The boosted screaming taco build!
Discussion in '2nd Gen. Builds (2005-2015)' started by Tacoma SS, Nov 18, 2015.
  1. Jan 26, 2016 at 8:40 AM
    #1021
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Steel if you wheel
  2. Jan 26, 2016 at 8:41 AM
    #1022
    3378jakesr5
    jake
    littleton colorado
    I have no pun for aluminum.
    Tacoma SS[OP] likes this.
  3. Jan 26, 2016 at 8:41 AM
    #1023
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    So is aluminum pretty much just for pavement princesses?
  4. Jan 26, 2016 at 8:42 AM
    #1024
    3378jakesr5
    jake
    littleton colorado
    For the most part. I have seen a lot of 3/16 steel need to be beet back to flat to bolt back on so I don't know if I want to see what aluminum does. It's fine for weekend worriors but if you wheel hard go steel.
  5. Jan 26, 2016 at 8:44 AM
    #1025
    Tacoma SS
    Denver
    I feel like I could use the extra weight of the steel anyway. I feel like the 700 pounds brings on my icons might just be LITTLE overkill right now and I need to mellow them out with some weight
  6. Jan 26, 2016 at 8:50 AM
    #1026
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    AL can be just as strong but it will gouge deeper which can hang you up more. I suggest steel for IFS, trans, and T Case to protect the vitals. Then if you want UCA skids go AL and go AL for the gas tank skids. I will be ordering an AL gas tank skid from RCI soon.
    chenbro likes this.
  7. Jan 26, 2016 at 8:51 AM
    #1027
    Tacoma SS
    Denver
    Don't you mean LCA?
  8. Jan 26, 2016 at 8:53 AM
    #1028
    Gramps
    Gramps
    07 TRD DC 4x4
    Keep in mind your springs are designed to hold you up. If you add weight it increases preload which can create a stiffer ride. It's the dampening on your shocks that are making your ride rough. But they are still new. They need time to break in.
  9. Jan 26, 2016 at 8:53 AM
    #1029
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah. Sorry.
  10. Jan 26, 2016 at 8:55 AM
    #1030
    Tacoma SS
    Denver
    I only notice it when I hit potholes or manhole covers that are kind of deep. My guess is that the spring is so stiff that it fully extends almost immediately and causes the clanking noise that I keep hearing
  11. Jan 26, 2016 at 9:04 AM
    #1031
    Gramps
    Gramps
    07 TRD DC 4x4
    Shouldn't be a clanking noise. Is the UCA hitting the spring? What bump stops are you running?
    303tacoma likes this.
  12. Jan 26, 2016 at 9:06 AM
    #1032
    Tacoma SS
    Denver
    The UCAS shouldn't be hitting the spring, that's why I bought aftermarket. And I am still running factory front bumps
  13. Jan 26, 2016 at 9:08 AM
    #1033
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Clanking?????
    Tacoma SS[QUOTED][OP] likes this.
  14. Jan 26, 2016 at 9:08 AM
    #1034
    3378jakesr5
    jake
    littleton colorado
    I want UCA's skids!!!!
    ChadsPride likes this.
  15. Jan 26, 2016 at 9:11 AM
    #1035
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah they shouldn't but you might want to Jack it up and let it extend to make sure. Factory bumps are really hard so there is a small chance you could be tapping it but I kind of doubt that with the longer coilovers.
  16. Jan 26, 2016 at 9:12 AM
    #1036
    Gramps
    Gramps
    07 TRD DC 4x4
    Make some damnit. You call yourself a fabricator?
  17. Jan 26, 2016 at 9:13 AM
    #1037
    Tacoma SS
    Denver
    If it is the upper control arms what the hell am I supposed to do? That's the reason why I bought aftermarket is to avoid issues like that
  18. Jan 26, 2016 at 9:14 AM
    #1038
    Gramps
    Gramps
    07 TRD DC 4x4
    First see if that is the problem.
  19. Jan 26, 2016 at 11:28 AM
    #1039
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Did you get that job for the other forklift place John? :fingerscrossed:
  20. Jan 26, 2016 at 11:39 AM
    #1040
    Tacoma SS
    Denver
    Waiting on a call back from Arnold. I'm filling out an app at FMH as we speak.
