The boosted screaming taco build!
Discussion in '2nd Gen. Builds (2005-2015)' started by Tacoma SS, Nov 18, 2015.
  1. Feb 6, 2016 at 1:41 PM
    #1201
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    They're up now
  2. Feb 6, 2016 at 1:47 PM
    #1202
    Tacoma SS
    Denver
    No doubt, hopefully I'll get a new one soon. Maybe @3378jakesr5s bumper when he makes a new one
  3. Feb 7, 2016 at 11:04 AM
    #1203
    Tacoma SS
    Denver
    303tacoma likes this.
  4. Feb 7, 2016 at 11:17 AM
    #1204
    Tacoma SS
    Denver
    The "hammered steel" look is awesome... I know that won't last long though image.jpg
  5. Feb 7, 2016 at 2:27 PM
    #1205
    Tacoma SS
    Denver
    The taco lean came back again since we installed the Coilovers. I just had to crank up my driver side another 2 full turns to make it go away. Good thing I haven't gotten that alignment yet!
  6. Feb 7, 2016 at 4:24 PM
    #1206
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Yeah you can only control taco lean so much with the coilover. You have to get side specific rear springs that account for the lean. So far I know of Alcan making them.
  7. Feb 7, 2016 at 4:29 PM
    #1207
    Tacoma SS
    Denver
    it shouldn't be too bad without the rear springs though right?
  8. Feb 7, 2016 at 5:57 PM
    #1208
    Gramps
    Gramps
    07 TRD DC 4x4
    Nah. You can get a little a with a full tank but it goes away as you use gas
    Tacoma SS[OP] likes this.
  9. Feb 8, 2016 at 8:07 AM
    #1209
    Tacoma SS
    Denver
    I'm still about 1/4 inch low on the driver side and that's with less than a quarter tank of gas. Maybe I should crank it up another full turn to compensate for the fuel
  10. Feb 8, 2016 at 8:19 AM
    #1210
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    you need new leafs and a spacer for the front, I think toytec has them.
  11. Feb 8, 2016 at 8:32 AM
    #1211
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    A1/4" is nothing I have probably 1/2 and I have - + Dakars
  12. Feb 8, 2016 at 9:16 AM
    #1212
    Tacoma SS
    Denver
    You don't need a spacer if you have an adjustable Coilover. I can just tighten it more but I don't think 1/4 is a big deal. I'll have to measure again with a full tank
  13. Feb 8, 2016 at 9:18 AM
    #1213
    Red Baron
    Aaron
    07 Radiant Red DCSB
    Only problem I see is you will have the coilovers set completely different with preload and soon as you wheel you will notice. The spacer will fix yo lean and keep the same settings on each side for the front.
  14. Feb 8, 2016 at 10:06 AM
    #1214
    Tacoma SS
    Denver
    Yeah I guess so, after taking a look again yesterday it looks like my rear leafs are pretty clapped out so after I get the new dakars put on hopefully that will help out a little bit and I won't need as much preload
    Red Baron[QUOTED] likes this.
  15. Feb 8, 2016 at 10:17 AM
    #1215
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    I'm in the same boat. The Tacoma rear springs are garbage. I'm pretty sure my taco actually leans the opposite way a normal one does (even with a full tank of gas) because my passenger side rear spring is completely done. I should probably crawl under there and make sure it's not actually cracked. Good thing the weather is supposed to be nice this week.
  16. Feb 8, 2016 at 10:48 AM
    #1216
    Tacoma SS
    Denver
    Yeah, looking at how flat my factor rear leafs are I could probably get about 3 full inches from adding the new Dakar pack. Then I can crank up my coilovers to avoid the stink bug stance and I'll be ready to wheel :thumbsup:
  17. Feb 8, 2016 at 10:56 AM
    #1217
    Tacoma SS
    Denver
    Might buy the dakars next Friday if @3378jakesr5 can still get me a deal and can do my shock tower relocate
  18. Feb 8, 2016 at 11:03 AM
    #1218
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
  19. Feb 9, 2016 at 6:14 AM
    #1219
    Gramps
    Gramps
    07 TRD DC 4x4
    Careful cranking coilover to the max. Ride is rough and you put more stress on the CV axle with that much angle.
  20. Feb 9, 2016 at 9:53 AM
    #1220
    Tacoma SS
    Denver
    I definitely wouldn't be going to the max. Just enough to level out the front end so it doesn't look as much like a stinkbug. If I end up having to crank it up too much I will just remove a leaf from the rears
