    #114
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    The front end looks like Chevy's minivan.
  15. May 30, 2013 at 12:34 PM
    #115
    Brian007Taco
    Not bad, but looks a bit like the Hummer truck from the side.
  16. May 30, 2013 at 12:37 PM
    #116
    Werkro01
    Werkro01 Senior Clown
    Rob
    CT
    Butters
    Long Bed Leer cap, Wheather tech floor liners, Black badges, Demello Offroad front plate bumper, rear wrap around tube bumper and sliders. Scorpion lined bed, rocker panels and fender flares.
    Ehh... I've seen better looking Jeep trucks.
  17. May 30, 2013 at 12:38 PM
    #117
    Brian007Taco
    We shall see what the 3rd gen Taco has in store as far as mpg and hp.
  18. May 30, 2013 at 12:39 PM
    #118
    Werkro01
    Rob
    CT
    Butters
    If you like square things with big wheels this has that and raises you two wheels and another axel.
  19. May 30, 2013 at 12:41 PM
    #119
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I used to have a 72 jeep j4000. That thing was a tank. Sunk a lot of money into it though.
  20. May 30, 2013 at 12:41 PM
    #120
    Brian007Taco
    This is what I am missing in life. I want it! Not really!
